Of course. Here is mediainfo on Channel 4 which works(can provide clip if needed aswell):
Video
Menu ID : 1123 (0x463)
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : 27
Duration : 53 min 12 s
Bit rate : 8 204 kb/s
Maximum bit rate : 8 700 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.158
Stream size : 3.05 GiB (91%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
OK, so I’ve put in a network switch at the TV so I can run the Rpi3 and Vero4k at the same time and just A/B by switching source.
Examining BBC1 I’ve made simultaneous recordings from the SD and HD streams.
I did this for “EastEnders” and later for “Shrek 2”.
The quoted mediainfo output is for the original .ts files, rather than the short .mkv cuts I’ve uploaded.
Video
Menu ID : 17540 (0x4484)
Format : AVC
Format profile : High@L4.0
Format settings, ReFrames : 4 frames
Format settings, GOP : M=8, N=24
Codec ID : 27
Duration : 29mn 1s
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Scan type : MBAFF
Video
Menu ID : 4163 (0x1043)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Codec ID : 2
Duration : 29mn 10s
Bit rate mode : Variable
Bit rate : 2 510 Kbps
Maximum bit rate : 15.0 Mbps
Width : 704 pixels
Height : 576 pixels
Active Format Description : Letterbox 16:9 image
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.248
Stream size : 524 MiB (84%)
Video
Format : AVC
Codec ID : 27
Duration : 1mn 10s
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Video
Format : MPEG Video
Codec ID : 2
Duration : 4mn 37s
Bit rate : 2 582 Kbps
Width : 704 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.255
Stream size : 85.3 MiB (84%)
In each case the live stream played fine on the Rpi. On the Vero the SD was fine but HD juddered.
The same result when playing back the recordings from each device - only HD juddered on the Vero.
In all cases the tv switches to 50Hz (set to auto switch).
Mediainfo on all files indicates 25.000 fps.
The fps reported from the info button at playback:
Rpi3 Vero
Eastenders SD 25 50
Eastenders HD 25 50
Shrek2 SD 25 25
Shrek2 HD 25 50
So the reported fps on Vero4k is different not only between SD/HD but also between programmes from the same channel.
I hope this gives you something to work with. Please do let me know if there’s anything else I can provide.
Watching without HW acceleration was interesting.
Shrek 2 looked absolutely fine.
EastEnders I’d selected because the titles are a rotating aerial view. That has perhaps a finer judder but still not right. But the footage before it, when the continuity announcer is speaking, runs in juddery slow motion, whilst the audio continues normally. Every few seconds the video seeks and jumps to catch up. Same after the titles, the program proper starts and it’s juddery slow motion again.
If it helps with diagnosis - Freeview HD live and recordings look fine for me, certainly better than my NUC. OSD says 1080p @ 50hz. The backend is ubuntu with tvh 4.1-451.
Is there any progress on this? I can see that i’m not the only one with this issues.
I have had to revert back to my RPi3 w. LibreElec for the time being, as this is the channel most watched in the household, so the Vero is fast becoming a very expensive paperweight.
Just to add that I’ve experienced this exact same issue. I have tvheadend 4.2 on a separate system and regularly record kid’s tv shows on UK channel 5 HD for playback on the Vero 4k without issue. I then recorded a program on Channel 4 HD to watch with the missus and it was stuttering really badly. File plays fine on the PC. Needless to say the usual opinionating about me wasting time and money on rubbish technology ensued and we had to watch it on the All4 app on the tele and endure adverts!
I also wondered if the tv headend client app might contribute to this issue of course?
