Thanks for this suggestion. I did tap on a couple of the entries in the white list to see if I was supposed to enable/disable any, and I think there may have been a slight change in the grey/white balance of the text, but at a glance I certainly could not see what I’d done afterwards, there is (to my vision), next to no change in the GUI. I would respectfully suggest that if the list is intended for user selection, it will be much easier to offer radio buttons/check boxes next to each one (as Playstation does it I think). That way the GUI is robust if the display does not differentiate well or the person doing the set up has any kind of impaired colour vision. I think I came across the same issue somewhere in the TV timer record part of the GUI, where there is a reliance on being able to distinguish between brightness gradings that not everyone can perceive. Well-designed GUI’s would not have that issue.
In my case all resolutions were disabled by default. You have to press OK after you have made the selection.
Why would this additional complexity be introduced for default configuration? Surely all the resolutions reported via the initial handshaking between the Vero and its connected device should be enabled by default?
As noted above, I can’t easily distinguish which ones are selected and which ones are not as the grading difference is not easy for me to perceive. If there were check boxes it would be obvious, regardless of impaired colour vision. The toggling of Selected status should not rely soley on text colour for any GUI element, I’d respectfully advise.
17.8-255, 23 June 2018: Based off OSMC commit (17b13a9d) and xbmc (37d0c49)
OSMC:
- Re-add pvr.mediaportal.tvserver, pvr.demo, pvr.iptvsimple
- Temp removal of 17b13a9d due to build issues
XBMC:
- Implement SDK21 AudioTrack constructor (PR:14081, 2 commits, 3 files changed)
- bump to v18 alpha3 (PR:14010, 1 commit, 1 file changed)
- [Music]Sources filtering ignore drives without paths (PR:14082, 1 commit, 3 files changed)
pvr.vuplus:
- PVR API 5.10.1 (PR:88, 1 commit, 3 files changed)
pvr.zattoo:
- Fix error when no recordings are available (eb56bef)
Includes latest addons: inputstream.adaptive (d89b547), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (eb56bef, +2), vfs.libarchive (84a4876)
17.8-256, 25 June 2018: Based off OSMC commit (4a066764) and xbmc (cf5ffab67)
OSMC:
- Re-add vfs.libarchive
XBMC:
- [Estouchy] add subtitle settings button (PR:14065, 1 commit, 2 files changed)
- [Estuary] assign unique id to the TouchBackButton (PR:14027, 1 commit, 1 file changed)
- Gbm code improvements (PR:14096, 6 commits, 11 files changed)
pvr.zattoo:
- Store app token in case it cannot be fetched from Zattoo (baeb316)
Includes latest addons: inputstream.adaptive (4db421d, +2), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629), pvr.filmon(b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv(d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
17.8-257, 26 June 2018: Based off OSMC commit (b4efdcc2) and xbmc (6973010)
XBMC:
- VideoPlayer: opengl - fix color range of subtitle textures (PR:14105, 1 commit, 4 files changed)
- Add required package names (PR:14098, 1 commit, 1 file changed)
- [dns-cache] Only use nmblookup if HAS_SMBCLIENT (PR:14024, 1 commit, 1 file changed)
- [Estuary] increase space for sysinfo (PR:14100, 1 commit, 3 files changed)
inputstream.adaptive:
- Allow Rep::BaseUrl for templated AdpSets (ef3cefb)
- [HLS] Add stream name / [All] media renewal URL (d19c7d3)
- [HLS] share parameters between master / sub playlists (298366e)
pvr.dvbviewer:
- Show an error if timeshift buffer path does not exist (f9e1290)
- Remove redundant IsTimeshiftBufferPathValid check (361e162)
- Timers: -1 is no valid priority value. Pass default priority instead. (1bf5aaa)
- Timers: Only pass default priority if backend doesn’t do it on its own (0e55f2c)
- Only load autotimers if backend supports it (aae288a)
- Also log the backend version in dot-format (5432b84)
- Bump version to 3.6.2 (fccf48a)
Includes latest addons: inputstream.adaptive (298366e, +4), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo(481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
