I can’t find out how to stop playback at the of video from usb stick. the video starts over again.
I have an Rpi2 with current version of osmc running.
thanks. I found this already. How does this help? I just use a mouse.
Also found this https://discourse.osmc.tv/t/solved-how-to-stop-play-after-movie-finished-disable-loop/11280
I can queue to playlist. But playlist does not appear in context menu. In the sidemenu i can see the current playlist. But how do I turn off loop?
Does settings>video>player>play next video automatically have anything selected in it? If so turn that off.
No it doesn’t.
Is this all videos, just playlists, ???. I think you would need to give us a bit more to go off of. Perhaps posting some debug logs could allow us to see something.
OK here is the thing. when there is an episode of show is running it does not return to the list at the end. The episode keeps running over and over again.
reboot the OSMC device
reproduce the issue
upload the log set either using the
Finally found it in the side menu of the playlist.
Thanks for help.
