Stuttering on some scenes. Using Vero 4k on 2018.12-1
Here’s the Sample file
Here’s the Log
Media Info
General
Unique ID : 139055161145278194363380539509521624920 (0x689D0CC4BF5B30AF088F6D107E15AF58)
Complete name : Deepwater.Horizon.2016.UHD.BluRay.2160p.TrueHD.Atmos.7.1.HEVC.mkv
Format : Matroska
Format version : Version 4
File size : 61.5 GiB
Duration : 1 h 47 min
Overall bit rate : 82.0 Mb/s
Movie name : Deepwater Horizon 4K
Encoded date : UTC 2017-12-09 14:18:34
Writing application : mkvmerge v18.0.0 ('Apricity') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 76.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.383
Stream size : 57.1 GiB (93%)
Writing library : ATEME Titan KFE 3.7.3 (4.7.3.1003)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 510 cd/m2
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 5 039 kb/s
Maximum bit rate : 8 613 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.78 GiB (6%)
Title : TrueHD Atmos 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 491 MiB (1%)
Title : AC3 5.1-EX
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 36 min
Bit rate : 41.3 kb/s
Count of elements : 2984
Stream size : 28.6 MiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Bit rate : 46.2 kb/s
Count of elements : 3310
Stream size : 32.0 MiB (0%)
Title : English (SDH)
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Duration : 1 h 38 min
Bit rate : 41.5 kb/s
Count of elements : 3316
Stream size : 29.2 MiB (0%)
Title : Spanish (Latin American)
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:07:01.212 : en:Chapter 02
00:12:32.627 : en:Chapter 03
00:19:34.465 : en:Chapter 04
00:27:17.219 : en:Chapter 05
00:34:52.632 : en:Chapter 06
00:44:29.834 : en:Chapter 07
00:48:04.924 : en:Chapter 08
00:53:47.599 : en:Chapter 09
00:58:05.148 : en:Chapter 10
01:05:44.607 : en:Chapter 11
01:10:06.869 : en:Chapter 12
01:16:02.933 : en:Chapter 13
01:20:44.381 : en:Chapter 14
01:27:37.669 : en:Chapter 15
01:31:37.826 : en:Chapter 16
