I am still on version 2020.11-1 with my Vero 4K+. When trying to update I get the message " Connectivity issue while checking updates". My network connection is working though. Do I have to make a full reset or is there a better solution? Thanks!
Yeah. Do as @ActionA suggested in the previous thread advised and please provide logs.
Thanks Tom.
Solved using the hotfix mentioned in the thread “No updates - oct 2020.10-1”. Thanks!
Had the same issue, applied hotfix as mentioned , and now updating Thx ! If anyone else needs it, here is the specific thread with the hotfix
