I am trying to connect my TBS 5980 usb tuner to my Vero 4K, but it seems that the firmware is not loading? Is the firmware for this tuner added to OSMC? I thought it was supposed to be added and supported for Vero 4K from May update? I have latest June update installed.
Uname -r
3.14.29-25-osmc
lsusb
Bus 001 Device 003: ID 734c:5980 TBS Technologies China
dmesg | grep usb
[ 0.224737] usbcore: registered new interface driver usbfs
[ 0.224769] usbcore: registered new interface driver hub
[ 0.224824] usbcore: registered new device driver usb
[ 0.341390] usbcore: registered new interface driver smsc95xx
[ 0.341853] usbcore: registered new interface driver usb-storage
[ 0.341938] usbcore: registered new interface driver usbserial
[ 0.341961] usbcore: registered new interface driver usbserial_generic
[ 0.341983] usbserial: USB Serial support registered for generic
[ 0.342005] usbcore: registered new interface driver pl2303
[ 0.342027] usbserial: USB Serial support registered for pl2303
[ 0.342245] amlogic-new-usb2 d0078000.usb2phy: USB2 phy
probe:phy_mem:0xd0078000, iomap phy_base:0xffffff800047e000
[ 0.342330] amlogic-new-usb3 d0078080.usb3phy: This phy has no usb port
[ 0.342350] amlogic-new-usb3 d0078080.usb3phy: USB3 phy
probe:phy_mem:0xd0078080, iomap phy_base:0xffffff8000582080
[ 0.344452] usbcore: registered new interface driver usbhid
[ 0.344457] usbhid: USB HID core driver
[ 2.529866] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.529873] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.529879] usb usb1: Product: xHCI Host Controller
[ 2.529884] usb usb1: Manufacturer: Linux 3.14.29-25-osmc xhci-hcd
[ 2.529890] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.530548] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.530555] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.530561] usb usb2: Product: xHCI Host Controller
[ 2.530567] usb usb2: Manufacturer: Linux 3.14.29-25-osmc xhci-hcd
[ 2.530572] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.848887] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[ 2.996883] usb 1-1: New USB device found, idVendor=2252, idProduct=1037
[ 2.996894] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.996899] usb 1-1: Product: USB Keyboard Mouse
[ 2.996904] usb 1-1: Manufacturer: HBGIC Technology Co., Ltd.
[ 3.009922] input: HBGIC Technology Co., Ltd. USB Keyboard Mouse as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:2252:1037.0001/input/input2
[ 3.010120] hid-generic 0003:2252:1037.0001: input,hidraw0: USB HID v1.10 Keyboard [HBGIC Technology Co., Ltd. USB Keyboard Mouse] on usb-xhci-hcd.0.auto-1/input0
[ 3.018897] input: HBGIC Technology Co., Ltd. USB Keyboard Mouse as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.1/0003:2252:1037.0002/input/input3
[ 3.019143] hid-generic 0003:2252:1037.0002: input,hidraw1: USB HID v1.10 Mouse [HBGIC Technology Co., Ltd. USB Keyboard Mouse] on usb-xhci-hcd.0.auto-1/input1
[ 3.138899] usb 1-2: new high-speed USB device number 3 using xhci-hcd
[ 3.279007] usb 1-2: New USB device found, idVendor=734c, idProduct=5980
[ 3.279018] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.179465] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: d0078000, ctrl: 0
[ 4.179478] dwc_otg_driver_probe host only, not probe usb_otg!!!
I also have TVHeadend server and HTSP client installed, but there in the web interface I cannot see the tuner in Configuration->DVB Inputs->TV adapters.
In firmware folder I have these->
/lib/firmware
3.14.29-17-osmc
RTL8192E
RTL8192SU
ar3k
ar5523.bin
ar7010.fw
ar7010_1_1.fw
ar9170.fw
ar9271.fw
ath3k-1.fw
ath6k
brcm
config_43455c0.txt
dvb-cx18-mpc718-mt352.fw
dvb-demod-drxk-pctv.fw
dvb-demod-si2165.fw
dvb-dibusb-5.0.0.11.fw
dvb-fe-or51132-qam.fw
dvb-fe-or51132-vsb.fw
dvb-fe-or51211.fw
dvb-fe-tda10046.fw
dvb-fe-tda10071.fw
dvb-ttpci-01.fw
dvb-ttusb-dec-2000t.fw
dvb-ttusb-dec-2540t.fw
dvb-ttusb-dec-3000s.fw
dvb-usb-az6027-03.fw
dvb-usb-bluebird-01.fw
dvb-usb-it9135-01.fw
dvb-usb-it9135-02.fw
dvb-usb-terratec-h5-drxk.fw
dvb-usb-vp7049-0.95.fw
fw_bcm43455c0_ag.bin
htc_7010.fw
htc_9271.fw
mt7601u.bin
mt7610u_sta.template.dat
ngene_15.fw
ngene_17.fw
ngene_18.fw
nvram_43455c0.txt
rt2561.bin
rt2561s.bin
rt2661.bin
rt2860.bin
rt2870.bin
rt3070.bin -> rt2870.bin
rt3071.bin
rt3090.bin -> rt2860.bin
rt3290.bin
rt73.bin
rtl8192dufw.bin
rtl8192dufw_wol.bin
rtl_nic
rtlwifi
sms1xxx-hcw-55xxx-dvbt-01.fw
sms1xxx-hcw-55xxx-dvbt-02.fw
sms1xxx-hcw-55xxx-isdbt-02.fw
v4l-cx231xx-avcore-01.fw
v4l-cx23418-apu.fw
v4l-cx23418-cpu.fw
v4l-cx23418-dig.fw
v4l-cx23885-enc.fw
v4l-cx25840.fw
Which firmware is supposed to be loaded for TBS 5980?
This tuner is added to LibreELEC image, by using CrazyCat fork of media build by Ijalves to the Linux kernel 4.9.
… I will reply back here of the results later on.
