Vero 4K+ has been stuck on Building Menu screen for the last 14 hours after update. Please advise what action to take. Thanks.
Most likely an issue with your skin.
Try the first topic in the FAQ
A simple restart of the mediacenter is all mine took.
A reboot should fix things
Cheers Sam, yes that sorted it,
Thank you
