[TESTING] Kodi 17 (Krypton) builds for Raspberry Pi (continued)
No.
1 sad face and all fine is well known and finally quashed in next Kodi release (skin shortcuts issue).
If you have crashes, and no one else has reported them, it sounds like a local issue. I’d suggest a new forum post with some logs if you think it’s an issue with an OSMC build. I would recommend you try reverting to Jarvis first.
Ok, I will try to produce some documented testing result on Jarvis.
But I don’t think this issue was present in earlier Krypton build.
16.8-194, 24 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (bf7ddd8d)
Build Highlights
Temporarily removed peripheral.joystick due to build errors.
XBMC:
[cmake] Properly find correct libcec version (PR:10960, 1 commit, 1 file changed)
AESinkOSS: Fix compilation after STREAM_TYPE transition (PR:10670, 1 commit, 1 file changed)
GUIWindowSlideShow: Protect against empty slides access (PR:10971, 1 commit, 1 file changed)
remove unused control id definitions (PR:10936, 1 commit, 4 files changed)
[cmake] allow RPi to build with lirc support (#10962) (30f6f3b7)
pvr.vbox:
Fixed previous coverity issues (#162) (e4183831)
newclock5:
Commits no longer in build:
GUIWindowSlideShow: Protect against empty slides access (5184a8b5)
I’m getting error on automatic updates installing with this build. Only manual update working. Is it expected behaviour or my system’s issue?
Expected behaviour.
16.8-195, 26 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (bf7ddd8d)
Build Highlights
XBMC:
FileFactory: handle library protocol (PR:10976, 1 commit, 1 file changed)
Cmake fixes (PR:10973, 6 commits, 7 files changed)
[estuary] 2nd edition (PR:10975, 1 commit, 419 files changed)
pvr.hts:
Bugfix/epg loading time improvements (PR:249, 3 commits, 3 files changed)
Because we are not signing those packages.
It can be done but makes versioning hard. Something for me to think about
Having a huge amount of trouble playing videos since I moved to this beta a couple of days ago. Almost any video local or a stream will play unwatchably slow and stutters with long pauses. I have no idea what is gone wrong with it. Strangely enough I’ve found some youtube videos are the only thing that can play smoothly. I’ve made logs of me trying to play a video that was playing fine on Jarvis. With debugging on I can see everything running smoothly at 60fps in the menus and drops to 6-8fps when playing a video with very low CPU usage.
http://paste.osmc.io/owoxukayoc
Anyone able to help?
EDIT: 18:29:09 72.921806 T:1958323120 NOTICE: VideoPlayer: Opening: /media/Ciaran/Vi - Pastebin.com
Here is a chunk of my kodi log where the video is loading and shows errors.
16.8-196, 27 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (d61b1b7)
Build Highlights:
VideoPlayer: change time parameter of SeekTime from int to double
ffmpeg: update to 3.1.5-Krypton-Beta6
XBMC:
[PVR]Small fixes and optimizations (PR:10986, 2 commits, 6 files changed)
VideoPlayer: change time parameter of SeekTime from int to double (PR:10985, 3 commits, 29 files changed)
kodi-theme-Estuary:
adjusted weather visible condition (PR:124, 1 commit, 1 file changed)
Cleanup (PR:127, 4 commits, 20 files changed)
reworked episodewidget (PR:126, 7 commits, 6 files changed)
volumeslider dialog for touch (d41aaaf1)
cleanup volume dialog (edfcb987)
volume work (a07322a6)
some small fixes (00e8e3ab)
white textcolor for editcontrol in keyboarddialog (de7cb086)
spacing for weather sublabel and fanart viewtype (0884699d)
widget cleanup (105cfdae)
imagewidget tweaks (9829f068)
