That is the debug log (not in the format you wanted). You can see all my configuration, my addons, etc. Even the errors
Debug v2: https://paste.osmc.tv/qadikivefa
MediaInfo: http://paste.osmc.io/amurujeqep.tex
You can see that it used to work (S02E03), then, after an upgrade, S02E04 doesnât work.
10:05:47.081 T:3551105776 DEBUG: CVideoPlayerVideo - video decoder returned error
10:05:47.082 T:3407028976 INFO: CFileCache::Process - Source read didnât return any data! Hit eof(?)
@gmc Probably unlikely but I think I read something about vfs.nfs becoming a binary add-on. If thatâs the case it may explain why the path cannot be resolved (as user isnât using fstab); but then browsing shouldnât be possible; unless invoked from library mode.
Not really following you but I must say that all my other tv shows\movies are working great.
Are you accessing them from the same source (NFS)?
If so â itâs not that.
Next nightly should be out later this evening. Might be a issue thatâs been addressed.
Yep, all from the same source. Iâll try the nightly and let you know.
17.8-307, 23 Aug 2018: Based off OSMC commit (3946275f) and newclock5 (b95aa7e)
XBMC:
- Windowing: GBM - fix window system initialization (PR:14331, 1 commit, 3 files changed)
- [PVR] Fixes for hidden channels (PR:14329, 2 commits, 6 files changed)
- fix some ffmpeg warnings caused by incorrect code (PR:14330, 1 commit, 4 files changed)
- [Estuary] Fix condition for focus on the stop button (PR:14333, 1 commit, 1 file changed)
- AE: adapt to new ffmpeg api - kills warning (PR:14332, 1 commit, 1 file changed)
- Fix compiler warnings (PR:14309, 14 commits, 17 files changed)
- Settings: Remove circular dependency on CPowerManager (PR:14305, 1 commit, 10 files changed)
- [depends] Fix standalone build of flatbuffers with GCC 8.1 (PR:14334, 1 commit, 1 file changed)
- Include cleanup (PR:14336, 4 commits, 4 files changed)
- [depends] bump libfmt to 5.1.0 (PR:14328, 1 commit, 1 file changed)
- kodi-send: restore -a support broken by #13804 (PR:14335, 1 commit, 1 file changed)
vfs.libarchive:
- [depends] update lz4 & xz (PR:23, 3 commits, 7 files changed)
- fixed: do not incorporate the file name in the regular expression (430a8e0)
- fixed: only add actual rar archives for old filename (PR:22, 1 commit, 1 file changed)
vfs.sftp:
- [depends] openssl: build static (PR:17, 1 commit, 1 file changed)
- fixed: we have to call ssh_free on the session, not only disconnect (PR:14, 1 commit, 1 file changed)
Includes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313), pvr.iptvsimple(55637c8), pvr.mediaportal.tvserver (ca4f4db), pvr.mythtv (e61f47c), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0f3ccfd, +2), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441), vfs.sftp (9905037), pvr.sledovanitv.cz
It didnât solve my issue. I even downgraded to .275 and .250 and it does the same thing. Very weird. Could the latest version uninstalled a package required outside of kodi?
Is has to do with Hardware Acceleration. By disabling it (amlogic), it works fine!
17.8-308, 24 Aug 2018: Based off OSMC commit (a8035b1d) and xbmc (964e573)
XBMC:
- [windowing][vp] Fix mouse selection in disc menus. (PR:14338, 1 commit, 1 file changed)
- [videoplayer] Fix dvd resume (PR:14343, 2 commits, 5 files changed)
- [videoplayer] Always report ânot cachingâ while browsing disc menus. (PR:14340, 1 commit, 1 file changed)
17.8-309, 26 Aug 2018: Based off OSMC commit (10736a7db) and xbmc (6854871e)
OSMC:
- Temp removal of game.libretro.beetle-bsnes due to build issues
XBMC:
- VideoPlayer: VDPAU - whitelist AV_PIX_FMT_YUVJ420P (PR:14346, 1 commit, 1 file changed)
17.8-310, 26 Aug 2018: Based off OSMC commit (c29d1e3f) and xbmc (f99b6520)
XBMC:
- âPrefer stereo streams if user has configured 2.0 in AEâ as advanced setting (PR:14348, 1 commit, 3 files changed)
- [estuary] Video OSD: Hide âPreviousâ button for non-seekable streams. (PR:14350, 1 commit, 1 file changed)
- [videoplayer] Refactor some CSelectionStreams methods. (PR:14349, 3 commits, 2 files changed)
