The only changes for the last update were for skin fixes and a version update on the repository.
Indeed, it might be from a few days ago, but I donāt see a related change there either. Maybe there was a different Debian package that got updated?
Can you post the debug logs.
Sure, what logs do you want, trying to control the volume with the remote?
17.8-362, 3 Dec 2018: Based off OSMC commit (97e675b953) and xbmc (5880ccf21c)
pvr.vuplus
- PR #137. Load config if enabled
Includes latest addons: inputstream.adaptive (efd4b4f, +3), inputstream.rtmp (ce7f559), peripheral.joystick (5429dc4), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe, +1), pvr.dvbviewer (cda813e), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(6a12442), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (b17fdad), pvr.mythtv (d3a5af2, +3), pvr.nextpvr (ccdfd63), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d, +1), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (1207082), pvr.wmc(81e2090), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
Turn on debugging logging and replicate the issues. See first post for how to enable and upload logs.
Leia breaks unrar support. I queried how to install the new vfs rar support over on kodi and got:
ālinux binary addons are not available on the repo, itās your maintainers job to package them. In your case, itās OSMC.
Did you try: apt install kodi-vfs-rar? At leasts thatās how we name the rar addon in our ubuntu ppaā
I had a quick look into this and we are including vfs.rar but for some reason its not being added to the build. Will look into this.
Update: Iāve checked todays deb file and vfs.rar is included. Can you post the output from:
ls /usr/lib/kodi/addons/vfs.rar -la
Is the addon enabled?
Blockquoteroot
@osmc:/home/osmc# ls /usr/lib/kodi/addons/vfs.rar -la
total 396
drwxr-xr-x 2 root root 4096 Dec 1 14:54 .
drwxr-xr-x 57 root root 4096 Nov 28 20:38 ā¦
lrwxrwxrwx 1 root root 15 Nov 30 20:44 vfs.rar.so ā vfs.rar.so.18.0
lrwxrwxrwx 1 root root 16 Nov 30 20:44 vfs.rar.so.18.0 ā vfs.rar.so.2.0.4
-rw-rār-- 1 root root 394948 Nov 30 20:44 vfs.rar.so.2.0.4
Blockquote
I use the addon browser to search for vfs and get no hits
Itās already installed ā so doesnāt need to be fetched from a repository.
Just tried a test .rar file and also having the same issues.
Update: Found one issue, the repo has moved back to GitHub - xbmc/vfs.rar: RAR VFS addon for Kodi
On the nightly its still pointing to GitHub - notspiff/vfs.rar: RAR VFS addon for Kodi which is 2 commits behind.
Iāll update the binary repo and include the latest in the next nightly. Hopefully it fixes it.
I found it in my installed addons but disabled. A shame search doesnāt find the things OSMC (I assume) installed but didnāt activate.
Enabled/restart Kodi. I can now see the .mkv within the rar. Doesnāt play and I get errors in kodi.log. Will follow up on the kodi board. ** Just seen gmc updated his reply, so will hold off **
Hello, I get this error:
osmc@TVStuaosmc:~$ sudo apt update
Ign:1 Index of /debian stretch InRelease
Hit:2 Index of /debian stretch-updates InRelease
Hit:5 Index of /debian stretch Release
Hit:3 Index of /osmc/osmc/apt stretch InRelease
Get:4 Index of /osmc/osmc/download/dev/gmc-18 gmc-18 InRelease [6009 B]
Hit:6 http://security.debian.org stretch/updates InRelease
Err:4 Index of /osmc/osmc/download/dev/gmc-18 gmc-18 InRelease
The following signatures were invalid: EXPKEYSIG 326674E68C015D46 Greg McCarthy greg@gjmccarthy.co.uk
Fetched 6009 B in 2s (2675 B/s)
Reading package lists⦠Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: Index of /osmc/osmc/download/dev/gmc-18 gmc-18 InRelease: The following signatures were invalid: EXPKEYSIG 326674E68C015D46 Greg McCarthy greg@gjmccarthy.co.uk
W: Failed to fetch http://download.osmc.tv/dev/gmc-18/dists/gmc-18/InRelease The following signatures were invalid: EXPKEYSIG 326674E68C015D46 Greg McCarthy greg@gjmccarthy.co.uk
W: Some index files failed to download. They have been ignored, or old ones used instead.
Tried running this command again, but still the same.
Anyone else gets this?
Looks like the key has expired. Looking into it now.
http://paste.osmc.tv/oyovebiciy
It seems that I get a lot of CecLogMessage - Write: write failed
messages now. I also see it trying to control the volume of my TV (id 0), but my TV has cec disabled. It needs to control my AVR (id 5).
Maybe a recent kernel update caused this?
Not that Iām aware of. I think that warning message has been there forever. What happens if you enable cec on the TV?
Yes, Iāve got the same issue:
Fetched 6009 B in 2s (2799 B/s)
I think Iāve fixed this one now. The gpg key had expired so had to renew. Also means the public key has now changed. Can you please try this:
wget -qO - http://download.osmc.tv/dev/gmc-18/pubkey.asc | sudo apt-key add -
sudo apt-get update
Once confirmed working Iāll update the first post.
works:
Get:2 Index of /osmc/osmc/download/dev/gmc-18 gmc-18 InRelease [6009 B]
Hit:4 Index of /osmc/osmc/apt stretch InRelease
Get:8 Index of /osmc/osmc/download/dev/gmc-18 gmc-18/main armhf Packages [82.2 kB]
Fetched 88.2 kB in 2s (40.4 kB/s)
osmc@osmc:~/.kodi/temp$
Yes confirmed, this works!
osmc@TVStuaosmc:~$ wget -qO - http://download.osmc.tv/dev/gmc-18/pubkey.asc | sudo apt-key add -
OK
osmc@TVStuaosmc:~$ sudo apt-get update
Get:3 Index of /osmc/osmc/download/dev/gmc-18 gmc-18 InRelease [6009 B]
Fetched 88.2 kB in 2s (36.6 kB/s)
