[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
If you go back to previous version do you still have the issue?
the non-beta (non leila) version has no issues.
17.8-357, 26 Nov 2018: Based off OSMC commit (30dc8295) and xbmc (e29b4bbc)
XBMC:
  • added: play next context menu and action (PR:14912, 1 commit, 10 files changed)
  • [guiinfo] Fix support for ListItem.NextDuration (PR:14929, 2 commits, 1 file changed)
pvr.mythtv:
  • don’t try any more to purge old cache: api fails (eec5154)
  • bump version 5.10.1 (f4a0f59)
Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (0517d4b, +17), pvr.nextpvr (7e36106, +2), pvr.njoy(4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
17.8-358, 27 Nov 2018: Based off OSMC commit (2ac38a889) and xbmc (b8518709e)
XBMC:
  • [estuary] add default addon image fallback in addon browser (PR:14935, 1 commit, 2 files changed)
  • VideoLayerBridgeDRMPRIME: unmap previous buffer when current buffer is reused (PR:14940, 1 commit, 1 file changed)
  • [skin.estuary] fix visualization visibility (PR:14941, 1 commit, 1 file changed)
  • [cleanup] remove code for VS lower than 14.0 (2015) (PR:14948, 1 commit, 2 files changed)
  • [fix] remove network available checks in C(Directory|File)Factory (PR:14918, 1 commit, 2 files changed)
inputstream.adaptive:
  • Sort forced subs before main subs (e86e995)
pvr.mythtv:
  • sync upstream cppmythlib (2.12.0) (0a3a50b)
  • add option to set default recording group as root for recordings (44e8ac8)
17.8-359, 28 Nov 2018: Based off OSMC commit (7a6e79fca) and xbmc (93086fd8)
OSMC Leia Skin
  • Better highlighting of cover art + improvements/fixes
pvr.mythtv:
Is it possible to install the ā€œpre releaseā€ version, currently on RC1 instead of the nightly builds?
Running RC1 on my 4k firestick and seems pretty stable. Was worried nightly builds might introduce other issues. Perhaps I’m worrying unnecessarily…
There are no official builds yet, these are all nightly builds. You could just disable checking for updates but then you will not get the latest skin etc. Or you could try remove gmc-18 from sources.
If you do run into issues you can always downgrade to the previous version.
Apologies if I’m asking things beyond the remit of this board.
On firestick Leia RC1 Skins I’m giving 4 options (and I’ve beenvgetting over my migration from Aeon Flux to Rapier).
On the Vero I’m on 17.8-359 and changing skins gives a similar sized list as Krypton.
Leia RC1 only supports skins ā€œConfluence, Pellucid, Rapier, Transparency, xperience1080ā€
But I get ERROR: CAddonInstallJob[skin.rapier]: The dependency on xbmc.gui version 5.12.0 could not be satisfied.
That’s a skin issue not a Kodi or OSMC issue. I believe the correct xbmc.gui dependency for 18RC1 is 5.14. It seems like some of the betas has the requirement to set it to 5.13, but I noticed when RC1 actually came out that Estuary had it listed at 5.14. You should probably check with the skin author.
17.8-360, 29 Nov 2018: Based off OSMC commit (7a6e79fca) and xbmc (5880ccf2)
XBMC:
  • Games: Assign joysticks in order of MRU (last activation) (PR:14944, 1 commit, 8 files changed)
  • [addons] fix addon install process percent indication (PR:14884, 2 commits, 4 files changed)
  • [pvr] CPVRRecording::GetResumePoint(): Performance: Update resume poi (PR:14961, 1 commit, 2 files changed)
  • [cleanup] remove code for glibc 2.0 and lower (PR:14951, 1 commit, 1 file changed)
  • [DASH] Tag main subs as default (6fb462e)
  • Version bump 2.3.12 (efd4b4f)
Includes latest addons: inputstream.adaptive (efd4b4f, +3), inputstream.rtmp (ce7f559), peripheral.joystick (5429dc4), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe, +1), pvr.dvbviewer (cda813e), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(6a12442), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (b17fdad), pvr.mythtv (d3a5af2, +3), pvr.nextpvr (ccdfd63), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d, +1), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (1207082), pvr.wmc(81e2090), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
The problem appears to be the Krypton repository is being used instead of the Leia.
Looking into this. Can you post a debug log if your repo is still pointing to Krypton.
Thanks so much gmc, for the reply.
Strange now it has self fixed after a day. Since I noted the problem kodi.log:
18:22:26.139 T:4074381920 NOTICE: Samba is idle. Closing the remaining connections
18:23:43.273 T:4074381920 ERROR: Missing operand
18:23:43.274 T:4074381920 ERROR: Error parsing boolean expression container.content(addons) + !int
eger.isgreater(container.numitems,1) +
18:23:43.274 T:4074381920 ERROR: Missing operand
18:23:43.274 T:4074381920 ERROR: Error parsing boolean expression container.content(addons) + inte
18:24:06.176 T:3940545264 ERROR: GetDirectory - Error getting addons://search/
20:40:41.881 T:3682296560 ERROR: Previous line repeats 2 times.
20:40:41.881 T:3682296560 NOTICE: ADDON: audioencoder.flac v2.0.1 installed
then loads more ADDON lines
then 1000+ lines when I enabled debug
Now I only see the Leia skins, and I just installed Rapier skin. I’m no longer ripping the skin off my hands in pain!
So sorry, can’t reproduce now
Did you manage to discover what is causing the BD-J menu error?
Unfortunately not yet.
BD-J cannot be used on OSMC; as it requires the Java runtime environment and a windowing system.
17.8-361, 1 Dec 2018: Based off OSMC commit (e33a4e70) and xbmc (5880ccf21)
OSMC
OSMC Skin 18
  • Add no dimming of cover art option
  • Bug fix
  • Update selected color + change wide widgets size
  • Version 17.9.3-20
Does this mean OSMC will never be able to utilise full blu-ray menus which use BD-J (as most do) even though Kodi 18 supports this?
Correct. Kodi v18 doesn’t support this on GLES platforms.
Since today’s update, the volume keys are controlling kodi’s volume instead of my AVR trough HDMI.
The CEC settings have always behaved a bit strange. When I reset them, I can indicate that Kodi is connected to my AVR instead of a TV, and in the past, changing this to AVR was enough to make Kodi control my AVR. After saving, that option disappeared however.
