[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
I’ve never used the rar functionality before so can’t comment if its working or not. Never seen the point of this tbh :slight_smile:
Looking at your logs there is some sort of incompatibility on the .rar file. Probably best to check with the addon maintainer.
00:39:46.645 T:3766481664 WARNING: CreateLoader - unsupported protocol(rar) in rar://nfs%3a%2f%2f192.168.1.68%2fnfs%2fMovies%2fSeriale%2fLucifer%2fLucifer.S03E07.1080p.WEB.x264-TBS%2flucifer.s03e07.1080p.web.x264-tbs.rar/lucifer.s03e07.1080p.web.x264-tbs.mkv
17.8-160, 13 Jan 2018: Based off OSMC commit (9f91aa5e) and xbmc (cb57886)
OSMC:
  • Re-add pvr.mythtv (9f91aa5e2)
XBMC:
  • [fix] boolean condition window.is does not work properly (PR:13346, 1 commit, 1 file changed)
  • [depends] bump python27 to 2.7.14 (PR:13328, 4 commits, 13 files changed)
  • Update RetroPlayer’s Render Manager documentation (PR:13341, 2 commits, 3 files changed)
  • RendererDRMPRIME: add atomic support (PR:13192, 4 commits, 11 files changed)
pvr.vdr.vnsi:
  • fix osd for legacy OpenGL (4db947c)
Thanks for the replay. I have loads of movies in rar files so I did use this functionality a lot. It worked with Krypton and wonder if anyone in Leia release pushed it to work? And yes, I know it is alpha :slight_smile:
17.8-161, 14 Jan 2018: Based off OSMC commit (d8d429cd) and xbmc (d7d9f9c)
XBMC:
  • [gui] refactor window is topmost methods and add new boolean conditions (PR:13348, 7 commits, 11 files changed)
  • [xbmc][improvement] Add a platform abstraction for temp files / directories (PR:13253, 1 commit, 9 files changed)
pvr.mythtv:
  • fill major and minor number for channel in group (3200b09)
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (3200b09, +1), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c, +2), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
17.8-162, 15 Jan 2018: Based off OSMC commit (73f85db) and xbmc (d7d9f9c)
OSMC:
  • Update Update better cec behaviour patch (73f85db)
  • Do not use TV menu language from CEC by default (9e718df95)
  • Vero 4K: add some fallback FPS when there are no hints (99cfcf8)
  • Vero 4K: do not stream silence. Fixes GUI sound lag and buzz (065b5dd)
  • Vero 4K: fix for delays when switching channels using UDP IPTV streams (204fc6a11)
17.8-163, 16 Jan 2018: Based off OSMC commit (4cd7e455) and xbmc (18f76aba)
XBMC:
  • [PVR] Add missing parental check to CPVREpgInfoTag::EpisodeName. (PR:13365, 1 commit, 4 files changed)
  • [depends] mark app_rendersystem as substitute variable (PR:13369, 2 commits, 2 files changed)
  • fix focus being lost when that was not intended (PR:13359, 1 commit, 1 file changed)
  • [wayland] Support xdg_shell stable (PR:13344, 8 commits, 13 files changed)
  • VideoPlayer: fix segfault when stopping bluray playback (PR:13370, 1 commit, 1 file changed)
  • Application: Set volume after opening file (PR:13372, 1 commit, 1 file changed)
pvr.octonet:
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (3200b09, +1), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf, +1), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c, +2), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
Hi @gmc,
patching of 164 fails:
Hunk #1 succeeded at 298 (offset 1 line).
can't find file to patch at input line 120
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/xbmc/windowing/egl/EGLNativeTypeAmlogic.cpp b/xbmc/windowing/egl/EGLNativeTypeAmlogic.cpp
|index 3a5e8f7..f3dd16c 100644
|--- a/xbmc/windowing/egl/EGPreformatted textLNativeTypeAmlogic.cpp
|+++ b/xbmc/windowing/egl/EGLNativeTypeAmlogic.cpp
File to patch: ^CMakefile:20: recipe for target 'vero3' failed
make: *** [vero3] Interrupt
cu
Thanks, I haven’t started building 164 yet. Its quite common for patches for break as new commits are done upstream.
Will fix them asap.
Thx, just wanted to let u know! :wink:
cu
Hi all, I’m running Kodi 18 on the Vero 4k only since a few days and I wonder if the “Amazon VOD” Add-On is running with inputstream. I tested it but I get a error message. In the corresponding community to this addon some others also are facing this issue. Most of them are running Kodi 18 with libreelec.
