Yep:
17.8-409, 3 Feb 2019: Based off OSMC commit (48b8d05d) and newclock5 (40c4ab5b)
XBMC:
- [PVR][videoplayer] Fix PVR input stream creation ⦠(PR:15381, 1 commit, 6 files changed)
- [TexturePacker] update windows dirent implementation (PR:15392, 1 commit, 1 file changed)
- [Resolution] Check current mode if whitelist doesnāt match (PR:15385, 1 commit, 1 file changed)
pvr.mythtv:
- Allow user to configure color display for damaged recordings. (db02fb3)
update translations fr,ca,de (22b3098) - All EDL to be sent as SCENE rather than COMM_BREAK (ed3949e)
update translations fr,ca,de (9846896)
Includes latest addons:
addons: inputstream.adaptive (9b944a5), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv(83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (dc35ade), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (9846896, +8), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv(b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (bb6babc), pvr.wmc (7b28be3), pvr.zattoo(c6ff1d2, +4), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
uhhhhh all of the sudden mouse works now via VNC. Awesomeā¦finally they decided to fix something else besides PVRā¦
17.8-410, 3 Feb 2019: Based off OSMC commit (8e2add144) and newclock5 (40c4ab5b)
XBMC:
- [guilib] d3dtexture: fixed wrong render target index. (PR:15401, 1 commit, 1 file changed)
peripheral.joystick:
- addon.xml.in: Bump to version 1.4.7 for Leia release (PR:158, 1 commit, 1 file changed)
OSMC Skin 17.9.3-37
- Smoothen cover art highlighting
OSMC
- Add game.libretro.dosbox addon
17.8-412, 3 Feb 2019: Based off OSMC commit (934abc1c20) and newclock5 (f8966438d)
XBMC:
- Fix Top 100 Albums regression (PR:15422, 1 commit, 1 file changed)
- [Fix]Avoid attempt to load music info for smartplaylists (PR:15353, 1 commit, 1 file changed)
- [Threads] revert #15263, log tid instead posix thread (PR:15419, 1 commit, 5 files changed)
- [PVR][settings] Reintroduce setting "Close channel OSD after switchin (PR:15420, 1 commit, 5 files changed)
vfs.rar:
- Fix infinite loop when attempting to read from invalid file (PR:32, 1 commit, 1 file changed)
- bump to version 2.0.6 (45a0cec)
17.8-413, 7 Feb 2019: Based off OSMC commit (2b91470b452) and newclock5(f8966438d)
OSMC Skin 17.9.3-33
- Home menu context menu fix
- VideoOSD bug fix
XBMC:
- Handle empty vertex buffers in GUIFontTTFGL (PR:15358, 1 commit, 1 file changed)
- RenderCapture: Fix wrong printout (PR:15425, 1 commit, 1 file changed)
- [modernize] use std:: instead of using namespace std (PR:15431, 2 commits, 2 files changed)
- [PVR] Fix CPVRTimers::GetRecordingTimerForRecording to respect timerā (PR:15443, 1 commit, 1 file changed)
inputstream.adaptive:
- [WV] Support BJB (Base64 / JSON / Base64) / B (Base64) license response types in body (0987a13)
pvr.dvblink:
- Reschedule āUpdate Processā to update record now status (PR:112, 1 commit, 2 files changed)
Iām having this issue with green artifacts too. When can we expect a fix?
When its stable⦠this is beta channel expect bugs cant demand stuff
if you want stable revert to stable channel.
Hello Everyone,
I followed all the steps above and now Iām getting continuously the Kodi sad face
and having SSH access to my Pi2.
I did a grab-logs -A and logs may be found on https://paste.osmc.tv/pejuheqami
From what I was able to understand thereās a fatal error loading default skin:
09:41:35.259 T:1799766768 WARNING: Repository add-on repository.xbmc.org uses plain HTTP for add-on downloads in path http://download.osmc.tv/kodi/addons/leia - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
09:41:35.315 T:1917964288 ERROR: Failed to load skin 'skin.osmc.v18alpha'
09:41:35.315 T:1917964288 FATAL: Default skin 'skin.osmc.v18alpha' could not be loaded! Terminating..
Can you guys help?
EDIT: Kinda fix this:
- Edit
/home/osmc/.kodi/userdata/guisettings.xml - Replace line <setting id="lookandfeel.skin default = ātrueā> skin.osmc.v18alpha
with<setting id="lookandfeel.skin">skin.estuary</setting>
This was due to the skin being renamed which is now causing the sad face.
You will need to SSH in and run:
mv /home/osmc/.kodi/userdata/addon_data/skin.osmc.v18alpha /home/osmc/.kodi/userdata/addon_data/skin.osmc
Then start up mediacenter:
Thank you @gmc! This one did the trick. Now I have my old-used-to-it skin back
I know this is a beta, donāt worry
Just wondering what the status is as there are more users with this problem and @gmc indicated it needs fixing before it can turn stable.
Let me know if there is anything I can do to help.
Ran into the same issue with the skin.osmc did the following to get things to work.
Modified
/usr/share/kodi/system/settings/settings.xml line 3160 from
<default>skin.osmc.v18alpha</default> to <default>skin.osmc</default>
and the same in /usr/share/kodi/system/settings/settings.xml line 3172
Modified /home/osmc/.kodi/userdata/guisettings.xml
<setting id="lookandfeel.skin" default="true">skin.osmc.v18alpha</setting> to
<setting id="lookandfeel.skin" default="true">skin.osmc</setting>
Moving the directory did not seem to work
Note: There are still some issues with osmc.skin. I found the problem and will be pushing out a new build later today
17.8-414, 9 Feb 2019: Based off OSMC commit (ecf3cacbfa) and newclock5 (f8966438d)
OSMC:
- Update default skin to point to skin.osmc
XBMC:
- [sqlite] Use extended result codes (PR:15232, 4 commits, 1 file changed)
- [PVR] Ignore very first āserver not reachableā notification. (PR:15449, 1 commit, 1 file changed)
- [guiinfo] Fix ListitemAbsolute and ListItemPosition (PR:15450, 2 commits, 1 file changed)
- [addons] add for test purpose only a script for debian package generation (PR:15438, 1 commit, 1 file changed)
pvr.mythtv:
- bump version 5.10.6 (c954c7e)
It didnāt work me. I had to manually downgrade to mediacenter 17.8-407 and skin 17.9.3-36.
Same here. I have installed 17.8-414 and tried all the fixes mentioned here subsequently, but I could not get it running. I know how to downgrade the mediacenter, but how can I downgrade the skin???
Thanks!
Just as you do with the mediacenter, changing the package name and version:
sudo apt-get install mediacenter-skin-osmc=17.9.3-36
mediacenter-skin-osmc (17.9.3-36) and rbp2-mediacenter-osmc (17.8-412) works as a fall back. Thanks!
17.8-415, 10 Feb 2019: Based off OSMC commit (07d31e33e5) and newclock5 (f8966438d)
OSMC:
- Fix crash caused by skin renamed. Enable skin.osmc instead of skin.osmc.v18apha
XBMC:
pvr.mythtv:
pvr.vuplus:
- Recording edls (PR:177, 12 commits, 35 files changed)
- Use nlohmannJson and remove requirement for cmake 3.8
- Fix segfault for empty b64 strings (06cf64f)
- Add checks for string sizes (f782dcc)
addons: inputstream.adaptive (9b944a5), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv(83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (dc35ade), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (9846896, +8), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv(b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (bb6babc), pvr.wmc (7b28be3), pvr.zattoo(c6ff1d2, +4), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)[/b]
