[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
i’m having problems with livetv. terrible stutter…
i’m on 17.8-166, livetv with vdr vnsi.
and this is what my log looks during file playback: 22:48:16.335 T:3472741120 DEBUG: write codec data failed, write_bytes(-1), err - Pastebin.com
can’t see any different in logs with playback from file (nfs). i get the same messages but not the stuttering.
livetv is not “watchable” at the moment :frowning:
17.8-168, 27 Jan 2018: Based off OSMC commit (7f2589c) and xbmc (7379a75)
XBMC:
  • [cmake] move ifdef conditions to cmake (PR:13430, 1 commit, 10 files changed)
  • [cleanup] remove dead code POPUP_SEEK_LABEL (PR:13431, 2 commits, 1 file changed)
  • [depends] improve rebuilding detection (PR:13436, 10 commits, 54 files changed)
  • [AML] define MESA_EGL_NO_X11_HEADERS to detect correct egl_platform (PR:13425, 1 commit, 2 files changed)
  • FIX: [droid;gradle] override aaptOptions (PR:13437, 1 commit, 1 file changed)
  • [GLES] updates and cleanup (PR:13406, 1 commit, 3 files changed)
  • [xbmc] move Environment to platform and split to platform specific implementations. (PR:13424, 3 commits, 18 files changed)
  • [gui] cleanups in WindowManager especially for getting the active window and dialog id (PR:13433, 5 commits, 23 files changed)
inputstream.adaptive:
  • [depends] bump expat to 2.2.5 (PR:114, 1 commit, 3 files changed)
Includes latest addons: inputstream.adaptive (b28d3f0, +1), inputstream.rtmp (b3ffc49, +2), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3, +1), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
17.8-169, 28 Jan 2018: Based off OSMC commit (23b835c) and xbmc (6ad6c22e)
XBMC:
  • PVR] Fix trac#17748. (PR:13438, 1 commit, 1 file changed)
  • [gui] confirm keyboard dialog with enter while on edit control (PR:13439, 2 commits, 1 file changed)
  • [windows] d3d11: use smart pointers (ComPtr) instead of raw pointers. (PR:13442, 7 commits, 20 files changed)
  • [xbmc][windows] Fix a bunch of warnings for windows x64 (PR:13366, 1 commit, 14 files changed)
Includes latest addons: inputstream.adaptive (b28d3f0, +1), inputstream.rtmp (b3ffc49, +2), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), [url=https://github.com/kodi-pvr/pvr.demo]pvr.demo/url, pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3, +1), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
Today OSMC installed the update of the Leia alpha automatically. I don’t needed to sudo dist-upgrade. Is this new?
If you checked for updates with myosmc and accepted prompts then it would have upgraded to the latest version.
Should not have automatically upgraded itself without a prompt.
You can use my osmc or apt-get dist-upgrade.
I started OSMC and he did asked me to grant installing the update maybe based on the automatic check. I thought (based on the instructions in the first thread) that this does not work. So can I update through OSMC or should I use sudo dist-upgrade?
As @gmc wrote:
Thanks, so maybe correct this in the first thread (see quote)
Updated. Updating didn’t work on the gui previously as the packages were not signed.
17.8-170, 29 Jan 2018: Based off OSMC commit (b3b55a40) and xbmc (e1e969b)
OSMC
XBMC:
  • [Android] default sdk=android-26 / update doc (PR:13420, 1 commit, 13 files changed)
  • [videoplayer] Fix vdpau crash after #13428. (PR:13448, 1 commit, 1 file changed)
  • Change label name to get multiple ratings (PR:13429, 1 commit, 1 file changed)
  • Fix hang on exit. (PR:13447, 1 commit, 2 files changed)
17.8-171, 2 Feb 2018: Based off OSMC commit (4a2ca950e0) and xbmc (65f0623e)
OSMC:
Fix for compile issue #13462 (884e6ea )
XBMC:
  • Revert “compile fix” (PR:13459, 1 commit, 1 file changed)
  • Revert “[AML] compile fix (#13450)” (PR:13460, 1 commit, 6 files changed)
