gmc
8 August 2018 16:56
548
17.8-298, 8 Aug 2018: Based off OSMC commit (aba32674b5 ) and newclock5 (da3ba3b13 )
XBMC:
posix: smb - set chunk size to 64k, fixes ECONNABORT (PR:14272, 1 commit, 1 file changed)
added: mappable action for toggling video streams (PR:14259, 1 commit, 5 files changed)
[Music]Fix export album folder naming and overwrite of single file output (PR:14257, 1 commit, 1 file changed)
VideoPlayer/Amlogic: fix for VC1 seek (PR:14262, 1 commit, 1 file changed)
VideoPlayer/Amlogic: bugfix for InstanceGuard locked (PR:14269, 1 commit, 1 file changed)
update splash to v18.0 beta (PR:14275, 1 commit, 1 file changed)
Coverity fixes (PR:14273, 1 commit, 4 files changed)
Includes latest addons: inputstream.adaptive (faf22f1), inputstream.rtmp (bf5351e), peripheral.joystick (207d433, +3), peripheral.xarcade (07be227, +7), pvr.argustv (37a3a76), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer(75e2447), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (306fac5), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (6439be6), pvr.mythtv (c4d8899), pvr.nextpvr (6f0515b), pvr.njoy (30aae48), pvr.octonet (1e44819), pvr.pctv(32d4b66), pvr.stalker (bfb875e, +2), pvr.teleboy (0460536), pvr.vbox (12e1304), pvr.vdr.vnsi (bb4fb30, +2), pvr.vuplus (75179a3), pvr.wmc (ec652db), pvr.zattoo (12134c8), vfs.libarchive (1bc1517), vfs.sftp, pvr.sledovanitv.cz addon
Update: My theory is that this change is now switching to an invalid resolution for my AVR / Projector combination. I’ll try cutting down the resolution white-list and see if that solves it.
Just in case anyone else suffers this issue. It does seem that the change back in 263 allows Kodi to pick resolutions that your device doesn’t support (at least in my case). By going through the white-list of resolutions and being very prescriptive on what should be allowed, it is now resolved. Can play 4k content again.
gmc
9 August 2018 20:22
550
17.8-299, 9 Aug 2018: Based off OSMC commit (eb4014f6 ) and xbmc (f25baa5fb )
XBMC:
cleanup resolutions, drop resoltion info < RES_WINDOW (PR:14264, 1 commit, 7 files changed)
[VideoDatabase] Improved speed of CVideoDatabase::GetEpisodeId: Only (PR:14267, 1 commit, 2 files changed)
Add default member initialization to code guide lines (PR:14274, 1 commit, 2 files changed)
VideoPlayer: do not reset interlaced (PR:14276, 1 commit, 1 file changed)
[windows] windowing: fix resetting calibration settings. (PR:14279, 1 commit, 2 files changed)
[addons] Update XSD schemas (PR:14237, 20 commits, 14 files changed)
VideoPlayer: WinRenderer - add smooth motion (PR:14278, 1 commit, 2 files changed)
Fix two skin-related crashes (PR:13151, 2 commits, 2 files changed)
[docs] Documentation fixes for built-in functions (PR:14265, 1 commit, 5 files changed)
inputstream.adaptive:
[MPD] Fix live streams with missing timeshiftbuffer length (93efb20)
Version bump 2.2.25 (6bf7802)
pvr.mythtv:
SeekRecordedStream: handle special flag SEEK_POSSIBLE (3bc66ce)
fix seeking ahead: PVR API needs zero when seeking beyond the end (e980f24)
bump version 5.8.2 (4e9d782)
update readme (e61f47c)
gmc
10 August 2018 17:28
551
17.8-230, 10 Aug 2018: Based off OSMC commit (e5627e9f2 ) and xbmc (a82463f )
XBMC:
X11: updates (PR:14280, 2 commits, 10 files changed)
VideoPlayer: blurays - do not read chunked in open_stream path (PR:14277, 1 commit, 5 files changed)
gmc
11 August 2018 19:29
552
17.8-301, 11 Aug 2018: Based off OSMC commit (2970da28 ) and xbmc (c30e66337 )
XBMC:
Fix CApplicationPlayer::GetPercentage() to use new method CDataCacheCore::GetPercentage (PR:14287, 1 commit, 3 files changed)
Fix stream playlists as directory (PR:14284, 2 commits, 1 file changed)
vfs.libarchive:
[depends] download bzip2 from kodi mirrors (PR:20, 1 commit, 1 file changed)
[debian] add missing dependency on libssl-dev (PR:16, 1 commit, 1 file changed)
gmc
13 August 2018 15:35
553
17.8-302, 13 Aug 2018: Based off OSMC commit (28edea1eb ) and xbmc (881a9e6 )
OSMC Skin:
Version 17.9.3-8
Fix highlighting of next-up notification (2d530cd)
XBMC:
Fix GUI sounds not updating when changed (PR:14285, 1 commit, 3 files changed)
Retroplayer: black screen fix for ARGB1555 and some other small changes (PR:14281, 4 commits, 5 files changed)
[docs] Add missing Player infolabels/boolean conditions (PR:14261, 2 commits, 1 file changed)
[Docs] Unescaped comma in Player.PlaySpeed (PR:14289, 1 commit, 1 file changed)
[bluray] Change log messages after the fs callbacks refactoring. (PR:14288, 3 commits, 5 files changed)
[gui] Cosmetic improvements and fixes (PR:14290, 3 commits, 3 files changed)
OpenGL: fix gui fonts for GL version 2.1 (PR:14293, 1 commit, 1 file changed)
Revert "Retroplayer: RenderBufferPoolOpenGLES: use internal format GL (PR:14292, 1 commit, 1 file changed)
pvr.hts:
Demuxer fixes (PR:371, 2 commits, 4 files changed)
gmc
