I’ve just burnt a brand new image of OSMC to a new SD card for my Pi 2B.
It was working fine initially, it expanded the partition, installed files, took me through the walkthrough etc.
Once the walkthrough was complete, I used the GUI to manually check for updates and agreed to their installation. Now I’m stuck in a sad face loop.
The following extract from jounalctl seems to be the issue:
Aug 03 13:47:28 wabewewwypi mediacenter[340]: Starting Kodi...
Aug 03 13:47:28 wabewewwypi sudo[1294]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd
Aug 03 13:47:28 wabewewwypi sudo[1294]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
Aug 03 13:47:28 wabewewwypi mediacenter[340]: /usr/lib/kodi/kodi.bin: error while loading shared libraries: libbrcmEGL.so: cannot open shared object file: No such file or directory
Aug 03 13:47:28 wabewewwypi sudo[1294]: pam_unix(sudo:session): session closed for user osmc
Aug 03 13:47:28 wabewewwypi mediacenter[340]: Kodi exited with return code 127 after 0 hours, 0 minutes and 0 seconds
Don’t really see how any other logs will help as the issue is clearly that the file “libbrcmEGL.so” is missing, but you can find them here: http://paste.osmc.io/uvuvukigap
Incidentally, running find \ -iname "lobbrcmEGL.so" as root returns no result so the file isn’t on the system, yet kodi seems to depend on it. Seems to me that an update has either introduced a new version of kodi without all it’s dependencies or has removed a file without correctly checking that it has no active dependencies.
Looking at what was updated during the upgrade triggered from the GUI it would seem that kodi was replaced [rbp2-mediacenter-osmc:armhf (16.1.0-12, 16.1.0-16)]
Can I roll this package back? Is 16.1.0-16 broken?
While it may seem that way to you, you are certainly not accounting for the thousands of other users of OSMC that do not have this issue. 16.1.0-16 is not broken. Though something in your installation is broken. Corruption of the downloaded update? Existing data corruption on the system from improper shutdowns or other? Try downloading the install image and burning again would be my suggestion.
I was noticed that there is a new update (previously running June update), installed it and rebooted - black screen. Rpi2 not even starting to boot.
So I took out the sd card, downloaded osmc-installer, re-formatted the card and installed the latest OSMC again. Fired up the Rpi2 again, waited for the install to finish and on the next boot black screen again. I suspected that maybe the sd card is faulty so tried with a brand new Kingston, exactly the same thing happens.
Info
Raspberry Pi 2 model B
2A - 5V power supply (changed it as well for testing)
Sandisk Ultra 8gb
Kingston UHS1 - 8gb
Sony KDL 32bx420
Wired LAN
Nothing else.
Any idea what to check? With the card inserted, when connecting the power the red led lights up and the green one for a fraction of a second, then stops. The TV is picking up the signal, but it stays black. Mind you, OSMC install (formatting the device etc) works fine, the first reboot after that is giving me blank screen. Just to be sure, tested the latest OpenELEC and works fine. I can’t provide any logs as I can’t boot at all.
This happened to me too (fresh install of OSMC_TGT_rbp2_20160621.img) and then ran the upgrade to the July one and it went to a black screen I couldn’t get out of.
Regardless, there could be any number of reasons that could introduce corruption. Point being, this issue is not yet “widespread”. We have 3 reports out of tens of thousands of installs. Has not been seen in any testing scenarios but, at this moment I’m installing and attempting to replicate. Please be calm and patient.
dpkg -l produces the following line for rbp-userland-osmc:
ii rbp-userland-o 1.2.0-6 armhf Raspberry Pi userland package
So the same version you quote. Again this is a brand new install with only 1 upgrade from the GUI. No power loss, just the one auto reboot at the end of the installation and another at the end of the update.
root@wabewewwypi:/# apt-get install --reinstall rbp-userland-osmc
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/2,089 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 22438 files and directories currently installed.)
Preparing to unpack .../rbp-userland-osmc_1.2.0-6_armhf.deb ...
Unpacking rbp-userland-osmc (1.2.0-6) over (1.2.0-6) ...
Setting up rbp-userland-osmc (1.2.0-6) ...
Processing triggers for libc-bin (2.19-18+deb8u4) ...
I never implied that the issue was widespread, just that it happened on a clean install with a “successful” update which is worrying as it suggests it isn’t something related to my specific configuration (as I haven’t configured anything yet).
More than happy to be as patient as necessary. If no joy by the weekend though I’ll probably just reinstall again.
Here is the output atfer sudo apt-get install --reinstall rbp-userland-osmc (only saw your message after I ran it, but issue still ongoing after running that command and rebooting.
Interesting that the file is there and yet kodi can’t see it. Maybe an issue with my PATH?
That said the error in journalctl has changed now to…
Aug 03 16:22:47 wabewewwypi mediacenter[377]: Starting Kodi...
Aug 03 16:22:47 wabewewwypi mediacenter[377]: sudo: /usr/lib/kodi/kodi.bin: command not found
Aug 03 16:22:47 wabewewwypi mediacenter[377]: Kodi exited with return code 1 after 0 hours, 0 minutes and 0 seconds
Aug 03 16:22:58 wabewewwypi mediacenter[377]: Failed to set capabilities on file `/usr/lib/kodi/kodi.bin' (Invalid argument)
Aug 03 16:22:58 wabewewwypi mediacenter[377]: The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
Maybe I have fixed one issue and exposed another besides?