widget work (0ac17a2a)
banner textcolor (728fe067)
show ep count for all listitems in more views (85616321)
merge label2 vars (76399423)
episodewidget tweaks (b2550c66)
episodewidget tweaks (9ac78aac)
show premiered instead of watched/total (e008c5b0)
smaller text for mediaflag (7e8fcde8)
some more episode tweaks (ce64208b)
animation fix (e6bd06a4)
userrating for musiclayout (b4b1ef69)
positioning (ad0b936f)
pos fix (1192d41f)
musicvideo stuff (ba5f1b1d)
musicvideo work (9e34cdc3)
better vis condition for addon ImageWidget (601f4249)
another one (2fe7db16)
fix infowall episode layout (5b2c4e9b)
streamline widget thumb labels (74fe9df5)
inputstream.mpd:
bump inputstream dependency version to 1.0.6 (4e55b385)
Merge branch ‘master’ of https://github.com/peak2d/inputstream.mpd (2d8ddb6f)
inputstream.smoothstream:
inputstream api version bump to 1.0.6 (b15e6e60)
pvr.argustv:
bump version to 2.5.1 (43869cf3)
adapt to api change - SeekTime (7d3bdba7)
pvr.demo:
adapt to API change - SeekTime (3501d606)
bump version to 2.4.2 (9ebc62c6)
pvr.dvblink:
adapt to api change - SeekTime (618c7427)
bump version to 3.3.7 (42207a03)
pvr.dvbviewer:
adapt to SeekTime to api change (2b7f8901)
bump version to 2.4.4 (2449df9a)
pvr.filmon:
adapt to api change - SeekTime (28429ce5)
bump version to 1.4.4 (f3c57b88)
pvr.hdhomerun:
adapt to api change - SeekTime (47071a52)
bump version to 2.4.3 (ef45d3f7)
pvr.hts:
adapt to api change - SeekTime (38bd4d3c)
bump version to 3.4.9 (c171114c)
pvr.iptvsimple:
adapt to api change - SeekTime (d22e1197)
bump version to 2.4.5 (d69778ea)
pvr.mediaportal.tvserver:
adapt to api change - SeekTime (a7cde91a)
bump version to 2.4.9 (8ba6a797)
pvr.mythtv:
adapt to api change - SeekTime (0deb2d55)
bump version to 4.9.1 (f00d3ef8)
pvr.nextpvr:
adapt to api change - SeekTime (a35d5494)
bump version to 2.4.8 (fe85f2a3)
pvr.njoy:
adapt to api change - SeekTime (c5bd9382)
bump version to 2.4.1 (3a322763)
pvr.pctv:
adapt to api change - SeekTime (9d9dda9a)
bump version to 1.4.3 (e829beb1)
pvr.stalker:
adapt to api change - SeekTime (1683159b)
bump version to 2.8.1 (fd800fdb)
pvr.vbox:
adapt to api change - SeekTime (6950cb61)
bump version to 3.6.1 (3dc55507)
pvr.vdr.vnsi:
adapt to api change - SeekTime (6d1fb490)
bump version to 2.6.9 (4b06d83e)
pvr.vuplus:
adapt to api change - SeekTime (e42ac005)
bump version to 2.4.5 (d2c54427)
pvr.wmc:
adapt to api change - SeekTime (493b1612)
bump version to 1.4.5 (bffb41d4)
newclock5:
New commits in this build:
fixup! ffmpeg: Revert: matroska_read_seek Fix used streams for subtitles index compensation (19f48ff9)
DemuxMVC: fixup after SeekTime API change (d61b1b72)
I’m seeing loads of ffmpeg failures.
18:29:17  81.117020 T:1259103216   ERROR: ffmpeg[4B0C63F0]: [hevc] get_buffer() failed
18:29:17  81.117119 T:1291011056   ERROR: ffmpeg[4CF343F0]: [hevc] thread_get_buffer() failed
18:29:17  81.117188 T:1291011056   ERROR: ffmpeg[4CF343F0]: [hevc] Error constructing the frame RPS.
18:29:17  81.117271 T:1291011056   DEBUG: ffmpeg[4CF343F0]: [hevc] Error parsing NAL unit #0.
Which version of the nightlies are you running? There was a bump to a new version of ffmpeg in 16.8-196. Might be worth going back to 195 and see if you still have the same issues.
I’m running the newest version AFAIK, just updated it now and I’m getting exactly the same behaviour.
Haven’t been able to figure out installing different versions or downgrading. Been searching everywhere but finding it incredibly hard to find detailed instructions. I’m computer literate and happy to go tinkering but very linux inexperienced.
