I know, no complaining
I just want to let you guys know.
This may have been asked elsewhere, if so I apologise in advance as I couldnât find it. Is it possible to run the Vero 4K KODI 18 alpha build from an SD card for testing?
Unfortunately this isnât possible.
17.8-243, 8 June 2018: Based off OSMC commit (5d559cd) and xbmc (f14936128)
OSMC:
- Temp remove game.libretro.mame, steamcontroller due to build issues
XBMC:
- windowing/gbm: set fullscreen flag and other small fixes (PR:13977, 4 commits, 8 files changed)
- [guiinfo] Fix after 2cef6e4 - skin.string label broken (PR:13981, 1 commit, 3 files changed)
- [tools] win32: build ffmpeg with openssl instead of schannel (PR:13979, 1 commit, 1 file changed)
inputstream.adaptive:
- Dont skip behind Now on live streams (1962cfd)
- log / fail on kNoKey DRM Error (6a1a765)
- [HLS] Fix url base path retrieval (02b3197)
- Version bump 2.2.21 (765cf22)
Includes latest addons: inputstream.adaptive (765cf22, +4), inputstream.rtmp (b8e3f39), peripheral.joystick (80224e1), pvr.argustv (2bce465), pvr.demo (20d81d8), pvr.dvblink (a87258b), pvr.dvbviewer (884b732), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (4f7196d), pvr.iptvsimple (e220777), pvr.mediaportal.tvserver (c4e32b0), pvr.mythtv (9d15025), pvr.nextpvr (78a80de), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (17c1897), pvr.stalker (0700069), pvr.teleboy (3e9e537), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (6c94eec), pvr.wmc (a7ec576), pvr.zattoo (73891b1, +1), vfs.libarchive (84a4876)
The app store appears to be broken. TVheadend highlighted. Canât scroll or select other apps.
Will look in to this
17.8-244, 11 June 2018: Based off OSMC commit (76116c1db) and xbmc (04ff6408)
XBMC:
- Games window: Fix error playing standalone cores (PR:13989, 1 commit, 1 file changed)
- Games: Fix standalone games creating savestate files in app dir (PR:13990, 1 commit, 2 files changed)
- Various copy operator optimizations (and several small cleanups) (PR:14005, 8 commits, 7 files changed)
- [PVR] Addon API 5.10.0: New API function GetStreamReadChunkSize. (PR:14002, 1 commit, 9 files changed)
- Do not use CURL::proxy for localhost (PR:13995, 1 commit, 1 file changed)
- [c-pluff] kill another implicit function declaration warning (PR:13998, 1 commit, 2 files changed)
- kodi-send: Add option to send a key press event (PR:13804, 4 commits, 1 file changed)
- CHelper_libXBMC_addon: Avoid buffer overflow in Log (PR:13984, 1 commit, 1 file changed)
- Log redacted URL in case of CURL failure (PR:13997, 1 commit, 1 file changed)
- [PVR] Addon API documentation cleanup (PR:14000, 3 commits, 6 files changed)
- [videoplayer] DVDDemux::GetStreamType(): Add more codecs and channel (PR:13965, 2 commits, 3 files changed)
- Small GBM code cleanups (PR:13985, 6 commits, 7 files changed)
- [JSON]Music library âlastupdatedâ property (PR:13969, 2 commits, 6 files changed)
- RetroPlayer: Add stream abstraction (PR:13976, 4 commits, 45 files changed)
- Add cryptoSession when comparing hints (DVDStreamInfo) (PR:13982, 0 commits, 0 files changed)
- Add CGUIViewStateFromItems::AutoPlay feature for Videos (PR:13980, 0 commits, 0 files changed)
- utils/Geometry: add âconstexprâ (PR:13918, 1 commit, 1 file changed)
- More include cleanups (PR:13950, 5 commits, 16 files changed)
- eventclients paths (PR:13957, 4 commits, 12 files changed)
- RetroPlayer: Fix memory leak on Windows (PR:13999, 1 commit, 1 file changed)
