My brand new Vero 4k+ is totally crashing without trace (nothing in dmesg, journalctl -f or kodi.log) when plugging in this cheap external USB DVD drive, which otherwise works fine on my workstation.
This is what it looks like, when it works:
fév 01 16:20:43 curie kernel: usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
fév 01 16:20:43 curie kernel: usb 2-2: New USB device found, idVendor=13fd, idProduct=3940, bcdDevice= 4.03
fév 01 16:20:43 curie kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
fév 01 16:20:43 curie kernel: usb 2-2: Product: INIC-3609
fév 01 16:20:43 curie kernel: usb 2-2: Manufacturer: Initio
fév 01 16:20:43 curie kernel: usb 2-2: SerialNumber: 30303030303030303030303030303030
fév 01 16:20:43 curie kernel: usb-storage 2-2:1.0: USB Mass Storage device detected
fév 01 16:20:43 curie kernel: usb-storage 2-2:1.0: Quirks match for vid 13fd pid 3940: 2000020
fév 01 16:20:43 curie kernel: scsi host3: usb-storage 2-2:1.0
fév 01 16:20:43 curie kernel: usbcore: registered new interface driver usb-storage
fév 01 16:20:43 curie kernel: usbcore: registered new interface driver uas
fév 01 16:20:45 curie kernel: scsi 3:0:0:0: CD-ROM TSSTcorp CDDVDW TS-L633A TO01 PQ: 0 ANSI: 0
fév 01 16:20:45 curie kernel: scsi 3:0:0:0: Attached scsi generic sg2 type 5
fév 01 16:20:45 curie kernel: sr 3:0:0:0: Power-on or device reset occurred
fév 01 16:20:45 curie kernel: sr 3:0:0:0: [sr0] scsi3-mmc drive: 8x/24x writer dvd-ram cd/rw xa/form2 cdda tray
fév 01 16:20:45 curie kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
fév 01 16:20:45 curie kernel: sr 3:0:0:0: Attached scsi CD-ROM sr0
The above is from my workstation, which does have a USB-3 port and can operate the DVD drive fine. I was surprised to find out it doesn’t actually work on my laptop, which has only USB-3 ports. But my laptop does not crash, it simply cycles between the USB initialization and resets. Here’s a typical reset cycle:
[fév 1 16:34] usb 2-1.2: new high-speed USB device number 4 using ehci-pci
[ +0,110293] usb 2-1.2: New USB device found, idVendor=13fd, idProduct=3940
[ +0,000007] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0,000004] usb 2-1.2: Product: INIC-3609
[ +0,000003] usb 2-1.2: Manufacturer: Initio
[ +0,000004] usb 2-1.2: SerialNumber: 30303030303030303030303030303030
[ +0,571522] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[ +0,000220] usb-storage 2-1.2:1.0: Quirks match for vid 13fd pid 3940: 2000020
[ +0,000065] scsi host6: usb-storage 2-1.2:1.0
[ +0,000757] usbcore: registered new interface driver usb-storage
[ +0,006518] usbcore: registered new interface driver uas
[ +1,079697] scsi 6:0:0:0: CD-ROM TSSTcorp CDDVDW TS-L633A TO01 PQ: 0 ANSI: 0
[ +0,001451] scsi 6:0:0:0: Attached scsi generic sg1 type 5
[ +0,383512] sr 6:0:0:0: [sr0] scsi3-mmc drive: 8x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ +0,000006] cdrom: Uniform CD-ROM driver Revision: 3.20
[ +0,000680] sr 6:0:0:0: Attached scsi CD-ROM sr0
[fév 1 16:35] usb 2-1.2: USB disconnect, device number 4
But the Vero just totally crashes: dmesg -w doesn’t even catch the USB device detection line. I feel that’s bad enough to open a bug report here. It also goes to show how useful a USB-3 port would be in my current situation.
Sorry to bring back that topic again, but it’s a fairly concrete example of why that could matter.
Arguably, that DVD drive should fallback to USB-2 correctly, I’m quite surprised by its behavior and it might be unfair to blame that on the Vero. But I would say that a device shouldn’t simply crash when buggy hardware is plugged in, particularly USB…
I would love to hear how I can diagnose this further. If there’s a way to open the Vero safely and hook up a serial console, I have the cabling and some experience to do that as well. Let me be your remote monkey! ![]()
Cheers and thank you in advance!
