I have played this file on my PC using VLC, it plays fine, on Vero V it stutters at the start , if I pause it cures it when restarted but gradually looses lip sync over the next few minutes (the other files in the series behave the same). Any reason why?
General
Unique ID :
Complete name : T:xxxxxxxxx .mkv
Format : Matroska
Format version : Version 4
File size : 2.16 GiB
Duration : 51 min 14 s
Overall bit rate : 6 037 kb/s
Frame rate : 25.000 FPS
Writing application : mkvmerge v74.0.0 (‘You Oughta Know’) 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=3, N=50
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Constant
Bit rate : 6 000 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.116
Stream size : 2.11 GiB (98%)
Default : Yes
Forced : No
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 125 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 45.9 MiB (2%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 49 min 19 s
Bit rate : 47 b/s
Frame rate : 0.197 FPS
Count of elements : 583
Stream size : 17.1 KiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 52 b/s
Frame rate : 0.234 FPS
Count of elements : 694
Stream size : 19.1 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
