17.8-154, 2 Jan 2018: Based off OSMC commit (6023f739) and xbmc (ffc89f64)
OSMC:
Add missing patch Fix crash on skin reload (ee2a6dfa)
Add missing patch Fix setting loss when rebooting from Kodi (e7b0bfd)
OSMC:
17.8-155, 3 Jan 2018: Based off OSMC commit (775e072e) and xbmc (a4ad91)
OSMC:
PulseAudio no longer runs as a system service; donāt check if itās running when handling the PA sink in Kodi. (001630d210)
XBMC:
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (6284566), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (bf22a18), pvr.iptvsimple (a768d0e), [url=https://github.com/kodi-pvr/pvr.mediaportal.tvserver]pvr.mediaportal.tvserver/url, pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (3c76791), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
17.8-156, 6 Jan 2018: Based off OSMC commit (1287130) and xbmc (e03aad)
XBMC:
pvr.demo:
pvr.vdr.vnsi:
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (bf22a18), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), [url=https://github.com/notspiff/vfs.libarchive]vfs.libarchive/url
17.8-157, 8 Jan 2018: Based off OSMC commit (31ae9089) and xbmc (e03aad6)
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (83ea2d5, +4), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), [url=https://github.com/notspiff/vfs.libarchive]vfs.libarchive/url
17.8-158, 10 Jan 2018: Based off OSMC commit (cb88c8a) and newclock5 (adf334c3)
OSMC:
XBMC:
pvr.hts[/url]:
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)[/b]
All, I hope this is the right place. I installed the recent nighly and wanted to use a german plugin called āSky Goā compareable to Netflix using widevine. But I receive the message that there is no Widevine DRM library available for the system architecture (see error log attached). Can you help?
22:48:35.810 T:4078092352 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.skygo.de/?action=playLive&manifest_url=http%3A%2F%2Flivemss1it-s.akamaihd.net%2Flive%2F242818_242819%2Fbulihd01.isml%2FManifest&package_code=OFBS&parental_rating=0&infolabels=%7B%27plot%27%3A+u%27Fu%5Cxdfball%3A+Bundesliga+1899+Hoffenheim±+VfB+Stuttgart%2C+16.+Spieltag%27%2C+%27title%27%3A+u%27%5BCOLOR+blue%5DSky+Sport+Bundesliga+1+HD+%7C+%5B%2FCOLOR%5DFu%5Cxdfball%3A+Bundesliga+1899+Hoffenheim±+VfB+Stuttgart%2C+16.+Spieltag%27%2C+%27originaltitle%27%3A+%27%27%2C+%27cast%27%3A+%5B%5D%2C+%27duration%27%3A+0%2C+%27genre%27%3A+%27%27%7D]
Snippets are useless. Full logs with debugging only.
@sam_nazarko Sorry. You are right. Attached the full Kodi log with debugging activated.
maybe check with this guy he might know more
Yeah, this is the same problem as I had on my Raspberry Pi 3.
In this case, the system architecture is reported as āarmv7ā but the InputStream Helper ignores the last character which leads to āarmvā.
This patch should fix it until the next update:
--- inputstreamhelper.py 2018-01-11 20:44:58.068547087 +0100
+++ inputstreamhelper_new.py 2018-01-11 20:47:08.367991376 +0100
@@ -128,8 +128,7 @@
if arch in config.X86_MAP:
return config.X86_MAP[arch]
elif 'armv' in arch:
- arm_arch = 'armv' + arch.split('v')[1][:-1]
- return arm_arch
+ return arch[:5]
return arch
Go to ~/.kodi/addons/script.module.inputstreamhelper/lib, save the patch to a file named patch.diff and apply it with
$ patch < patch.diff
@eminga Thanks. I tried, but I receive the following error by patching. Can you assist?
patching file inputstreamhelper.py
Hunk #1 FAILED at 128.
1 out of 1 hunk FAILED ā saving rejects to file inputstreamhelper.py.rej
Oops, seems like your file is different from mine, probably my fault, sorry.
To patch it by hand, open the file inputstreamhelper.py with your favorite editor, go to ~ line 128, delete the line arm_arch = 'armv' + arch.split('v')[1][:-1] and in the following line replace arm_arch by arch[:5].
EDIT: Definitely my fault, I updated my original post, the patch should work now.
Are you running the latest inputstreamhelper. Its was updated 8 days ago.
Thanks, this was the solution.
Sorry for this question. But how to figure this out. I donāt found this addon in Kodi, only the inputstream adaptive. But I reinstalled my system seconds ago with moving to the Kodi 18 Aplha Test Built. So I assume yes.
Under your addos you can check if there are updates. Latest inputstreamhelper is 0.2.4
The Kodi Addon Menu? Yesterday I was not able to find this addon there. I need to recheck today when I back at home.
But so far the issue was resolved (see above).
17.8-159, 12 Jan 2018: Based off OSMC commit (01a741) and xbmc (d6e5222)
OSMC:
XBMC:
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), [url=https://github.com/notspiff/vfs.libarchive]vfs.libarchive/url
Hi everyone, Iām new here, so please, be gently with me. Iāve went through most of the posts in this topic and canāt find the answer: Can we play, at this alpha stage, videos in rar files (r00, r01ā¦, rar)?
Every time I try to open a video in rar files I have no video and only some pieces of audio in background.
The only things Iāve found:
17.8-142
vfs.libarchive:
changed: disable rar support (8fa085e)
and:
17.8-143
vfs.libarchive:
added: multi-volume support (PR:111, 1 commit, 2 files changed)
Here is my log when I was trying to access multi-rar video: https://paste.osmc.tv/mopozubaki
Thank you ![]()
