[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
You’re on the staging repository which had some CEC improvements that have caused some regressions.
It will be fixed in the next 24 hours or so
Thx for the fast response. Cheers
17.8-285, 24 July 2018: Based off OSMC commit (e0ff2a4bf) and newclock5 (0a107bac9)
XBMC:
  • Rework FindXkbcommon.cmake (PR:14216, 1 commit, 1 file changed)
  • [database] Reset path hashes when cleaning up files in video database (PR:14165, 1 commit, 1 file changed)
  • [cmake] fix building with internal fmt (PR:14215, 1 commit, 2 files changed)
  • make sure not to delete a CThread object while spawn thread is in pro (PR:13867, 1 commit, 1 file changed)
  • [depends] bump python27 to 2.7.15 (PR:14218, 2 commits, 13 files changed)
peripheral.joystick:
  • .travis.yml: Update for addition of -DADDONS_DEFINITION_DIR (PR:148, 1 commit, 1 file changed)
pvr.vdr.vnsi:
  • add status channel for streaming (PR:17, 2 commits, 7 files changed)
Includes latest addons: inputstream.adaptive (faf22f1), inputstream.rtmp (bf5351e), peripheral.joystick (dbdeded), pvr.sledovanitv.cz, pvr.argustv (37a3a76), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (75e2447), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (306fac5), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (6439be6), pvr.mythtv (c4d8899), pvr.nextpvr (6f0515b), pvr.njoy (30aae48), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (bfb875e, +2), pvr.teleboy (0460536), pvr.vbox (12e1304), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3), pvr.wmc (ec652db), pvr.zattoo (12134c8), vfs.libarchive (1bc1517), vfs.sftp
17.8-286, 27 July 2018: Based off OSMC commit (6e3c26f15) and xbmc (7b63f663)
OSMC:
  • Add build dependency for fstrcmp (6e3c26f15)
XBMC:
  • [VideoLibrary] Do not scan unsupported plugin sources + fix database cleaning (PR:14210, 2 commits, 8 files changed)
  • Use EGLContextUtil in Wayland (PR:13746, 14 commits, 15 files changed)
  • RetroPlayer: Remove width and height state from renderers (PR:14208, 5 commits, 16 files changed)
  • [Subtitles] Background color and background opacity settings (PR:14056, 9 commits, 13 files changed)
  • [JSON]Fix music source handling to match schema (PR:14222, 1 commit, 3 files changed)
  • Updates for addon.xml.in (PR:149, 2 commits, 1 file changed)
peripheral.xarcade:
  • Add Travis CI, Appveyor and Debian packaging files (PR:4, 3 commits, 9 files changed)
  • addon.xml.in: Bump version to 1.1 release (07be227)
Includes latest addons: inputstream.adaptive (faf22f1), inputstream.rtmp (bf5351e), peripheral.joystick (207d433, +3), peripheral.xarcade (07be227, +7), pvr.argustv (37a3a76), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer(75e2447), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (306fac5), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (6439be6), pvr.mythtv (c4d8899), pvr.nextpvr (6f0515b), pvr.njoy (30aae48), pvr.octonet (1e44819), pvr.pctv(32d4b66), pvr.stalker (bfb875e, +2), pvr.teleboy (0460536), pvr.vbox (12e1304), pvr.vdr.vnsi (bb4fb30, +2), pvr.vuplus (75179a3), pvr.wmc (ec652db), pvr.zattoo (12134c8), vfs.libarchive (1bc1517), vfs.sftp, pvr.sledovanitv.cz addon
17.8-287, 27 July 2018: Based off OSMC commit (6e3c26f15) and xbmc (773a396)
XBMC:
  • Do not show busy dialog if progress dialog is active while calling a plugin (PR:14225, 1 commit, 3 files changed)
  • [lang][skin.estuary] updated language files from Transifex (3d30c64)
  • [lang][skin.estouchy] updated language files from Transifex (ce65dc5)
inputstream.adaptive:
  • [TS] ensure / check size of sps/ pps (f700c00)
  • [HLS] use parameter string from master PL only for sub PL, if base_url matches. (f1f16f3)
pvr.argustv:
  • [lang] updated language files from Transifex (1459cea)
pvr.dvbviewer:
  • [lang] updated language files from Transifex (c3ceb0b)
pvr.hts:
  • [lang] updated language files from Transifex (445772d)
pvr.mediaportal.tvserver:
  • [lang] updated language files from Transifex (89cac8b)
pvr.njoy:
  • [lang] updated language files from Transifex (204d95b)
pvr.stalker:
  • [lang] updated language files from Transifex (f84483c)
pvr.vbox:
  • [lang] updated language files from Transifex (c115a14)
pvr.wmc:
  • [lang] updated language files from Transifex (b5fe5a1)
17.8-288, 28 July 2018: Based off OSMC commit (ae1765) and xbmc (773a396)
OSMC:
  • Add libfstrcmp dependency (ae1765f)
  • [HLS] check for base_url when adding parameters in #EXT-X-STREAM-INF, too (48a9928)
  • Compile fix (4e95976)
  • AdaptveTree: relink aadpset in psshset if stream was merged to avoud access to erased adpsets (5061a1a)
