I’ve been having this problem since forever really, its just that it really bothers me lately and i have to solve it.
The problem is that when i reboot the pi2 99% of the time it wont autoreconnect to the wifi router.I have to manually go to network settings and connect, retyping my password 3-4 times till it gets it. After that i cant Exit the wifi settings screen…I press Exit and nothing happens. I have to reboot the pi and hope that it will autoconnect again…otherwise, the same thing…i have to do it manually and i wont be able to exit the settings…
So my solution ? Never reboot the pi, and have it ON 24/7.
Is there a way i can fix this ?
Btw when i go into Network settings i see ALL the Layers on top of each other (wired, wireless, tethering, mysql) until i ‘move down’ in the menu.
Imagine having each settings tab on a layer in photoshop, one under the other…thats how i see it.
Because i cant go back to the menu and create a log file, are there any commands i can do to give you guys the logs manually ?
EDIT:
Figured it out how to stop/start kodi. here is the log
http://paste.osmc.io/inozimuduy
EDIT2:
I guess here is the problem ?
18:29:21 1512.674805 T:1725490208 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.TypeError'>
Error Contents: argument of type 'NoneType' is not iterable
File "/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py", line 427, in onAction
self.shutdown_process()
File "/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py", line 409, in shutdown_process
write = self.write_advancedsettings(self.advs_dict)
File "/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py", line 797, in write_advancedsettings
dictionary_valid = self.validate_advset_dict(dictionary)
File "/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py", line 778, in validate_advset_dict
if 'videodatabase' in main:
TypeError: argument of type 'NoneType' is not iterable
-->End of Python script error report<--
-Thanks
root@osmc:~# cat /etc/*-release
PRETTY_NAME="Open Source Media Center"
NAME="OSMC"
VERSION="September 2015"
VERSION_ID="2015.09-1"
ID=osmc
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.osmc.tv"
SUPPORT_URL="http://www.osmc.tv"
BUG_REPORT_URL="http://www.osmc.tv"