pvr.argustv:
- [lang] updated language files from Transifex (c57a5c4)
pvr.dvblink:
- [lang] updated language files from Transifex (72ef8a0)
pvr.dvbviewer:
- [lang] updated language files from Transifex (b63e867)
pvr.hdhomerun:
- [lang] updated language files from Transifex (7a607c9)
pvr.hts:
- [lang] updated language files from Transifex (7c7c6ce)
pvr.iptvsimple:
- [lang] updated language files from Transifex (e8effad)
pvr.mediaportal.tvserver:
- [lang] updated language files from Transifex (cc3eaf0)
pvr.nextpvr:
- [lang] updated language files from Transifex (441edde)
pvr.pctv:
- [lang] updated language files from Transifex (9d95bab)
pvr.stalker:
- [lang] updated language files from Transifex (2eb66d1)
pvr.vbox:
- [lang] updated language files from Transifex (40ca81f)
pvr.vuplus:
- [lang] updated language files from Transifex (016a4ff)
pvr.wmc:
- [lang] updated language files from Transifex (292a819)
inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(c57a5c4, +1), pvr.demo (481f2fa), pvr.dvblink (72ef8a0, +1), pvr.dvbviewer (b63e867, +1), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9, +1), pvr.hts (7c7cf99b6520a75965363efbe70113bd4d15c5dda8db6ce, +1), pvr.iptvsimple (e8effad, +1), pvr.mediaportal.tvserver (cc3eaf0, +5), pvr.mythtv (e61f47c), pvr.nextpvr (441edde, +1), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab, +1), pvr.stalker (2eb66d1, +1), pvr.teleboy (0f3ccfd, +2), pvr.vbox (40ca81f, +1), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff, +1), pvr.wmc(292a819, +1), pvr.zattoo (12134c8), vfs.libarchive (f93a5f3, +5), vfs.sftp (e69acc9, +6), pvr.sledovanitv.cz
17.8-311, 27 Aug 2018: Based off OSMC commit (2cec947e) and xbmc (4e198a9e)
XBMC:
- [pvr][guiinfo][guilib][estuary] PVR timeshift GUI v2. (PR:14316, 6 commits, 27 files changed)
- [libUPnP] fix device discovery on windows (PR:14347, 2 commits, 3 files changed)
- [videoplayer] Fix external vob subs usage. (PR:14353, 1 commit, 2 files changed)
- [depends] bump pcre to 8.42 (PR:14342, 2 commits, 5 files changed)
inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(c57a5c4, +1), pvr.demo (481f2fa), pvr.dvblink (72ef8a0, +1), pvr.dvbviewer (b63e867, +1), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9, +1), pvr.hts (7c7c6ce, +1), pvr.iptvsimple (e8effad, +1), pvr.mediaportal.tvserver (cc3eaf0, +5), pvr.mythtv (e61f47c), pvr.nextpvr (441edde, +1), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab, +1), pvr.stalker (2eb66d1, +1), pvr.teleboy (0f3ccfd, +2), pvr.vbox (40ca81f, +1), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff, +1), pvr.wmc(292a819, +1), pvr.zattoo (12134c8), vfs.libarchive (f93a5f3, +5), vfs.sftp (e69acc9, +6), pvr.sledovanitv.cz
[/list]
17.8-312, 30 Aug 2018: Based off OSMC commit (d7a50cbf) and xbmc (99a83710)
XBMC:
- [videoplayer] Reduce the number of GetSubtitle() calls a bit. (PR:14365, 1 commit, 3 files changed)
- Some minor MMAL improvements (PR:14337, 5 commits, 6 files changed)
- PythonInvoker: fix thread termination check (PR:14356, 1 commit, 1 file changed)
- Fix access to music information from menu and shortcut key (PR:14364, 1 commit, 4 files changed)
- Added PVR.EpgEventIcon guiinfo label (PR:14372, 1 commit, 3 files changed)
- Show EPG image on Dialog Channel Guide (PR:14355, 1 commit, 1 file changed)
- [PVR] OSD: Make seek using mouse working. (PR:14363, 1 commit, 4 files changed)
- [pvr] Persist series link EPG tag attributes to database (PR:14339, 1 commit, 2 files changed)
- [videoplayer] GUIInfoProvider: Add subtitle info to the cache. (PR:14360, 2 commits, 11 files changed)
- [PVR] trac18007: PVRDialogChannelsOSD: Fix crash after accessing m_ve (PR:14366, 1 commit, 1 file changed)
- [cleanup] NetworkBase and NetworkInterface refactoring (PR:14362, 5 commits, 10 files changed)
- VideoPlayer: WinRenderBuffer - fix buffer state after releasing video (PR:14368, 1 commit, 1 file changed)
- [network][windows] IPv6 preparations (PR:14369, 4 commits, 2 files changed)
- [docs/code_guideline] Fix interface file naming convention (PR:14367, 1 commit, 1 file changed)