- Rename GL_INTERFACE to KODIGL_INTERFACE (PR:13700, 3 commits, 8 files changed)
- [addons] implement path attribute (PR:13991, 1 commit, 2 files changed)
- Refine Video::Autoplay options (PR:13992, 1 commit, 12 files changed)
- GUIDialogSubtitles: close SUBTITLE_OSD_SETTINGS after a subtitle download (PR:13975, 1 commit, 4 files changed)
- Clear EDL when opening a new FileItem (PR:13996, 1 commit, 1 file changed)
peripheral.joystick:
- Add NDO SW Pro Controller and 8bitdo NES30 Arcade (PR:145, 1 commit, 2 files changed)
pvr.argustv:
- PVR API 5.10.0 (PR:80, 1 commit, 3 files changed)
pvr.demo:
- PVR API 5.10.0 (PR:62, 1 commit, 2 files changed)
pvr.dvblink:
- PVR API 5.10.0 (PR:103, 1 commit, 3 files changed)
pvr.dvbviewer:
- PVR API 5.10.0 (PR:73, 1 commit, 3 files changed)
pvr.filmon:
- PVR API 5.10.0 (PR:83, 1 commit, 3 files changed)
pvr.hdhomerun:
- PVR API 5.10.0 (PR:78, 1 commit, 3 files changed)
pvr.hts:
- PVR Addon API 5.10.0: Implement stream read chunk size as addon setting. (PR:366, 1 commit, 7 files changed)
pvr.iptvsimple:
- PVR API 5.10.0 (PR:186, 1 commit, 3 files changed)
pvr.mediaportal.tvserver:
- PVR API 5.10.0 (PR:87, 1 commit, 3 files changed)
pvr.mythtv:
- PVR API 5.10.0 (PR:100, 1 commit, 3 files changed)
pvr.nextpvr:
- PVR API 5.10.0 (PR:74, 1 commit, 3 files changed)
pvr.njoy:
- PVR API 5.10.0 (PR:47, 1 commit, 3 files changed)
pvr.octonet:
- PVR API 5.10.0 (1e44819)
pvr.pctv:
- PVR API 5.10.0 (PR:59, 1 commit, 3 files changed)
pvr.stalker:
- PVR API 5.10.0 (PR:113, 1 commit, 3 files changed)
pvr.teleboy:
- PVR API 5.10.0 (PR:10, 1 commit, 3 files changed)
pvr.vbox:
*] PVR API 5.10.0 (PR:209, 1 commit, 3 files changed)
pvr.vdr.vnsi:
- add chunk size for recordings (PR:16, 3 commits, 6 files changed)
pvr.vuplus:
pvr.wmc:
- PVR API 5.10.0 (PR:62, 1 commit, 4 files changed)
pvr.zattoo:
- PVR API 5.10.0 (PR:19, 1 commit, 3 files changed)
- Login v2 (PR:20, 4 commits, 4 files changed)
- New settings version (prevent log spam / hidden setting value for widevine_api (a401504)
Includes latest addons: inputstream.adaptive (a401504, +5), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745, +1), pvr.argustv (37a3a76, +1), pvr.demo (bcd8289, +1), pvr.dvblink (1732e4b, +1), pvr.dvbviewer (986b1ba, +1), pvr.filmon (ba261c9, +1), pvr.hdhomerun (379c62c, +1), pvr.hts (f569808, +1), pvr.iptvsimple (663040c, +1), pvr.mediaportal.tvserver (01af5a0, +1), pvr.mythtv (c18ca9e, +1), pvr.nextpvr (fad3ca9, +1), pvr.njoy (30743c6, +1), pvr.octonet(1e44819, +1), pvr.pctv (d0c7241, +1), pvr.stalker (00f3fc4, +1), pvr.teleboy (dfa68b0, +1), pvr.vbox (d2e61a9, +1), pvr.vdr.vnsi (18c7474, +3), pvr.vuplus (bcfd34d, +1), pvr.wmc (ce4b47a, +1), pvr.zattoo (4fa0f72, +6), vfs.libarchive (84a4876)
17.8-245, 12 June 2018: Based off OSMC commit (183500893d) and xbmc (44f7cc9)
OSMC:
- Vero4k: Sometimes /sys/class/display/mode can have a second line which is blank. (ba31ca373)
XBMC:
- GUILib cleanups & optimizations & dead code removal (PR:14006, 19 commits, 29 files changed)
- VideoPlayer: vaapi - fix quirk for mesa (PR:14013, 1 commit, 1 file changed)
- Various CMatrixGL optimizations (PR:14014, 22 commits, 19 files changed)
- MMALCodec: Initialise iRepeatPicture (PR:13993, 1 commit, 1 file changed)
- Game OSD: Add âAdvanced settingsâ button to settings list (PR:14008, 1 commit, 16 files changed)
- Version bump 2.2.22 (27ddff1)
pvr.zattoo:
- Fix loading recordings data (286ce5f)
