Stuttering at start of video, then lip sync loss
In the log I could see that there are some frames at the beginning that have wrong/invalid time codes. That causes confusion and the jerky playback. If you skip over the first second, then the clip should play fine.
So looks like in converting to mp4 the converter made it’s own mind up about timecodes. Timecodes can be dodgy in TV recordings - I often have problems skipping (eg through ads).
Yes, I suppose the converter creates them from scratch.
I am happy just to skip a few seconds forward as it then plays fine, I just thought that I should make you aware of the problem, it seems isolated to RTE broadcasts
Thanks. I know that this problem exists since we already had issues like that in the past. I managed to implement workarounds, but your clip can not be covered yet. I need to find a better solution for clips with bad timestamps …
