Add the following line: deb http://apt.osmc.tv jessie-devel main
Mearest hint of judder on the EastEnders titles- but you really have to look for it.
The Shrek scene pans smoothly.
I had an old recording of Mrs Doubtfire from Channel 4 HD which I was keeping as a test case because that used to be bad and that’s smooth as well now.
I got my Vero 4K yesterday (love it) and have installed the Myth TV client add-on. Everything works well apart from BBC HD channels which buffer an stutter when viewing Live TV. Recordings of BBC HD play perfectly as do Live Channel 4 HD and NHK HD.
I updated OSMC and Kodi immediately and allowed the box to reboot.
Let me know if you need logs or if I should start a new thread.
Cheers.
It was BBC 2 HD and BBC News HD over satellite that I had the issue on, didn’t try One HD.
Myth backend is on my server, ethernet connections, 4K TV connected via receiver.
I will capture logs tonight and post.
@sam_nazarko Did you get a chance to look into this?
I have a LibreElec box which works fine and I notice that it’s addon is a higher version. MythTV PVR Client source is now at v5.0.8. Perhaps an update is all that is required?
More Live TV improvements coming in the next update. I’m not sure if the TVHeadend client version needs bumping but if there’s a newer version available I’ll do that
This problem seems to happen on non-OSMC Kodi versions as well, so i was wondering about the root cause. I couldn’t find an explanation here in the thread, Sam seems to have fixed something (magical/unexplained), from all i read here.
How/where would i be able to find insight into the root cause ? Any specific diff on OSMC if “read the fine source” is the only way ?