inputstream.adaptive (27ddff1,2),inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo(bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (986b1ba), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker(00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (286ce5f, +1), vfs.libarchive(84a4876)
17.8-246, 13 June 2018: Based off OSMC commit (c77366e3b) and xbmc (14fb994)
XBMC:
- [PVR][VideoPlayer] Rework and simplify DVDInputStreamPVRManager. (PR:14015, 1 commit, 18 files changed)
- Space out order value of library nodes (PR:11017, 1 commit, 79 files changed)
- Header cleanup (PR:14020, 9 commits, 1645 files changed)
- Whitespace (PR:14021, 8 commits, 925 files changed)
- RendererDRMPRIME: release video buffers after flush (PR:13978, 3 commits, 4 files changed)
- [Estuary] Fix header of rating dialog in skin settings (PR:14025, 1 commit, 1 file changed)
- Reusepython (#13814) (57d64c1)
- Version bump 2.2.23 (4705d59)
pvr.zattoo:
- Fix deadlock due to missing mutex.unlock() (e72598d)
Includes latest addons: inputstream.adaptive (4705d59, +4), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo(bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (986b1ba), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker(00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive(84a4876)
17.8-247, 14 June 2018: Based off OSMC commit (4e5de7fd) and newclock5 (2c2146213)
XBMC:
- [PVR] CPVRClients cleanup. (PR:14023, 1 commit, 16 files changed)
- VideoPlayer: correct frame rate for interlaced (PR:14022, 1 commit, 4 files changed)
- CMediaSource cleanup (PR:14032, 3 commits, 2 files changed)
- CStreamDetails code cleanup (PR:14034, 6 commits, 2 files changed)
- Trivial code cleanups in Util.cxx (PR:14004, 5 commits, 5 files changed)
- [PVR] Fix crash in CPVREpg::UpdateFromScraper after 2c09a9ca284cdc9312c3fe39086f65c03fdaf139 (PR:14035, 3 commits, 3 files changed)
- [Music]Filter music items by media source (PR:14012, 5 commits, 27 files changed)
- CURL: Disable FAILONERROR only for Open() calls (PR:14038, 1 commit, 2 files changed)
- Doxygen (PR:14041, 2 commits, 8 files changed)
- Fix Season no. displayed for launcher Channels. (PR:14037, 1 commit, 1 file changed)
- Allow tagging original language using listItemProperty (84df3e6)
- Fix segfault when destructing tree while updating (5756133)
Includes latest addons: inputstream.adaptive (5756133, +6), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo(bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (986b1ba), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker(00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive(84a4876)
17.8-248, 15 June 2018: Based off OSMC commit (a3155aa4) and xbmc (2c2146213)
OSMC:
Vero4k: Fix permissions for brightness and contrast controls. (73d7ed6e1)
XBMC:
- Games: Fix segfault when opening a game (PR:14018, 2 commits, 13 files changed)
- VideoPlayer: ffmpeg - make sure not to return eof as long nothing was added (PR:14040, 1 commit, 2 files change
- Remove unused Rendersystem methods (PR:14031, 2 commits, 9 files changed)
- Display #channels in audio selection list (PR:14042, 1 commit, 2 files changed)
- [GLES] update rendering method to use CPictureBuffer (PR:14029, 4 commits, 5 files changed)
- Do not reuse pvr channel string (PR:14043, 1 commit, 2 files changed)
- center â centre revert / lowercase channels (PR:14044, 1 commit, 1 file changed)
- [cleanup] silence unused variable warning (PR:14045, 1 commit, 1 file changed)
