Hi ! I would like to set up the Surfshark VPN on the Vero 4K.
It looks like there is no Add On and according to their website it should be installed directly on the Linux: Linux VPN (for Ubuntu): Free Download & Easy Setup - Surfshark
I copy here from the website (How to configure Kodi with Surfshark? – Surfshark Customer Support)
"To be short, you cannot install Surfshark on Kodi itself. Nonetheless, you can configure Surfshark on your device where the Kodi is installed! After setting up out connection on one of these devices, Kodi will be automatically covered with the VPN traffic and you will be able to stream content securely! "
When I go through the installation process for Linux I got an error at the stage “sudo apt-get install surfshark-release_1.0.0-1.1_amd64.deb”.
dpkg: errore nell’elaborare l’archivio /tmp/surfshark-release_1.0.0-1.1_amd64.deb (–unpack):
l’architettura del pacchetto (amd64) non corrisponde a quella del sistema (armhf)
Si sono verificati degli errori nell’elaborazione:
Is it possible to install this release on the Vero 4K?
I already tried another solution suggested in this topic New to VPN and can't find answers - #3 by anon87236014 where it suggested to use Zomboided. I installed the Add On but Surfshark is not available in the list of VPN providers.
Any help is really appreciated.