Installing a previous version is mentioned in the first post.
sudo apt-get install rbp2-mediacenter-osmc=VERSION
Where version for example is 16.8-195. If you are on the Pi1 then rbp1-mediacenter-osmc
16.8-197, 30 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (d61b1b729)
Build Highlights:
XBMC:
cmake: make external, shared ffmpeg default (PR:10479, 3 commits, 3 files changed)
[cmake] allow using an existing Texturepacker binary (PR:10988, 1 commit, 2 files changed)
VideoPlayer: rtmp fixes (PR:10998, 1 commit, 1 file changed)
[PVR] Fullscreen video: On up/down and no channel info is currently s… (PR:10995, 1 commit, 1 file changed)
[PVR] Reintroduce filename sort for PVR recordings (PR:10999, 1 commit, 1 file changed)
[PVR][guiinfo] Fix listitem hastimerschedule (PR:11001, 1 commit, 1 file changed)
[Estouchy] update to match the new look of the default skin (PR:10991, 1 commit, 64 files changed)
aml: Do not force default output device for passtrough (PR:10942, 1 commit, 1 file changed)
kodi-theme-Estuary:
widget work and cleanup (PR:128, 3 commits, 4 files changed)
add mute icon to TopBarOverlay (PR:130, 1 commit, 1 file changed)
streamline context menu (PR:131, 1 commit, 1 file changed)
Use adaptive height for music osd settings (PR:134, 1 commit, 1 file changed)
hide seekbar in case sliderdialog is active (35c362b5)
another try to fix PVR OSD issues (8be55e80)
mute icon into time sublabel (65f75147)
better spacing (2662cc3b)
pvr work (96d32a8b)
showinfo only for livetv (501e8659)
font tweak, add missing font to arial fontset (6de17200)
fixedlist focusposition/movement (4a87a6f7)
improve timer window list labels (2ecea349)
cleanup post/prefixing (d6a23d48)
pvr overlay: also check for videowindow (83afdc54)
home menu wrapping (5c0e9de5)
It seems that .198 is not yet online.
I have .197 installed. After installing I got the message that the inputstream addons I had installed were not compatible. So I removed the addons, downgraded to .195 and then back to .197. How can I enable inputstream - I cannot find it and it seems not to work.
Eriol
Whoops - forgot to update sync. Should be avaialable within the hour.
Update: Ahh - seems inputstream.adaptive was not added to the last build. Will fix for the next build
Hi there. short question. With the osmc krypton builds im not to be able to load pvr addons. Always the same message “unable to load addon - unkown error occured”. Google told me that this error was solved with kodi krypton beta 5. why it isnt with osmc builds?
kr 3rr0r
hi
running sudo apt-get install rbp1-mediacenter-osmc on pi zero I keep getting:
error processing archive /var/cache/apt/archives/rbp-userland-osmc_1.5.0-1_armhf.deb (–unpack)
trying to overwrite ‘/opt/vc/bin/vcdbg’, which is also in package libraspberypi-bin 1.20161125-1
any ideas?
Thanks very much
This are the errors from log:
21:15:27.104 T:1958359040 DEBUG: CurlFile::Open(0x5c73ca8) http://192.168.0.10:8089/api/status2.html
21:15:27.105 T:1958359040 ERROR: CCurlFile::Open failed with code 404 for http://USERNAME:PASSWORD@192.168.0.10:8089/api/status2.html
21:15:27.105 T:1958359040 ERROR: AddOnLog: DVBViewer Client: Unable to get backend status. Error: Error document empty.
21:15:27.106 T:1958359040 ERROR: ADDON: Dll DVBViewer Client - Client returned bad status (1) from Create and is not usable
DVBViewer is reachable over 192.168.0.10:8089 - but not with /api/status2.html
Looks like you are trying to install on Raspbian.
You need to be running OSMC, not Raspbian
Having upgraded to Krypton via this thread [TESTING] Kodi 17 (Krypton) Beta Builds for all platforms do I need do anything other than usual sudo apt-get update && sudo apt-get dist-upgrade ?
As although I’m on kodi 17 when I run the command nothing is available or should it be done within Kodi?
There seems a lot more commands at the top of this thread than I ever ran…:astonished:
