I have been busy tweaking my Vero 4k+ box and a have come so far until I got stuck on this issue.
Before I explain, I did read the 2 topics that contain this problem:
I’ve been playing around with my new Vero4k+ and the suspend mode, which is working now after today’s (May) update.
I had a look through the patch that was added to add the Vero suspend mode and it seems to hijack screensaver functions - meaning that if I have screensaver set to standby devices on/off in CEC settings, suspend mode does a great job of turning other devices on/off when the Vero sleeps/wakes. The side effect is that I can no longer see the screensaver if it does turn off - because…
There have been some requests to control behaviour when Vero 4K / 4K + is put in to or woken from standby using via the Power → Suspend option.
It is now possible (as of the 2018-12.1 update) to run scripts when toggling standby state.
You can place Python scripts accordingly:
/home/osmc/.kodi/userdata/wake.py
/home/osmc/.kodi/userdata/standby.py
If your script is in the right place, you should see the following in your log (debug logging is not required):
CApplication::ToggleStandby – scri…
I have made an standby.py scripts that contains the following:
import xbmc xbmc.executebuiltin('XBMC.CECStandby')
But the tv does not turn off. Why not?
I know cec is working, if I wake vero/kodi then the tv turns on and if i run this command echo "standby 0" | cec-client -s the tv turns off. So I think kodi does not execute the command?
Kodi does execute the standby.py, I can see that in de kodi log.
The wake.py works fine.
Can you guys help me?
It’s hard to tell without seeing the Kodi log.
In settings>system>input>peripherals>CEC adapter> is “devices to power off during shutdown” set correctly?
Continuing the discussion from Standby.py not sending cec standby command :
Here is the log:
2020-04-01 18:24:36.054 T:4069347328 DEBUG: HandleKey: long-escape (0x100f01b) pressed, action is suspend
2020-04-01 18:24:36.068 T:4069347328 NOTICE: Activating standby mode
2020-04-01 18:24:36.068 T:4069347328 INFO: Activating Vero standby mode
2020-04-01 18:24:36.068 T:4069347328 INFO: Toggle standby state is sleeping
2020-04-01 18:24:36.068 T:4069347328 INFO: CApplication::ToggleStandby -- Toggle TMDS clock to 0
2020-04-01 18:24:36.069 T:4069347328 INFO: CApplication::ToggleStandby -- Toggle LED brightness to 0
2020-04-01 18:24:36.069 T:4069347328 INFO: CApplication::ToggleStandby -- governor will now be powersave
2020-04-01 18:24:36.075 T:4069347328 INFO: CApplication::ToggleStandby -- HPD locking will now be hpd_lock1
2020-04-01 18:24:36.077 T:4069347328 NOTICE: CApplication::ToggleStandby -- checking for existence of /home/osmc/.kodi/userdata/standby.py
2020-04-01 18:24:36.078 T:4069347328 NOTICE: CApplication::ToggleStandby -- script /home/osmc/.kodi/userdata/standby.py found
2020-04-01 18:24:36.080 T:3599758048 DEBUG: Thread LanguageInvoker start, auto delete: false
2020-04-01 18:24:36.082 T:4069347328 DEBUG: ------ Window Deinit () ------
2020-04-01 18:24:36.085 T:3599758048 INFO: initializing python engine.
2020-04-01 18:24:36.085 T:3599758048 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/userdata/standby.py): start processing
2020-04-01 18:24:36.113 T:4069347328 DEBUG: ------ Window Init () ------
2020-04-01 18:24:36.125 T:4069347328 DEBUG: CAddonSettings[screensaver.xbmc.builtin.dim]: loading setting definitions
2020-04-01 18:24:36.126 T:4069347328 DEBUG: CAddonSettings[screensaver.xbmc.builtin.dim]: trying to load setting definitions from old format...
2020-04-01 18:24:36.129 T:4069347328 DEBUG: ------ Window Init () ------
2020-04-01 18:24:36.162 T:4069347328 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
2020-04-01 18:24:36.443 T:3610243808 DEBUG: Previous line repeats 5 times.
2020-04-01 18:24:36.443 T:3610243808 DEBUG: Thread Timer 3610243808 terminating
2020-04-01 18:24:36.459 T:4069347328 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
2020-04-01 18:24:38.697 T:3599758048 DEBUG: Previous line repeats 1 times.
2020-04-01 18:24:38.697 T:3599758048 DEBUG: -->Python Interpreter Initialized<--
2020-04-01 18:24:38.698 T:3599758048 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/userdata/standby.py): the source file to load is "/home/osmc/.kodi/userdata/standby.py"
2020-04-01 18:24:38.699 T:3599758048 WARNING: CPythonInvoker(4): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
2020-04-01 18:24:38.796 T:3599758048 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/userdata/standby.py): setting the Python path to /home/osmc/.kodi/userdata:/usr/lib/kodi/addons/script.module.elementtree/lib:/usr/lib/kodi/addons/script.module.osmccommon/lib:/usr/lib/kodi/addons/script.module.osmcsetting.apfstore/lib:/usr/lib/kodi/addons/script.module.osmcsetting.logging/lib:/usr/lib/kodi/addons/script.module.osmcsetting.networking/lib:/usr/lib/kodi/addons/script.module.osmcsetting.remotes/lib:/usr/lib/kodi/addons/script.module.osmcsetting.services/lib:/usr/lib/kodi/addons/script.module.pil/lib:/usr/lib/kodi/addons/script.module.pycryptodome/lib:/home/osmc/.kodi/addons/script.module.xmltodict/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
2020-04-01 18:24:38.797 T:3599758048 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/userdata/standby.py): entering source directory /home/osmc/.kodi/userdata
2020-04-01 18:24:38.800 T:3599758048 INFO: CPythonInvoker(4, /home/osmc/.kodi/userdata/standby.py): script successfully run
2020-04-01 18:24:38.801 T:3599758048 DEBUG: onExecutionDone(4, /home/osmc/.kodi/userdata/standby.py)
2020-04-01 18:24:38.824 T:4069347328 DEBUG: ToggleDeviceState - putting CEC device on standby...
2020-04-01 18:24:38.827 T:3599758048 INFO: Python interpreter stopped
2020-04-01 18:24:38.828 T:3599758048 DEBUG: Thread LanguageInvoker 3599758048 terminating
And I will double check de cec settings. But I don’t do a shutdown, I’m using suspend…
EDIT: OK,
Was the solution! Thanks you! Never thought off it because it said shutdown and not suspend…
Topic can be closed
Glad you that worked for you. We prefer to keep topics open and just mark them as solved.
