It should work - just tried it.
sudo apt-get install rbp2-mediacenter-osmc=16.8-065
What error are you getting?
-065 not .065
Sorry for wasting your time Sam, its me typing he version wrong, 16.8.065 should be 16.8-065.
anyway downgrading fine now.
thanks
The mediaportal pvr is working fine with 065, but fails on 066, is it a osmc problem, or should i go to the addons owner.
@bmonster have you updated your addons recently before trying to update or did you just update ?
PVR add-ons are tied to build. They are binary-addons. So it is a regression. I am sure it will get resolved soon.
Yer i did update addons, but no change.
Think it was due to this.
16.8-066, 25 April 2016: Based off OSMC commit (46e935c) and newclock5 (e64cf2a)
Build Highlights
OSMC - fix connectivity to weaker shares (46e935c1)
newclock5
New commits in this build:
omxplayervideo: cosmetic: use default code path (da3bfe6d)
Revert “[settings] remove show EXIF picture information setting” (a79c4f93)
Revert “[rbp] Use default resampling setting on Pi2” (1621ec8b)
omxplayer: clearer GENERAL_SYNCHRONIZE logging (056eb7f3)
omxplayer: Add sync parameter to log (cfa86348)
omxplayer: Switch to using m_syncState like videoplayer (d5b962d8)
fixup speedup: consider stream details (78940780)
FFmpegImage: Fix memory leak (e64cf2ab)
Commits no longer in build:
Mediaportal pvr addon is working again with 16.8-066.
Thank you
What did you do to fix it - you replied earlier that it was broken in 066? Unless you mean fixed it 067
I wrote already that OSMC crashes on YouTube addon and other plugins. It works well on 16.8-041 but crashes on other versions were reported in my previous post. Now it crashes on the latest 16.8-067. Logs are here.
On my own plugin it throws in kodi.log a bunch of messages like this: “23:31:31 383.032318 T:1957528496 ERROR: streamin_bufferwrap: can’t stream in: requested 1 bytes, was read 0 bytes” but my plugin doesn’t crash OSMC.
The first one of errors looks like this: “23:48:24 65.708344 T:1958065072 ERROR: streamin_bufferwrap: can’t stream in: requested 16777216 bytes, was read 1314 bytes”.
RSS feeds and scrapers work well.
I did nothing, working in 067, and fails in 066.
I have youtube and a few other addons they all work fine for me.
Thanks. You said working in 066 ![]()
My mistake i think, think it should be 16.8-065
Sorry that was suppose to be .067, im on too many pain killers at the moment, so best ignored.
Can confirm that the TMDB plugin had api key issues on an earlier version but works perfectly now on 3.40. Had to update the plugin as mentioned. Anyone who has issues with scraping should try to update their plugin.
@gmc, ok with -67 I can switch to Titan skin (even so the skin change still only applies after reboot) with osmc skin I still get crash.
Nothing special in the logs, last four lines below. Did you had any success?
20:57:43 686.693237 T:1616237552 DEBUG: Thread CLinuxInputDevicesCheckHotplugged start, auto delete: false
20:57:43 686.695251 T:1957479344 DEBUG: LoadXML: load:/home/osmc/.kodi/addons/skin.osmc-master/1080i/Pointer.xml,/home/osmc/.kodi/addons/skin.osmc-master/1080i/pointer.xml,/home/osmc/.kodi/addons/skin.osmc-master/1080i/pointer.xml
20:57:43 686.695435 T:1957479344 DEBUG: LoadXML: control
20:57:43 686.697083 T:1957479344 DEBUG: LoadXML: texture(0) pointer/Pointer.png (0)