17 August 2018 06:29
554
17.8-303, 17 Aug 2018: Based off OSMC commit (01d18da9 ) and xbmc (a7fef8f13f6 )
OSMC:
Add build of flatbuffers to build script (a7fef8f13f6 )
XBMC:
Fix for (external)player from playercorefactory.xml gets the default (PR:14291, 1 commit, 1 file changed)
addondb: avoid constraint violation (PR:14137, 1 commit, 1 file changed)
VideoPlayer: LinuxRendererGL fixes (PR:14295, 3 commits, 5 files changed)
[TS] collect codec extra data for hevc (036f014)
[DASH] throttle segment wait / fix adaptationset search for updates without id / group (430c440)
gmc
17 August 2018 13:31
555
17.8-304, 17 Aug 2018: Based off OSMC commit (50067215 ) and xbmc (5f77b6d5 )
XBMC:
[json-rpc] Fix playback of pvr channels and pvr recordings - trac#17984. (PR:14301, 1 commit, 2 files changed)
fixed: add missing dependency for retroplayer messages (PR:14297, 1 commit, 1 file changed)
RetroPlayer: Merge savestate metadata into .sav file (PR:14209, 6 commits, 71 files changed)
VideoPlayer: fix video rotation (PR:14298, 2 commits, 3 files changed)
changed: auto-enable disabled add-ons which are dependencies of another (PR:14296, 1 commit, 1 file changed)
pvr.mediaportal.tvserver:
Various updates for v18 (PR:90, 15 commits, 53 files changed)
gmc
19 August 2018 15:56
556
17.8-305, 19 Aug 2018: Based off OSMC commit (2eb65ad ) and xbmc (b2ffb27a )
XBMC:
VideoPlayer / AE: pass downmix info to AE (PR:14312, 1 commit, 20 files changed)
Remove CAnnouncementManager::GetInstance() (PR:14303, 1 commit, 42 files changed)
v18.0 beta2 bump (PR:14314, 1 commit, 1 file changed)
AE: fix audio after 4a8ab6af230b58162f28f5277516a8d53498a647 (PR:14317, 1 commit, 1 file changed)
[docs/README.*] Fix typo in .bashrc export (PR:14310, 2 commits, 6 files changed)
VideoPlayer: fix player states regarding time (PR:14318, 1 commit, 4 files changed)
peripheral.xarcade:
[addon.xml.in] Update URL to wiki (0ccd676)
[README.md] Add link to wiki article (91567dd)
pvr.teleboy:
Fix locking (PR:12, 1 commit, 1 file changed)
Update changelog and version (0f3ccfd)
inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313), pvr.iptvsimple(55637c8), pvr.mediaportal.tvserver (ca4f4db), pvr.mythtv (e61f47c), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0f3ccfd, +2), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441), vfs.sftp (9905037), pvr.sledovanitv.cz
gmc
20 August 2018 18:15
557
17.8-306, 20 Aug 2018: Based off OSMC commit (5ce37b157 ) and xbmc (50d4a65e3 )
XBMC:
[jenkins] fix rebuild detection (PR:14323, 1 commit, 1 file changed)
VideoPlayer: do not create resume bookmarks for content that cannot b (PR:14322, 1 commit, 1 file changed)
VideoPlayer: VDPAU: disable all but 4:2:0 (PR:14324, 1 commit, 1 file changed)
added: manual orientation setting for videos (PR:14311, 1 commit, 7 files changed)
GUIWindowVideoNav.cpp: Fix comparison bug (PR:14321, 1 commit, 1 file changed)
Update to v3.5.5 (PR:91, 3 commits, 7 files changed)
Fix cmake parsing error at AddonHelpers.cmake line 126 due to a missing space (e8b0a9c)
Inacludes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313), pvr.iptvsimple(55637c8), pvr.mediaportal.tvserver (ca4f4db), pvr.mythtv (e61f47c), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0f3ccfd, +2), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441), vfs.sftp (9905037), pvr.sledovanitv.cz
dan
22 August 2018 18:32
558
Im finding that if I adjust settings (video calibration) it doesnt get saved following reboot, is this a bug or am i missing something?
gmc
22 August 2018 20:14
559
Working fine here. Check that guisettings.xml file is not read only. Otherwise you can try stopping mediacenter and renaming kodi. (You will lose any settings/addons you have)
mv /home/osmc/.kodi /home/osmc/.kodi.bak
Failing that post a debug log.
Guys,
I used to play a tv show on my Vero 4k. Since an upgrade, it won’t play anymore. The sound is ok but the video is glitching (purple squares). Like the Vero 4k cannot decode the video. What test can I make and what kind of information do you need to help me?
Might be an issue with a specific nightly, in which case the next build may resolve it. Otherwise some longs will definitely help
I tried reverting back to .299 but it didn’t help. Which log do you need for a problem like that? Note sure if the logs sees that it’s not displaying correctly.
I’m running the same build of Rpi3 and it works.
Yes, I can provide that but the question here is: will the log show anything useful since it’s not crashing, just displaying it wrong on the TV.
Logs are explicitly for debugging issues.
http://paste.osmc.tv/cimovedafe.vhdl
Starts at 10:05:46.969 T:3477074672
This is not a debug enabled log. It also does not contain additional details such as your config settings. The link provided above gives explicit instructions on how to provide useful info/logs.
