[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
Somewhere in the last several test builds I lost the ability to play any 4k content… i just get no signal. Non 4k still works fine.
I see errors in the kodi logs setting scale_width and height:
11:54:21.795 T:4068132400  NOTICE: Display resolution ADJUST : 4096x2160 @ 23.98 - Full Screen (36) (weight: 0.000)
11:54:22.044 T:4068132400  NOTICE: VideoPlayer: OnLostDisplay received
11:54:22.285 T:4068132400   ERROR: SetInt: error writing /sys/class/graphics/fb0/scale_width
11:54:22.285 T:4068132400   ERROR: SetInt: error writing /sys/class/graphics/fb0/scale_height
Anyone else having issue with 4k in the last week or so?
could it be that the modes aren’t whitelisted in Leia?
Settings->System->Display->Whitelist
Mark the modes you want available
Thanks but no - I had them all set already.
Its more than just the res too, basically i don’t seem to get any hdmi signal (neither projector or amp show anything being sent i.e. audio shows no signal either)
Full logs:
http://paste.osmc.tv/ohoweluvep
17.8-269, 8 July 2018: Based off OSMC commit (06033b7f) and xbmc (2a76746)
XBMC:
  • RetroPlayer: Zero-copy support (PR:14149, 4 commits, 34 files changed)
  • [cleanup] silence compiler warnings (PR:14159, 4 commits, 12 files changed)
  • move activating OSD to GUIWindowFullScreen (PR:14158, 1 commit, 3 files changed)
pvr.zattoo:
  • Enable replay also for hls streams (12134c8)
Includes latest addons: inputstream.adaptive (faf22f1, +9), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple (55637c8, +3), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (48a1ac1, +3), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo(12134c8, +4), vfs.libarchive (1bc1517, +1)
Further to my issue with 4k content no longer playing - also determined that DTS-X soundtracks on 1080p also broken.
I downgraded to version 17.8-261 of the test package - and all is well again.
So something has changed in the Leia test build between end of June and now that has broken this. If i get time, i’ll try and go through each build from then until now and work out which one it was.
17.8-270, 9 July 2018: Based off OSMC commit (74e8888c) and xbmc (2f216c5)
XBMC:
  • fix mimetype of items expanded from playlists (PR:14162, 1 commit, 1 file changed)
pvr.dvbviewer:
  • [lang] updated language files from Transifex (75e2447)
pvr.hts:
  • [lang] updated language files from Transifex (306fac5)
pvr.vbox:
  • Bumped version to 4.4.3 (#213) (12e1304)
Includes latest addons: inputstream.adaptive (faf22f1, +9), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (75e2447, +10), pvr.filmon(93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (306fac5, +3), pvr.iptvsimple (55637c8, +3), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (12e1304, +4), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (12134c8, +4), vfs.libarchive (1bc1517, +1), vfs.sftp
17.8-271, July 2018: Based off OSMC commit (bc2aaee) and xbmc (4fa90ff9)
XBMC:
  • VideoPlayer: demuxerffmpeg - do not discard unknown streams for pvr (PR:14163, 1 commit, 1 file changed)
  • [videoplayer] Teletext: refine fix 714b808 (PR:14164, 1 commit, 2 files changed)
17.8-272, 11 July 2018: Based off OSMC commit (583c8fc2) and xbmc newclock5 (93e34e5a)
XBMC:
  • Fix erratic input when entering cheat code (PR:14161, 1 commit, 4 files changed)
peripheral.joystick:
  • [cocoa] Add libretro mappings for all controllers (PR:146, 1 commit, 1 file changed)
  • Optimize controller transformer memory usage (PR:147, 1 commit, 6 files changed)
17.8-273, 12 July 2018: Based off OSMC commit (583c8fc2) and xbmc (b88fe4c8)
XBMC:
  • Fix Install from zip from addon view (PR:14166, 1 commit, 4 files changed)
17.8-275, 13 July 2018: Based off OSMC commit (93f7db67c) and newclock5 (9182224)
XBMC:
  • AE: fix sync for transcoding (PR:14173, 1 commit, 1 file changed)
17.8-276, 14 July 2018: Based off OSMC commit (f282dd2) and xbmc (b7583e36)
XBMC:
  • Keep protocol options in path databases (PR:14168, 3 commits, 4 files changed)
  • [cleanup] silence useless cast warnings (PR:14177, 28 commits, 104 files changed)
  • AE: fix handling sink errors in suspend state (PR:14179, 1 commit, 1 file changed)
  • X11: egl - make sure that we block in swapBuffers (PR:14178, 1 commit, 2 files changed)
17.8-277, 16 July 2018: Based off OSMC commit (f6aad15a) and xbmc (1d7285221)
XBMC:
  • Add headless modesetting for linux gbm (PR:14125, 1 commit, 8 files changed)
  • [JSON]Faster access to music library (PR:14160, 1 commit, 6 files changed)