17.8-258, 27 June 2018: Based off OSMC commit (ad5224d6) and xbmc (0910789)
XBMC:
- VideoPlayer: inputStreamAddon fix interface IsRealtime (PR:14110, 1 commit, 2 files changed)
[*][infoscanner] ensure we’re only checking for .nomedia in folders (fixes #17651) (PR:13088, 1 commit, 4 files changed) - windowing/gbm: allow different gui and screen size (PR:14108, 4 commits, 7 files changed)
- [PVR][Log] Introduce component based logging for PVR and EPG. (PR:14112, 1 commit, 29 files changed)
pvr.vbox:
- Fix recordings playback not working (was broken since v4.2.0). (PR:210, 1 commit, 3 files changed)
Includes latest addons: inputstream.adaptive (ef3cefb, +5), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo(baeb316, +3), vfs.libarchive (1bc1517, +1)
17.8-259, 28 June 2018: Based off OSMC commit (ad5224d6) and xbmc (0910789)
OSMC Skin (17.9.3-4):
- Swap default state of highlight option (69ce4fe2)
- Fix addon bold representation (570b02c)
- Fix weather section (10c44d)
- Bug fix 2.0 (fec1dc)
- New highlighting options (5834fab5)
- Fix orientation in game dialogs (e0e8798)
- Fix game dialog animation (b07a07)
- Fix Game dialogs (62b7f67)
- Finalizing Games section (77ced1)
- Games widget (edeb7f)
- Finalize game OSD (493838)
- Adjust hideo video player OSD option (df875ece)
- Hide unwatched preview art of unwatched episodes (7d21dec)
XBMC:
- [CURL] Rework failonerror (PR:14114, 1 commit, 2 files changed)
- windowing/gbm: use connector with a valid encoder (PR:14116, 1 commit, 1 file changed)
- [docs] remove instructions for obsolete Ubuntu versions (PR:14117, 1 commit, 1 file changed)
- allow reading build date from a BUILDDATE file (PR:14115, 1 commit, 1 file changed)
Includes latest addons: inputstream.adaptive (ef3cefb, +5), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon(b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv(d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
17.8-260, 29 June 2018: Based off OSMC commit (f80d0b8b09) and xbmc (254e7f9)
OSMC Skin (17.9.3-5):
- Bug fix(dd48640)
XBMC:
- [cmake] always build with -Wall (PR:14107, 1 commit, 1 file changed)
- filesystem: SpecialProtocol - fix possible endless recursion in URIUt (PR:14121, 1 commit, 1 file changed)
- Rework for renewal after HTTP 403 / kodi api changes (560728d)
- Version bump 2.2.24 (16a404)
Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo(481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (6f01a4b, +3), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo(baeb316, +3), vfs.libarchive (1bc1517, +1)
17.8-261, 30 June 2018: Based off OSMC commit (fbb8c0a6d) and xbmc (b02d4308)
XBMC:
- [Skin] add DefaultMusicSources icon (PR:14126, 1 commit, 2 files changed)
- [Estuary] Add setting to show profilename (PR:14007, 1 commit, 4 files changed)
- Estuary fixes (PR:14099, 3 commits, 3 files changed)
- [linux] windowing/gbm: plane selection rework (PR:14113, 4 commits, 7 files changed)
- Settings: GBM - hide “Display mode” setting (PR:14120, 1 commit, 1 file changed)
17.8-262, 1 July 2018: Based off OSMC commit (f0ce05728) and newclock5 (8063088)
XBMC:
- AESinkPULSE: Fix enumeration callback (PR:14133, 1 commit, 1 file changed)
- Fix ocassional playback in background (PR:14130, 1 commit, 1 file changed)
- VideoPlayer: fixes for discarding streams (PR:14127, 1 commit, 2 files changed)
17.8-263, 2 July 2018: Based off OSMC commit (b808eb2) and xbmc (17459bb)
XBMC:
- VideoPlayer: handle tempo and realtime dynamically (PR:14134, 2 commits, 11 files changed)
- allow selecting resolutions with non standard aspect ratio (PR:14132, 1 commit, 5 files changed)
Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon(b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (6f01a4b, +3), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv(d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
17.8-264, 3 July 2018: Based off OSMC commit (b808eb2) and xbmc (a44e6e26a)
XBMC:
- Fix segfault on shutdown caused by busy python addons (PR:14138, 1 commit, 3 files changed)
