That would explain why my install is failing with
“The following packages have unmet dependencies:
rbp2-mediacenter-osmc : Depends: xy-utils but it is not installable
E: Unable to correct problems, you have held broken packages.”
Yip. A typo. Wonder why I couldn’t find it
17.8-214, 21 April 2018: Based off OSMC commit (1d3b85a) and newclock5 (453ffb1)
OSMC:
XBMC:
inputstream.adaptive:
newclock5:
New commits in this build:
Commits no longer in build:
pvr.dvbviewer:
Includes latest addons: inputstream.adaptive (aedfa50, +3), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (7936ba1), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (5e5493b), vfs.libarchive (e7d149e)
17.8-215, 22 April 2018: Based off OSMC commit (ebc058c8) and newclock5 (453ffb1)
OSMC:
17.8-216, 23 April 2018: Based off OSMC commit (06db5209) and newclock5 (453ffb1)
OSMC:
inputstream.adaptive (aedfa50, +3), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (3799782, +4), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (5e5493b), vfs.libarchive (e7d149e)
17.8-217, 24 April 2018: Based off OSMC commit (c96614f61) and newclock5 (453ffb1)
OSMC:
17.8-218, 27 April 2018: Based off OSMC commit (6d8b175) and newclock5 (bd94422)
Known issues:
OSMC:
XBMC:
newclock5:
inputstream.adaptive (0f0ced4, +5), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (3799782, +4), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14, +2), vfs.libarchive (e7d149e)
Update: Found a problem with the dependency which will be fixed in the next version.
You can manually install the package or wait for the next build.
sudo apt-get install libinput10 libxkbcommon0
sudo systemctl restart mediacenter
17.8-219, 28 April 2018: Based off OSMC commit (b728f926) and newclock5 (bd94422)
OSMC:
Includes latest addons: inputstream.adaptive (0f0ced4, +5), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (3799782, +4), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14, +2), vfs.libarchive (e7d149e)
17.8-220, 29 April 2018: Based off OSMC commit (96e52b) and newclock5 (bd94422)
OSMC:
Update: 17.8-220 removed due to segfault
17.8-221, 30 April 2018: Based off OSMC commit (10904e) and newclock5 (bd94422)
OSMC:
XBMC:
I update 17.8.212 to 17.8.221
The version 17.8.212 worked perfectly, I had no problem.
By moving to 17.8.221, I lost the entire movie library.
The movie widgets are all empty and do not load.
By launching a Library Update, the system rebuilds all of it.
I downgraded in 17.8.214 but no better, so I need to recreate my entire library … too bad for me
I haven’t seen any recent changes to the library. If you post some debug logs they might give a clue to the problem.
Seeing a few issues here.
23:12:57.141 T:1801450224 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=S01|Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE1MjUyMDg5ODIsImlkIjoiS29kaSIsIm9yaWdfaWF0IjoxNTI1MTIyNTgyfQ.mUYCPsHH5hcV-f3VwWS_hvt6msDxoOqGIINz_KS59DsYHagvbODfJtzP5RmTyA5zKwUQHykGPc1UgybY1KvGuzGpeNQYSR4nJpm-T3iIZv6OCt9EyAAEMM5hGioMvRB6Y6-XNi0lneLJGiSbElcx-oURE0d6wCAs64dliSEMC8HYLQb6JpSfLw9zuzFP1pyGxF3BhtcVxzHD_NuwqWw4UcOuYRyv8wmHUiK2RbN_wl-RS1zIk0OQ5VWnNgu98mUNEevwgnSBRy7-V5Gt_-koJx9ifhlAm6GDjUHCDsdeukcceIC0Vv92hkui5G1LgJnSBsApj0pvbEcboQPghqhRUg&accept-language=fr
23:12:57.142 T:1801450224 ERROR: Run: Unable to parse web site
Looks like a problem with thetvdb.com. Unable to grab the content.
21:32:52.475 T:1576317680 ERROR: /home/osmc/.kodi/addons/script.artwork.beef/lib/libs/mediainfo.py:217: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
if result['label'] == mediaitem.label:
Some error with the addon. There is a dev version out, might want to try that. Or report this error to the developer.
Also a few memory issues with the same addon:
21:19:24.969 T:1604367088 WARNING: CPythonInvoker(14, /home/osmc/.kodi/addons/script.artwork.beef/service.py): the python script "/home/osmc/.kodi/addons/script.artwork.beef/service.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui16DialogProgressBGE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE
You also have quite a few old packages. You might want to run
sudo apt-get update
sudo apt-get dist-upgrade
Ok thx, I will look for thetvdb addon.
but once you have updated the packages with “sudo apt-get update” , there is a way to update everything at once?
The update doesn’t update any of the packages, it only refreshes the list. You need to run this after the upgrade
This will upgrade all the old packages
pfff, am I stupid
I report to the forum dev ti thetvdb
So, there is a bizarre behavior, that I am in a file source, so all my jackets have disappeared and only appears the name of the files.
And when I open a directory, the system looks non-stop, as long as I do not press “escape” to find the hand, otherwise it runs in a loop to plant the Rpi3.
And when I update the media library, the system does not find anything new.
There would be no way to completely empty the media library to redo it? to the point where I am …
I also tried to update the database movie addons, but I always have “update failures” they are on the deposit of “kodi team”
17.8-222, 3 May 2018: Based off OSMC commit (10904e) and newclock5 (bd94422)
OSMC:
XBMC:
pvr.dvbviewer:
inputstream.adaptive (0f0ced4, +5), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (098d23c, +6), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14, +2), vfs.libarchive (e7d149e)
