That worked. Perfect, thanks!
16.8-149, 29 August 2016: Based off OSMC commit (dd9484c) and newclock5 (d8c9ca9)
Build Details
XBMC:
use final redirected path for internet streams (PR:10236, 1 commit, 3 files changed)
peripheral.joystick:
Remove deadzone setting (PR:48, 1 commit, 4 files changed)
16.8-150, 30 August 2016: Based off OSMC commit (dd9484c8) and newclock5 (6355681)
Build Details
XBMC:
[PVR] Guide window: Fix deadlock (occured on quickly closing and reopening the guide window). (PR:10352, 1 commit, 3 files changed)
[PVR] Recordings window: Fix recording groups not working (regression introduced by #10333) (PR:10342, 1 commit, 1 file changed)
Make “Next” visible for chapters in Estuary’s OSD (PR:10353, 1 commit, 1 file changed)
[estuary] - show buffering progress in video full screen (PR:10325, 1 commit, 1 file changed)
Cmake fixes for offline/disconnected builds (PR:10351, 3 commits, 4 files changed)
newclock5:
New commits in this build:
Revert “[rbp] [retroplayer] Initial support for mmal renderer” (9879c0a4)
16.8-151, 31 August 2016: Based off OSMC commit (dd9484c) and newclock5 (635568)
Build Details
ffmpeg: Bump to 3.1.3-Krypton-Beta3
XBMC:
[Estuary][PVR] Recordings Info dialog: Fix ‘Play recording’ button. (PR:10358, 1 commit, 4 files changed)
pvr.mediaportal.tvserver:
Internal RTSP streaming & IPv6 backend connect support (PR:46, 7 commits, 109 files changed)
16.8-152, 1 September 2016: Based off OSMC commit (dd9484c) and newclock5 (7ce7c2b)
Build Details
XBMC:
[keymap] fix window names (PR:10360, 1 commit, 2 files changed)
Double the backslash in mysql in case we’re in ‘LIKE’ (PR:10157, 1 commit, 2 files changed)
[contextmenu] refactor addon loading/initialization (PR:10356, 3 commits, 11 files changed)
Fix query that was missing the actual join condition for unique_id (PR:10362, 1 commit, 1 file changed)
[depends] gnutls 3.4.14 and nettle 3.2 (PR:10365, 1 commit, 5 files changed)
inputstream.mpd:
Avoid double DMX_GENERAL_STREAMCHANGE / Allow component selection (56522d5d)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (20c47221)
[udev] Refactor logic to avoid rapid motor events (5ab8d4a1)
[udev] Protect motor states with a mutex (73623136)
16.8-153, 2 Sept 2016: Based off OSMC commit (dd9484c) and newclock5 (4d26443)
Build Details
XBMC:
DVDAudioCodecPassthrough: Fix memory leak after (PR:10367, 1 commit, 1 file changed)
Peripheral API v1.1.0: Fix mapping D-pad on RPi for some controllers (PR:10364, 5 commits, 31 files changed)
Break out joystick improvements from #10364 (PR:10371, 5 commits, 10 files changed)
[udev] Fix rumble effect failing to play second time (88d4aab0)
16.8-154, 3 Sept 2016: Based off OSMC commit (dd9484c) and newclock5 (4d26443)
Build Details
Update to peripheral API v1.1.0: Add function to save button maps (PR:50, 5 commits, 14 files changed)
16.8-155, 6 Sept 2016: Based off OSMC commit (dd9484c) and newclock5 (4d26443)
Build Details
XBMC:
[Estuary] missing icons and a few updated ones (PR:10378, 1 commit, 7 files changed)
[keyboard] add Silesian (PR:10361, 1 commit, 1 file changed)
[PVR] Recordings window: fix crash when selecting ‘…’ (fixes trac#16866) (PR:10374, 2 commits, 4 files changed)
[PVR] Recordings: Prevent thumbnail extraction (as it cannot work pro… (PR:10373, 2 commits, 2 files changed)
AESinkAUDIOTrack: Support what Android officially supports - nothing else (PR:10355, 4 commits, 4 files changed)
[readme] fix codestyle link (3f01e418)
inputstream.mpd:
Evaluate rep-placeholders in reps (43299db8)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (4d50f576)
16.8-156, 7 Sept 2016: Based off OSMC commit (dd9484c) and newclock5 (1adac541)
Build Details
XBMC:
[PVR] Add timer/timer rule: display error box in case pvr addon does … (PR:10404, 1 commit, 2 files changed)
fix SSE usage (PR:10403, 1 commit, 5 files changed)
VideoPlayer: fix lateframes if fps does not equal refresh rate (PR:10400, 1 commit, 1 file changed)
fix python deadlocks (PR:10399, 1 commit, 4 files changed)
aml: add codecname / video dimensions to processinfo (PR:10405, 1 commit, 1 file changed)
[cmake] Fixes: in-tree addon builds and CMAKE_INSTALL_PREFIX inconsistency (PR:10380, 3 commits, 4 files changed)
inputstream.mpd:
hvc / use always single track / ADP → REP video attributes (5dd3d3fc)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (cd51d697)
inputstream.smoothstream:
Remove ? parameters for base_url (90b07cdc)
16.8-157, 8 Sept 2016: Based off OSMC commit (dd9484c) and newclock5 (1adac541)
Build Details
newclock5:
Updated commits in this build:
[rbp] [retroplayer] Initial support for mmal renderer (24b00642 => b3eeab4f)
Commits no longer in build:
[mmalrenderer] Allow RGB buffers to be allocated (6f3e0be0)
Revert “[rbp] [retroplayer] Initial support for mmal renderer” (1adac541)
Not gonna lie when we had the build breaking bug a few weeks ago, i moved to another dist.
Really wanting to move back to osmc, as its probably the fastest and most stable version for kodi for the pi3.
But need help before i can return, the dist im using has the perfect button mapping for my mce remote control, so how would I go about moving this into osmc.
I tried overwrting some files(keymaps folder, from kodi/system), but cant get anything to work.
Kind Regards
I seem to have got into a bit of a loop when using latest Krypton build (10 Sep) although it probably applies to all of them. The MyOSMC app does not work in Programs. I tried switching to confluence but I get the same issue.
I am trying to move this Pi3 from WiFi to wired and cannot access the network settings as there is no app available.
This may be a known issues, but I thought I had read that the MyOSMC app was now included in the Krypton builds as of last week.
IS there a hack to allow me to disable WiFi and enable a wired connection.
Any help appreciated.
Spart
Also worth noting you cannot disable and uninstalll this app then reinstall as the uninstall option is greyed out.
Spart
Go into add-on setting ,manage dependencies, and see if the different parts are enabled, that all I had to do to get myosmc working.
They appear to be disabled by default.
They shouldn’t be disabled on latest builds. I sent @gmc a fix for this.
@bmonster that solved it thank you for your prompt reply.
@sam_nazarko definitely not fixed Sam as this was updated this morning with the latest version.
Spart
I’m busy redoing the builds. For some reason they seem to stuck on 156 when the latest is 158.
Pi1 updates work to 158, but Pi2/3 is stuck on 156.
It’s fixed here (I tested it myself).
Post a log if you still have problems.
Just a thought, if at some point I manually disabled these addons, would osmc remember, and keep them disabled after an update.
That could be what’s happened for me, I’m sure I disabled them a while ago due to some problems.
Yes.