pvr.hts:
  • Add setting to ignore duplicate scheduled recordings (tvh4.3+) (PR:370, 2 commits, 9 files changed)
17.8-289, 29 July 2018: Based off OSMC commit (99ee7ad4c) and xbmc (773a396c2)
OSMC:
  • Fix libfstrcmp dependency (99ee7ad4c)
17.8-290, 30 July 2018: Based off OSMC commit (e075c7ed33) and xbmc (743da9ed)
OSMC:
  • Vero 4K: don’t require LPCM option for 7.1 (01105b8b)
  • Vero 4K: separate HRA from MA (333c6a)
XBMC:
  • Fix build on openrisc (PR:14236, 1 commit, 3 files changed)
  • VideoPlayer: frame advance - fix + infobool (PR:14230, 2 commits, 9 files changed)
  • [guiinfo] Fix GUIInfoManager::GetItemImage for non-listitem labels. (PR:14238, 1 commit, 3 files changed)
  • [GUI]Fix window onload control move for music item lists (PR:14241, 1 commit, 1 file changed)
  • [PVR] Guide window: Only sort events item list when actually necessary. (PR:14240, 1 commit, 2 files changed)
17.8-291, 31 July 2018: Based off OSMC commit (9491e9a4) and xbmc (47d7c88)
XBMC:
  • [CUtil] HAS_IRSERVERSUITE is never defined (PR:14246, 1 commit, 1 file changed)
  • [PVR] Guide window: Prevent concurrent updates. (PR:14242, 2 commits, 1 file changed)
  • [mir] Clean up mir platform leftover from PR14186 (PR:14249, 1 commit, 1 file changed)
17.8-292, 1 Aug 2018: Based off OSMC commit (1b88660) and xbmc (e3dd2e4)
XBMC:
  • [docs] doxygen fixes (PR:14243, 2 commits, 1 file changed)
  • [guiinfo] Fix PLAYER_(PATH|FILENAME|FILEPATH). (PR:14239, 1 commit, 5 files changed)
PVR HTS client does not play HD channels properly. I get sound only for a few seconds, then silence and no picture. Do we just report these things here or to Kodi?
Probably best to work out what’s going on first.
Let’s discuss in Slack
17.8-293, 3 Aug 2018: Based off OSMC commit (c7d11f16d6) and xbmc (72da4dab4)
OSMC:
  • Temp remove game.libretro.scummvm due to build issue (2172f93f)
  • Update build script. If osmc-tc doesn’t exist then create before swapon (dd47351)
  • Bug in build script. Fix languages so latest version is always fetched (41e3c25)
XBMC:
  • [depends] bump openssl to 1.1.0h (PR:14226, 3 commits, 4 files changed)
  • VideoPlayer: allow saving video buffers on flush (PR:14253, 1 commit, 16 files changed)
17.8-294, 3 Aug 2018: Based off OSMC commit (a0cd258) and xbmc (ca8e0108d)
XBMC:
  • [fix] check directory implementation for null (PR:14255, 1 commit, 1 file changed)
17.8-295, 5 Aug 2018: Based off OSMC commit (9afb222ba) and newclock5 (59c112e840)
OSMC:
  • Re-add game.libretro.scummvm
XBMC:
  • Small cleanup/improvements (PR:14263, 4 commits, 6 files changed)
17.8-296, 6 Aug 2018: Based off OSMC commit (9afb222ba) and xbmc (439e0c56)
XBMC:
  • Use DBus to delay the triggered system poweroff so that Kodi can shut (PR:14252, 1 commit, 2 files changed)
  • [JSON] Fix for MySQL 8.0 remove brackets from query (PR:14268, 1 commit, 2 files changed)
Blockquote Thanks but no - I had them all set already.
Its more than just the res too, basically i don’t seem to get any hdmi signal (neither projector or amp show anything being sent i.e. audio shows no signal either)
Full logs:
http://paste.osmc.tv/ohoweluvep
So i updated to the latest Alpha 3 level build and also applied the firmware from the July release and this issue reoccurs. None of my 4k content will now play in exactly the same way as before, so I believe log is still valid.
@sam_nazarko - I raised this a while ago when you were on a break and didn’t get an feedback. Which is fair enough, but I hoped it was a side-effect that would be resolved through natural evolution of V18. Would you be able to review?
Kodi v18 is still in its very early stages.
Have you changed rc.local? Do you have HDR auto-switching enabled? Does turning this off help?
17.8-297, 7 Aug 2018: Based off OSMC commit (f3ed349) and xbmc (bc387f8e4)
XBMC:
  • [videoplayer] DVDDemux::GetStreamType(): Add Opus codec string. (PR:14270, 1 commit, 1 file changed)
I get its Alpha - but soon to be Beta…
I use 10bit 444 in rc.local and not hdr auto switching (not reliable for most of my titles)…
I’ve narrowed the issue down to this particular checkin…
17.8-263, 2 July 2018: Based off OSMC commit (b808eb2) and xbmc (17459bb)
If I revert to 262 all works fine (on the latest firmware) - move to 263 or any build since and I get the issue. Looking at the description of the content in 263 - does seem like something that could be the issue.
Update: My theory is that this change is now switching to an invalid resolution for my AVR / Projector combination. I’ll try cutting down the resolution white-list and see if that solves it.