  • Fix for DVDs not playing under Linux when using UDisks. (PR:13451, 1 commit, 1 file changed)
  • [VP] Add Reset method to VideoPicture which has changed from struct … (PR:13461, 1 commit, 2 files changed)
  • [AML/ANDROID] Make Android / AML work again after recent Renderflags (PR:13462, 1 commit, 4 files changed)
Includes latest addons: inputstream.adaptive (b28d3f0), inputstream.rtmp (b3ffc49), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
17.8-172, 3 Feb 2018: Based off OSMC commit (4a2ca950e0) and xbmc (f621a02)
XBMC:
  • [Estuary] hide repeat / random in partymode (PR:13465, 1 commit, 1 file changed)
  • add HTTPS support for RSS feeds (PR:13453, 1 commit, 9 files changed)
  • [xbmc] refactor instantiation of storage provider and power manager syscalls (PR:13258, 2 commits, 35 files changed)
17.8-173, 6 Feb 2018: Based off OSMC commit (6ab63e5a) and xbmc (a03c941f)
OSMC
  • Update patch Vero3-117rbp-094. Applied Upstream
  • Add patch Allow-sharing-for-mounted-disks
XBMC:
  • VideoPlayer: opengl - fix yuv2rgb (PR:13477, 1 commit, 2 files changed)
  • [jsonrpc] fix GetFavourites after dd29b3e (PR:13410, 1 commit, 2 files changed)
  • [depends] gnutls: don’t use getentropy on darwin systems (PR:13479, 1 commit, 2 files changed)
  • [addons] don’t use event load/unload in conjunction with async events (PR:12846, 1 commit, 4 files changed)
  • [addons] refactor dependecy tuples to a struct (PR:13473, 1 commit, 20 files changed)
  • [mention-bot] Nuke file (PR:13463, 1 commit, 1 file changed)
  • AndroidStorageProvider: Fix fsok logic (PR:13480, 1 commit, 1 file changed)
  • Update README.raspberrypi to default to release builds (#13327) (0edaa82)
pvr.mediaportal.tvserver:
  • New setting for the default keepmethod of new recording timers (PR:82, 1 commit, 6 files changed)
Includes latest addons: inputstream.adaptive (b28d3f0), inputstream.rtmp (b3ffc49), peripheral.joystick (7f2f2eb), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (386c6c1, +1), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
Horrible stuttering in Live TV when using a tvheadend backend (using pvr.hts) that doesn’t appear when using Kodi 17 & stable pvr.hts.
17.8-174, 8 Feb 2018: Based off OSMC commit (88c5b8b4) and xbmc (c45a8bf7)
]XBMC:
  • VideoPlayer: OpenGL - do colorspace conversion in linear RGB (PR:13481, 2 commits, 10 files changed)
  • Exit (PR:13483, 1 commit, 1 file changed)
  • [win32]Fix env vars out of sync in debug mode regression (PR:13490, 1 commit, 1 file changed)
  • FIX: [droid] proper handling of HDMI on/off broadcasts (PR:13487, 1 commit, 2 files changed)
  • fixed: return actual position for seek in file cache (PR:13488, 1 commit, 1 file changed)
  • changed: drop XbmcThread::NonCopyable (PR:13489, 1 commit, 4 files changed)
    [*][doxy] add missing docs and adjust docs in GUIInfoManager (PR:13467, 2 commits, 1 file changed)
Includes latest addons: inputstream.adaptive (b28d3f0), inputstream.rtmp (b3ffc49), peripheral.joystick (7f2f2eb), pvr.argustv (a4d3ec7), pvr.demo (8f62053, +1), pvr.dvblink (89d1687, +1), pvr.dvbviewer (64c4356, +1), pvr.filmon (2721611, +1), pvr.hdhomerun (7379fbc), pvr.hts (095784b, +1), pvr.iptvsimple (933a5c4, +1), pvr.mediaportal.tvserver (dec444f, +2), pvr.mythtv (3200b09), pvr.nextpvr (aa1c8d2, +1), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f, +1), pvr.stalker (77eec69, +1), pvr.teleboy (3ae0297), pvr.vbox (57f3198, +1), pvr.vdr.vnsi (4db947c), pvr.vuplus (f05f158, +1), pvr.wmc (38e670a, +1), pvr.zattoo (3c46173, +1), vfs.libarchive (3ad25b3, +1)
@Psycho
TVHeadend backend (Synology NAS) & TVHeadend-Frontend (Kodi Leia) are working flawlessly (incl. timeshift) on my Vero 4K.
No problems on my configuration.