- Cleanup of various virtual destructors (PR:14033, 36 commits, 40 files changed)
pvr.dvbviewer:
- rewrite threaded part of timeshift buffer (327d0a8)
- Make use of default member initializers (e84ce1f)
- appveyor linux builds (b2f0d35)
- remove A600 from maintainers (8ce8055)
- Fix backend info shown in Kodi (1be2b93)
- Fix memleak with GetLocalizedString (4804c1e)
- Fix compile warnings, be more verbose and enable debug builds (45ac9a9)
- This is no unstable software (19276a9)
- Use PVR_STRCPY instead of strncpy (c9502ae)
- Implement auto timers (c413bf8)
- do RelWithDebInfo builds for windows (c723f19)
- AutoTimers: Hardcode default priority (for now) (3894af2)
- Enable autotimer backend version check (1059502)
- AutoTimers: add deduplication properties (6f1044d)
- Remove ifdef guards (29b3f75)
- Add settings class (8bcae0a)
- Move global settings to settings class (c77b831)
- Fix parsing of backend settings (de6f322)
- Bump version to 3.6.0 (f01e52c)
Includes latest addons: inputstream.adaptive (5756133, +6), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (f01e52c, +19), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
17.8-249, 16 June 2018: Based off OSMC commit (72de2ea3) and xbmc (2c2146213)
XBMC:
- RetroPlayer: Add basic resolution changing #98 (72de2ea)
17.8-250 16 June 2018: Based off OSMC commit (b5eb925) and xbmc (2c2146213)
XBMC:
- Misc code cleanups (PR:14046, 3 commits, 3 files changed)
- Game OSD: Add rotation setting (PR:14019, 9 commits, 68 files changed)
- LinuxRendererGLES: consolidate custom renderers (PR:14030, 1 commit, 4 files changed)
- Revert âutils/IXmlDeserializable: drop useless interfaceâ (PR:14049, 1 commit, 5 files changed)
- [cmake] pass vaapi and vdpau options to internal ffmpeg (PR:14017, 2 commits, 3 files changed)
- libinput: check max pointers (PR:14028, 1 commit, 2 files changed)
pvr.dvbviewer:
- AutoTimers: Change deduplication default (600ae4b)
- Bump version to 3.6.1 (d6f1629)
Includes latest addons: inputstream.adaptive (5756133, +6), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629, +21), pvr.filmon(ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker(00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
17.8-251, 17 June 2018: Based off OSMC commit (14ca1dac) and xbmc (2c2146213)
XBMC:
- [vdpau] Fix black screen after pvr channel switch. (PR:14060, 1 commit, 4 files changed)
- Resolution: Fixup GetResolutionFromString (PR:14059, 1 commit, 1 file changed)
- [video] Cleanup and optimize CDVDFileInfo::ExtractThumb. (PR:14061, 1 commit, 3 files changed)
- VideoPlayer: only clear hints of streams on prepare (PR:14057, 1 commit, 1 file changed)
- PAPlayer: fix advancing playlist on error (PR:14055, 1 commit, 2 files changed)
- GUIMediaWindow: prevent from updates while updating (PR:14039, 1 commit, 3 files changed)
- Fix playback of playlists (PR:14054, 2 commits, 2 files changed)
- donât pass cryto to ffmpeg when transcoding (PR:14063, 1 commit, 1 file changed)
17.8-252, 18 June 2018: Based off OSMC commit (103072e1) and xbmc (195491e14)
XBMC:
- [python] browse dialog - list network and/or local paths (PR:11420, 1 commit, 2 files changed)
- LinuxRendererGLES: remove early exit from Flush (PR:14064, 1 commit, 1 file changed)
- Some ActorProtocol cleanup (PR:14047, 9 commits, 2 files changed)
- VideoPlayer: LinuxRendererGL - remove early exit from Flush (PR:14069, 1 commit, 1 file changed)