And the solution shall be using an actual libwidevinecdm.so (for example 1.4.8.1029).
So my quesions: Was this Add-On running before and in general? And how to update libwidevinecdm.so. Is this possible on osmc?
This library is already included. You should find it under
/home/osmc/.kodi/cdm
If u want i can give a script to u, which extracts the actual lib out of an chromeos-image, but it’s only for armhf.
cu
Probably the same script that I"m using. Grabs the file out of http://odroidxu.leeharris.me.uk/xu3/chromium-widevine-1.4.8.823-2-armv7h.pkg.tar.xz
Unless there is a newer version around?
Hi gmc,
newest is 1029. :wink:
you’ve got mail! :smile:
Yes, I need the newest one. But sounds like I can use the scripts which are also available for Libreelec to extract it from chromium. I will give it a try. Thanks @kid63
Of course, u can take them also! :wink:
cu
17.8-164, 19 Jan 2018: Based off OSMC commit (091ed386) and xbmc c8e690)
osmc
Remove widewine library as we are not allowed to redistribute. (You will need to use a script to download and install your system)
More info here with the script:
[HOW-TO ALL PLATFORMS]Can I use Netflix on OSMC?(post 4) - #35 by joakim_s
inputstream.adaptive:
[HLS] support GET parameters for license_key retrieval (9d183a9)
pvr.zattoo:
Re-enable osx build and cleanup travis file (PR:10, 1 commit, 1 file changed)
pvr.mediaportal.tvserver:
[fix] allow building with glibc 2.26 or newer (PR:81, 1 commit, 2 files changed)
Includes latest addons: inputstream.adaptive (9d183a9), inputstream.rtmp (482f5c1), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3, +1), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
17.8-165, 21 Jan 2018: Based off OSMC commit (bbad2a9e6) and newclock5 (0bb0e77)
OSMC
Vero 4K: add support for downgrading and matching resolution (bbad2a)
XBMC
  • Music Artwork Consistently Availlable To GUI (PR:13352, 1 commit, 8 files changed)
  • [PVR] Guide window: Fix crash when switching profiles and both old an (PR:13397, 1 commit, 1 file changed)
  • [pvr][guiinfo] Fix PVR.EpgEventProgress. (PR:13398, 1 commit, 5 files changed)
Includes latest addons: inputstream.adaptive (9d183a9), inputstream.rtmp (482f5c1), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3, +1), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
17.8-165, 21 Jan 2018: Based off OSMC commit (bbad2a9e6) and xbmc (6b3552e)
XBMC:
  • FIX: [droid] let gradle handle debuggable (PR:13405, 1 commit, 1 file changed)
  • AE: fix compensation distance (PR:13404, 1 commit, 1 file changed)
  • [PVR][Estuary] Guide window teaks for more consistency and readability. (PR:13402, 1 commit, 2 files changed)
  • [xbmc] Update .gitignore (PR:13399, 1 commit, 1 file changed)
  • event stream: fix order (PR:13396, 1 commit, 1 file changed)
  • CHG: [droid] Draw GUI on own View (PR:13400, 1 commit, 14 files changed)
  • Resume last played media after sleep - DVD and stacks update (PR:13407, 1 commit, 3 files changed)
  • VideoPlayer: vaapi - fix bob and yadif methods (PR:13408, 1 commit, 3 files changed)
  • windowing: amlogic: set framebuffer to maximum size before initializing EGL (PR:13391, 1 commit, 1 file changed)
17.8-167, 24 Jan 2018: Based off OSMC commit (9a8d4cf908) and xbmc (dbdbda)
XBMC:
  • [fix][android] Geometry.h move missed at 7ec2489 (PR:13414, 2 commits, 2 files changed)
  • fix segfault (PR:13411, 2 commits, 3 files changed)
  • filesystem: set proper check size for smb (PR:13401, 1 commit, 1 file changed)
  • FIX: [doc] sdk 26 required after Oreo merge (PR:13419, 1 commit, 1 file changed)
    [depends] curl: make sure openssl is compiled in (PR:13418, 1 commit, 1 file changed)
  • VideoPlayer: expose encoded display metadata to renderer (PR:13417, 1 commit, 2 files changed)
Includes latest addons: inputstream.adaptive (9d183a9), inputstream.rtmp (b3ffc49, +2), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3, +1), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