It’s so strange, I had the same behaviour when Kodi 17 was in alpha stage, horrible stuttering using pvr.hts with a TVheadend backend runing on my Arch server. When Kodi 17 reached final status, suddenly PVR started to play flawlessly. Now I have the same situation with Kodi 18 Alpha…
17.8-175, 11 Feb 2018: Based off OSMC commit (d43d41bb7) and xbmc (8c7f8bd3a4)a
XBMC:
  • [VideoPlayer] DXVA: fixed wrong surface format for 10bits videos and (PR:13506, 1 commit, 2 files changed)
  • [depends][configure] unify android & linux (PR:13505, 4 commits, 65 files changed)
  • Games: Mouse remapping support (PR:13482, 13 commits, 90 files changed)
  • VideoPlayer: rewrite yuv to rgb conversion for DirectX (PR:13500, 6 commits, 15 files changed)
  • [windows] use ComPtr instead of raw pointers. (PR:13501, 4 commits, 11 files changed)
  • [estuary] missing addon icons (PR:13498, 1 commit, 2 files changed)
  • changed: quell terminal spew in JpegParse (PR:13496, 2 commits, 2 files changed)
  • changed: remove .rar|.cbr from default video/music/image extensions (PR:13494, 1 commit, 1 file changed)
  • AMLUtils: simplify resolution parsing, add VESA modes parsing (PR:13432, 0 commits, 0 files changed)
  • RetroPlayer: Update OpenGL/ES Renderers and use RGB565 (PR:13497, 6 commits, 7 files changed)
peripheral.joystick:
  • Peripheral API v1.3.7: Mouse mapping support
Includes latest addons: inputstream.adaptive (b28d3f0), inputstream.rtmp (b3ffc49), peripheral.joystick (02da6ed, +4), pvr.argustv (a4d3ec7), pvr.demo (8f62053, +1), pvr.dvblink (89d1687, +1), pvr.dvbviewer (64c4356, +1), pvr.filmon (2721611, +1), pvr.hdhomerun (7379fbc), pvr.hts (095784b, +1), pvr.iptvsimple (933a5c4, +1), pvr.mediaportal.tvserver (dec444f, +2), pvr.mythtv (3200b09), pvr.nextpvr (aa1c8d2, +1), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f, +1), pvr.stalker (77eec69, +1), pvr.teleboy (3ae0297), pvr.vbox (57f3198, +1), pvr.vdr.vnsi (4db947c), pvr.vuplus (f05f158, +1), pvr.wmc (38e670a, +1), pvr.zattoo (3c46173, +1), vfs.libarchive (128394c, +3)
17.8-176, 12 Feb 2018: Based off OSMC commit (8d392666e) and xbmc (7a26fb4)
OSMC
  • Remove do-not-discard-buttons-in-repeat-mode patch. Applied upstream (3ed3702f7)
  • Remove configure-cec-repeats patch. Applied upstream (c89ffc8)
XBMC:
  • AddonSettings: Protect against nullptr (PR:12522, 1 commit, 1 file changed)
  • [PVR] Ensure larger objects are heap allocated to avoid stack overflows. (PR:13522, 1 commit, 2 files changed)
  • X11: add fallback for OpenGL legacy (PR:13528, 1 commit, 1 file changed)
  • [Music]Fix Container.Art for collaboration albums (PR:13491, 1 commit, 1 file changed)
  • [libdvd] latest versions libdvdcss 1.4.1 libdvdread/libdvdnav 6.0.0 (PR:13524, 1 commit, 3 files changed)
  • [xbmc][fix] Fix problematic format strings. (PR:13529, 1 commit, 3 files changed)
Includes latest addons: inputstream.adaptive (b28d3f0), inputstream.rtmp (b3ffc49), peripheral.joystick (02da6ed, +4), pvr.argustv (a4d3ec7), pvr.demo (8f62053, +1), pvr.dvblink (89d1687, +1), pvr.dvbviewer (64c4356, +1), pvr.filmon(2721611, +1), pvr.hdhomerun (7379fbc), pvr.hts (095784b, +1), pvr.iptvsimple (933a5c4, +1), pvr.mediaportal.tvserver (dec444f, +2), pvr.mythtv (3200b09), pvr.nextpvr (aa1c8d2, +1), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv(5b47d9f, +1), pvr.stalker (77eec69, +1), pvr.teleboy (3ae0297), pvr.vbox (57f3198, +1), pvr.vdr.vnsi (4db947c), pvr.vuplus (f05f158, +1), pvr.wmc (38e670a, +1), pvr.zattoo (3c46173, +1), vfs.libarchive (128394c, +3)
17.8-177, 16 Feb 2018: Based off OSMC commit (b340ead91) and xbmc (54b1d5a)
OSMC
  • Include addon game.libretro.scummvm
XBMC:
  • [uPnP] Content-Disposition Header (PR:13520, 1 commit, 1 file changed)
  • FreeBSD fixes (PR:13532, 8 commits, 19 files changed)
  • FIX: [3D;win] initialize 3D flags in renderer (PR:13543, 1 commit, 1 file changed)
  • [cleanup] FreeBSD 8 is EOL & move FreeBSDGNUReplacements include (PR:13544, 2 commits, 4 files changed)
  • DVDVideoCodecAmlogic: remove pts-based frame rate tracking (PR:13539, 2 commits, 2 files changed)
  • [cleanup][windows] remove system.h defines & includes (PR:13545, 4 commits, 31 files changed)
  • [wayland] Move EGL context attribs to winsys context, add GL fallback (PR:13527, 1 commit, 9 files changed)
Includes:
  • [Game API] Update to v1.0.36: Controller topology (#13499)