- Added new api EpgEventIcon for ListItem (#14361) (702c2eb)
pvr.mythtv:
- fix gui dead lock trying to prompt for deletion of last played recording (0e2708a)
- bump version 5.8.3 (b6a5e97)
- build from travis fails for xcode 7.3 (3163109)
- processing task by dedicated thread (8b3e9e8)
- bump version 5.8.4 (62b5c04)
- implement GetStreamTimes from API 5.8 (3bff33b)
- bump version 5.8.5 (6482442)
pvr.zattoo:
- Fix loading details of more than 200 recordings (8de69a1)
Includes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (b63e867), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (7c7c6ce), pvr.iptvsimple(e8effad), pvr.mediaportal.tvserver (cc3eaf0), pvr.mythtv (3163109, +3), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff), pvr.wmc (292a819), pvr.zattoo (29e0bbf, +1), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9), pvr.sledovanitv.cz
17.8-313, 31 Aug 2018: Based off OSMC commit (f8a86c27) and xbmc (af7276ca0)
XBMC:
- [guiinfo] Fix String.IsEqual if second parameter is a listitem in a given container (PR:14375, 1 commit, 2 files changed)
- Improve wrapper.def generation (PR:14354, 1 commit, 1 file changed)
- [bluray] Usability improvements and some refactoring (PR:14374, 7 commits, 4 files changed)
inputstream.adaptive:
- [Android] remove MediaDRM::KeyReqest::getRequestType from log for L devices (997abf6)
17.8-314, 2 Sept 2018: Based off OSMC commit (e5f37b37) and xbmc (404b08b5e)
XBMC:
- Add scroll to plot on PVR Channel Guide Dialog (PR:14377, 1 commit, 1 file changed)
17.8-315, 2 Sept 2018: Based off OSMC commit (e5f37b37e) and xbmc (404b08b5)
XBMC:
- Show EPG image on the PVR screens (PR:14376, 1 commit, 3 files changed)
pvr.mythtv:
- add message 30114 âConnectedâ (b0556f4)
- opening dialog to notify connection failure cause gui deadlock (ef371a0)
- bump version 5.8.6 (573f7b2)
- fix transifex failure to parse language resource (9bcaf51)
- update translations from transifex (64b354d)
17.8-318, 7 Sept 2018: Based off OSMC commit (8a46969) and xbmc (1820dd417)
XBMC:
- [PVR] trac#18022: Add support for ACTION_SHOW_INFO to CGUIDialogPVRChannelGuide (PR:14391, 1 commit, 1 file changed)
- [PVR] Simple timeshift OSD (optional). (PR:14386, 1 commit, 5 files changed)
- GLES logging cleanup and unused extension removal (PR:14384, 3 commits, 2 files changed)
- guilib: do not log empty compile info of pixel shaders (PR:14385, 1 commit, 1 file changed)
- [PVR] PVRChannelGroup::ResetChannelnumberCache - fixes trac#18009 (PR:14378, 2 commits, 3 files changed)
- [Estuary] Music OSD: Remove âPreviousâ button for non-seekable stream (PR:14381, 1 commit, 1 file changed)
- [cleanup] silence class memaccess warning (PR:14370, 2 commits, 2 files changed)
- [PVR][Estuary] Add support for ACTION_(PREV|NEXT)_ITEM for timeshift buffer navigation (PR:14387, 5 commits, 17 files changed)
- [Estuary] studio icon fixes (PR:14379, 1 commit, 1 file changed)
pvr.dvbviewer:
- Fix stream chunk size unit (fc87f43)
- Bump version to 3.6.8 (f09e3eb)
- AutoTimers: Populate the series-field with the timers name (f1e966e)
- Add stream read chunk size as addon setting (15ef0a8)
- Bump version to 3.6.7 (e571cf8)
- Fix Timeshifting for v18 (PR:93, 2 commits, 5 files changed)
- Add license_flags / persistent_storage (a33fec8)
- Version bump 2.2.26 (78b48a1)
pvr.mythtv:
- bump version 5.8.7 (22aa23b)
inputstream.adaptive (78b48a1, +3), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (f09e3eb, +5), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (7c7c6ce), pvr.iptvsimple(e8effad), pvr.mediaportal.tvserver (9ae555c, +2), pvr.mythtv (22aa23b, +14), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff), pvr.wmc (292a819), pvr.zattoo (8de69a1, +2), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9), pvr.sledovanitv.cz
It remembers other settings just not the video calibration, if you change the video calibration top left setting, write the number down, then exit kodi and wait for it to load again, do you get the same number?
I tried the mv of .kodi folder.