  • AESinkPULSE: Don’t deadlock - separate callback handling fixes #17959 (PR:14184, 1 commit, 1 file changed)
17.8-278, 17 July 2018: Based off OSMC commit (1c2df31) and newclock5 (c1baadd)
XBMC:
  • Game Window: XML updates (PR:14167, 5 commits, 8 files changed)
  • [threads] remove const constructor from C(Exclusive|Shared|Single)Lock (PR:14180, 3 commits, 68 files changed)
  • fix PlayMedia builtin playlist handling (PR:14183, 0 commits, 0 files changed)
  • Yet more include cleanups (PR:14036, 6 commits, 12 files changed)
  • Silence some type conversion warnings and fix a possible bug. (PR:14187, 4 commits, 6 files changed)
  • link with libbluray instead of loading it dynamic (PR:13944, 2 commits, 16 files changed)
  • [lang] Uniformize “not available” string usage (PR:14185, 1 commit, 9 files changed)
17.8-279, 18 July 2018: Based off OSMC commit (5d5cec5) and xbmc (bfdaaec4)
XBMC:
  • [videoplayer] Fix “Iterator ‘it’ used after element has been erased”. (PR:14190, 1 commit, 1 file changed)
17.8-280, 18 July 2018: Based off OSMC commit (4c7b5a9) and xbmc (bfdaaec4)
OSMC:
  • Include pvr.sledovanitv.cz addon
17.8-281, 19 July 2018: Based off OSMC commit (7fd21202f) and newclock5 (90720c98)
XBMC:
  • [mir] Drop platform (PR:14186, 1 commit, 18 files changed)
  • Fix “Iterator ‘it’ used after element has been erased”. (PR:14195, 2 commits, 2 files changed)
  • [PVR] Fix deadlock on Kodi startup - trac#15952 (PR:14189, 1 commit, 5 files changed)
  • [guiinfo] Fix ‘Slideshow.File(Name|Path|Size|Date)’ and ‘Slideshow.Index’ labels - trac#17956. (PR:14191, 1 commit, 1 file changed)
  • VideoPlayer: vaapi - fix copy path (PR:14196, 1 commit, 1 file changed)
  • VideoPlayer: fix/improve audio stalls of realtime streams (PR:14193, 2 commits, 2 files changed)
  • Games: Add setting to disable autosave (PR:14169, 3 commits, 12 files changed)
pvr.stalker:
  • Version 3.4.3 : Code cleanup & fix channel playback (PR:118, 2 commits, 6 files changed)
Includes latest addons: inputstream.adaptive (faf22f1), inputstream.rtmp (bf5351e), peripheral.joystick (dbdeded), pvr.sledovanitv.cz, pvr.argustv (37a3a76), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (75e2447), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (306fac5), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (6439be6), pvr.mythtv (c4d8899), pvr.nextpvr (6f0515b), pvr.njoy (30aae48), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (bfb875e, +2), pvr.teleboy (0460536), pvr.vbox (12e1304), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3), pvr.wmc (ec652db), pvr.zattoo (12134c8), vfs.libarchive (1bc1517), vfs.sftp
17.8-282, 20 July 2018: Based off OSMC commit (3f6ddf7b) and newclock5 (db5b866cbd)
XBMC:
  • mdns: add a txt record for http & json services containing ‘uuid’ and ‘txtvers’ (PR:14089, 1 commit, 4 files changed)
  • [gui] Kill g_colorManager (PR:14199, 1 commit, 8 files changed)
  • [bluray] improve bdj check (PR:14202, 1 commit, 1 file changed)
  • VideoPlayer: reset realtime when opening demuxer, some cleanup (PR:14200, 1 commit, 2 files changed)
  • fix videosettings for items not stored in db (PR:14197, 1 commit, 7 files changed)
17.8-283, 22 July 2018: Based off OSMC commit (9df1517) and xbmc (0b8f23abe)
OSMC:
OSMC Skin update (17.9.3-7)
  • Fix bold in view 51 (episode list) (ec68e3)
  • Fix bold in dialogs (aa6026)
  • Skin settings bug fix (4d5d5f)
  • Swap temp/wind in weather (61d91a)
XBMC:
  • [JSON]Fix filtering in GetSongs and GetAlbums (PR:14201, 1 commit, 2 files changed)
  • [PVR] Fix deadlock when removing deleted channels & some code cleanup. (PR:14205, 1 commit, 5 files changed)
  • [RetroPlayer] Configure renderer sooner (PR:14203, 1 commit, 1 file changed)
  • OMXImage: Switch filename to std:tring (PR:14207, 1 commit, 2 files changed)
17.8-284, 23 July 2018: Based off OSMC commit (b7173b06) and newclock5 (64a79f3e)
XBMC:
  • X11: some fixes to OML timings (PR:14211, 1 commit, 1 file changed)
  • FFmpeg: Bump to 4.0.2-Leia-Alpha3 (PR:14212, 1 commit, 1 file changed)
  • X11: implement GetFrameLatencyAdjustment (PR:14213, 1 commit, 5 files changed)
  • GLContextEGL: Adjust sleeptime when detecing missed msc increase (PR:14214, 1 commit, 1 file changed)
Updated today (not the commit from 1h ago) and CEC fails:
https://paste.osmc.tv/digonizome
15:25:42.994 T:3906990832 NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
15:25:43.938 T:3865047792 ERROR: OpenConnection - could not opening a connection to the CEC adapter
Anyone else experiencing this?