- Revert âaddons/AddonEvents: remove virtual destructorâ (PR:14073, 2 commits, 1 file changed)
- [Estuary] Added missing setting at SkinSettings.xml (PR:14067, 1 commit, 1 file changed)
Includes latest addons: inputstream.adaptive (5756133, +6), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629, +21), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
17.8-253, 19 June 2018: Based off OSMC commit (a69c89267) and xbmc (42f21e2dc)
XBMC:
- [RetroPlayer] Add basic resolution changing (PR:14053, 2 commits, 3 files changed)
- [RetroPlayer] Adjust game loop (PR:14051, 1 commit, 2 files changed)
- [RetroPlayer] Set AML GPU to ignore alpha channel (PR:14050, 1 commit, 6 files changed)
- [RetroPlayer] Flush/sync audio (PR:14052, 1 commit, 1 file changed)
- [linux][gbm] add RendererDRMPRIMEGLES (PR:14026, 3 commits, 12 files changed)
- added: ListItem.setProperties wrapper for python list items (PR:13952, 1 commit, 2 files changed)
- json-rpc: fix playing URLs with options (PR:14068, 2 commits, 3 files changed)
- [DASH] ensure startPTS gets not < 0 during initialization (d89b547)
Includes latest addons: inputstream.adaptive (d89b547, +7), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629, +21), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
An update to my situation. Now my Logitech remote doesnât work at all. The last build I was using was 240. Original remote still works fine
17.8-254, 22 June 2018: Based off OSMC commit (35ea64ddc) and xbmc (4c0a23e9)
OSMC:
- Temp removal of pvr.mediaportal.tvserver, pvr.demo, pvr.iptvsimple due to build issues
XBMC:
- RendererDRMPRIME: use ServiceBroker to get WinSystem (PR:14062, 2 commits, 3 files changed)
- Fix unsafe usage of last invoker thread (PR:14087, 1 commit, 1 file changed)
- changed: remove internal sftp support (PR:12005, 1 commit, 39 files changed)
- [pvr] PVR Addon API 5.10.1: Add PVR_STREAM_PROPERTY_ISREALTIMESTREAM. (PR:14086, 1 ommit, 3 files changed)
- AE: add a switch to signal that streaming will continue (PR:14085, 1 commit, 8 files changed)
- OMXAudio: Fixup after FreeStream change (PR:14088, 1 commit, 1 file changed)
- Fix event server keypress input processing so correct CKey creator called (#14084) (29a455e)
pvr.demo:
- PVR API 5.10.1 (PR:63, 1 commit, 2 files changed)
pvr.filmon:
- PVR API 5.10.1 (PR:84, 1 commit, 3 files changed)
pvr.hdhomerun:
- PVR API 5.10.1 (PR:79, 1 commit, 3 files changed)
pvr.njoy:
- PVR API 5.10.1 (PR:48, 1 commit, 3 files changed)
pvr.pctv:
- PVR API 5.10.1 (PR:60, 1 commit, 3 files changed)
pvr.stalker:
- PVR API 5.10.1 (PR:114, 1 commit, 3 files changed)
pvr.teleboy:
- PVR API 5.10.1 (PR:11, 1 commit, 3 files changed)
pvr.zattoo:
- PVR API 5.10.1 (PR:22, 1 commit, 3 files changed)
Includes latest addons: inputstream.adaptive (d89b547), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (84981bb, +1), vfs.libarchive (84a4876)
Installed latest test build of Kodi 18 today, all went well, but frame-rate switching was completely broken - could not get frame-rate switching to work for any source file or live TV source via my TV Headend server. Powered down, checked all obvious settings, the âwhite listâ looked good, nothing. All material plays at the frame rate in the display settings for the GUI.
Reverted to 17.6 and all is well. The Vero is connected to a Marantz NR1603 receiver.
@ac16161 Did you select resolutions and frame rates you need from the white list? I had the same problem and âwhite listingâ solved the problem.
