The answer remains the same as when you asked 6 months ago.
After updating to Kodi v17 my Vero2 is in a bootloop caused of an addon.
I can see Kodi V17 addon migration please waitâŚ
than a sad smiley and reboot and same again.
How to stop that ![]()
http://paste.osmc.io/avozahahif
Hi Chris,
Is this using CEC?
Possible that you need to configure OSMC as a âRecorderâ rather than a player. This would give you the same behaviour as when you use Raspberry Pi.
No clue about this â add-ons should function the same across all platforms. Check that the repository is up to date (manual refresh) and try again. If it persists a debug log would be handy.
You seem to have a lot of repositories and âunofficialâ addons.
Itâs up to the maintainers of these add-ons to ensure that they work properly in Kodi Krypton. A bissection is probably the easiest way to find the culprit.
In your logs I can see that there are some errors with a Google Code repository as well. You should consider removing this repository. I donât think Google Code exists anymore.
ok i will do a fresh setup and than upgrade to v17. After that i import the database from the backup. Should solve this.
Yes â it will solve your issue.
Good evening Sam!
RPI2 and V2 tested on same TV/HDMI/Ethernet cable. Both updated to latest Beta.
Yes Sir⌠and the channel forward back skips through the video as expected on beta RPI2 build
Apparently my search skills are lacking. I checked this forum, the wiki, and the kodi forum to no avail.
How would you like me to go about this?
Thatâs what I thought too⌠strange that it installed fine onto the Beta Rpi2 build.
I have the ZIP repository and ZIP add-on stored to an NFS share.
I can install the repository on both, and the add-on on to the Rpi2 via the repository or the add-on zip.
When I try to install the add-on via either the repository (without first telling the repository to update) or add-on zip on the V2 beta it fails.
Ok⌠this is nutso.
Updating the repository on the V2 fails (works on Rp2)
But updating the repository, which then fails, on the V2 and then installing via the repository works.
⌠I had debugging on when I entered the account credentials⌠guessing that shouldnât be posted up in public so turned debugging off and restarted.
âŚSo something here is a little off⌠but not certain what to provide to help iron it out at this point⌠or just ignore it as being a one off problem.
Check out this post/thread HDMI-CEC some buttons not working on Vero2 that do work on Pi2 - #13 by androb
Chuck some logs up and I can take a look.
Occasionally, you will catch the repository at a bad time (mid refresh) which is why I suggested refreshing.
You can PM me the logs / change password.
Just for the curious tinkerer: are instructions available on how to build osmc for yourself?
Thank you, but I already looked there of course. ![]()
OSMC Build Architecture Overview states
Information on completely building OSMC from source is covered in the article Building OSMC completely from source
but no such article seems to exist.
There are instructions on building Kodi (around the forums)
Building OSMC (from scratch) is quite a long task.
There will be more documentation in the future.
Definately looking forwards for that!
I consider that a great opportunity to âget my hands dirtyâ and learn more about compiling a full system.
Thanks @Dilligaf for that link
@sam_nazarko
Changed the V2 from a Player to a Recorder as per below, however the Channel forward/back button is still disconnecting switching to the TV source. Did not happen on v16 V2. Does not happen on v17 Rpi2.
sudo nano /usr/share/kodi/system/peripherals.xml
_*** set value from 4 to 1 here: setting key=âdevice_typeâ type=âintâ value=â1â configurable=â0â _
A log of pressing forward: http://paste.osmc.io/asijibazav
(This is really annoying)
Pandokiâs add-on repository update failing:
http://paste.osmc.io/xodokeleme
However, now that the couple hoops jumped through allowed me to install PandokiâŚ
It allows me to update the add-on itself: http://paste.osmc.io/obawiniluq
(I searched the log link⌠didnât see any account log on info⌠so all good!)
Youâre editing the wrong file, edit the one in ~/.kodi/userdata/peripherals the files in .kodi override the ones in /system
I feel like a dunce. Thanks
cec_0000_0000.xml , cec_0471_1001.xml, imx_0471_1001.xml, & rpi_2708_1001.xml all contained a device type of 1 already
cec_CEC_Adapter.xmlâs device type was 4, so I changed that to a 1.
(for others following that would be: sudo nano .kodi/userdata/peripheral_data/cec_CEC_Adapter.xml)
ANDâŚ
Changing the 2 XML device types from a 4 to a 1 has solved the channel forward/back button snaffu on the V2 beta
Many thanks
Canât see any obvious reason why the repository didnât update / install.
I changed it because on some Samsung TVs it improves things and on others it breaks thingsâŚ
Big enough âissueâ to be a user selectable item? An update to one of the osmc setting screens that sets all device type settings to Cec = 1/4 perhaps? Iâm happy changing the files manually
Maybe. There should be a better way to fix it properly ideally
