I donât think @BobCrachett confirmed it as fixed yet, so this is probably to be expected. I certainly havenât updated the skin since the issue was reported.
Canât replicate this. I downgraded the skin and then ran dist-upgrade and I got
mediacenter-skin-osmc
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 8,655 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://apt.osmc.tv/ krypton/main mediacenter-skin-osmc all 4.2.0-1 [8,655 kB]
Fetched 8,655 kB in 1s (4,626 kB/s)
(Reading database ... 41244 files and directories currently installed.)
Preparing to unpack .../mediacenter-skin-osmc_4.2.0-1_all.deb ...
Unpacking mediacenter-skin-osmc (4.2.0-1) over (4.2.0-0) ...
Setting up mediacenter-skin-osmc (4.2.0-1) ...
root@osmc:/home/osmc#
Iâve checked, and the archive is fine on the server.
Just updated from @sam_nazarkoâs last official beta build to his latest and I donât recognize any problems - all is working fine, including CEC functions.
Nice one
I was getting the same file mismatch. I just checked my deb repository sources in /etc/apt/sources.list
I had the apt.osmc.tv krypton main listed 3 times. I removed duplicates also the osmc.tv Jessie deb and Index of /osmc/osmc/download/dev/gmc ./ and then ran sudo apt-get update && sudo apt-get dist-upgrade -y
Here time it was wanted to update fewer packages and the osmc update went fine.
Tracked down the issue so it will be fixed on git today. It can be worked around in the mean time by enabling menu customisation - Settings > Interface > Configure Skin > Enable Menu Customisation.
Hey there, I moved my .kodi folder to get a clean slate. Realized today, that I can not install addons due to a malconfigured URL in /usr/share/kodi/addons/repository.xbmc.org/addon.xml, had to replace http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz with http://download.osmc.tv/kodi/addons/krypton/addons.xml.gz and so on. Removed the Addons26.db and restarted the mediacenter service refreshed the addon database and I finally could install plugins again.
Iâve found one issue so far: in my bedroom there is a RPi2 connected to a TV via HDMI using the TVâs RC to control both, OSMC and the TV with CEC.
Iâve configured OSMCâs CEC to make the TV enter standby as soon as Kodiâs screensaver kicks in. Works.
If I then power on the TV again, I can see that Kodi is still running as intended, but the screensaver will still be active (darkened screen in my case) and the TVâs RC over CEC wonât work anymore with OSMC, so I cannot do anything within Kodi anymore.
My workaround right now is to start Kore/Yatse on a tablet/phone and as soon as I initiate just one whatever action in one of those apps, the screensaver stops and CEC is working again.
So somehow the screensaver seems to stop the CEC service when started and doesnât deactivate itself when the TV is powered on again - used to work with @gmcâs Krypton builds, stopped working with the first âofficialâ OSMC-Krypton buildâŚ
Actually itâs âshutdownâ (and has been like this since OSMCâs Isengard implementation) - I want the RPi to shutdown if the TV really is turned off manually as I have a DECT controlled poweroutlet in use that turns off the power savely if the amount of power supplied is not higher then 3 Watts after a certain amount of time.
Thanks for krypton test builds Iâll give it a try. Is there any improvements to the Bluetooth streaming in the krypton builds? Thought I seen few mentions of fixes to Bluetooth streaming on GMC builds.