- RetroPlayer: Fix segfault on subsequent failure (PR:14101, 1 commit, 1 file changed)
- [lang][kodi.core] automatic syntax corrections for the en_GB language file (2656577)
- [lang][skin.estuary] automatic syntax corrections for the en_GB language file (39f9bd5)
- [lang][skin.estuary] updated language files from Transifex (e66ca5d)
pvr.dvblink:
- [lang] updated language files from Transifex (c66203b)
pvr.dvbviewer:
- [lang] automatic syntax corrections for the en_GB language file (4c60fc2)
- [lang] updated language files from Transifex (89344b4)
pvr.filmon:
- [lang] updated language files from Transifex (93ae10d)
pvr.hdhomerun:
- [lang] updated language files from Transifex (ced70bd)
pvr.hts:
- [lang] automatic syntax corrections for the en_GB language file (7500796)
- [lang] updated language files from Transifex (83451d3)
pvr.iptvsimple:
- [lang] updated language files from Transifex (c721c03)
pvr.mediaportal.tvserver:
- [lang] updated language files from Transifex (6439be6)
pvr.mythtv:
- [lang] updated language files from Transifex (3a04d2c)
- [lang] updated language files from Transifex (c9a14a7)
- [lang] updated language files from Transifex (6a0f2a2)
- [lang] updated language files from Transifex (f0f7e6d)
- bump version 5.8.1 (c4d8899)
pvr.nextpvr:
- [lang] updated language files from Transifex (6f0515b)
pvr.pctv:
- [lang] updated language files from Transifex (32d4b66)
pvr.stalker:
- [lang] updated language files from Transifex (6026419)
pvr.vbox:
- [lang] updated language files from Transifex (325774b)
pvr.vuplus:
- [lang] updated language files from Transifex (75179a3)
pvr.wmc:
- [lang] updated language files from Transifex (ec652db)
Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo(481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple(c721c03, +2), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv(32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (325774b, +2), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
17.8-265, 5 July 2018: Based off OSMC commit (11f0dc837) and xbmc (f2f48c95d)
XBMC:
- [gui][pvr][fix] Prevent the modification of the provider list while using its iterator. (PR:14139, 1 commit, 2 files changed)
- [modernize] use default member initializers (PR:14111, 30 commits, 300 files changed)
- reusepython off by default (PR:14136, 1 commit, 1 file changed)
- Kodi’s new and improved git docs (PR:14072, 27 commits, 72 files changed)
pvr.vbox:
- Fixed wrong size caused crash in Android Oreo (8) (#211) (48a1ac1)
Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon(93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple (c721c03, +2), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (48a1ac1, +3), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
I think there is something broken in the latest builds. When I press ‘pause’ in Chorus and want to resume again, the movie actually resumes but state in Chorus doesn´t change. Refreshing the webpage manually shows the correct state. Some http problems again? It is quite imporant to me because I need the ‘playState’ in order to execute commands to my LED stripes in my room. Can someone reproduce that issue in Chorus?
When did this start?
Usually Kodi issues are resolved promptly in nightlies, so stay tuned.
Can´t tell exactly because I rebuild my Fhem setup from scratch, this took me a while. Need to look at log-files today…
17.8-266, 6 July 2018: Based off OSMC commit (db535d6b) and xbmc (f2f48c95)
OSMC:
- Added vfs.sftp addon
- [MPD] check MPS::type==dynamic for LIVE streams (aa6c3f4)
pvr.iptvsimple:
- Add support for #EXT-X-PLAYLIST-TYPE in M3U (PR:189, 1 commit, 4 files changed)
Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon(93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple (c721c03, +2), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (48a1ac1, +3), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1), vfs.sftp (ac78185)
gmc, can you reproduce this Chorus bug? This needs a fix very soon.
With the latest update I’m kept in bootloop. I’m not able to enable debug mode and create logs in the graphic interface. How can I it via console?
