gmc I was on 17.8-362 (no 363)
And did:
root@osmc:/home/osmc/.kodi/temp# sudo apt-get update
Ign:2 Index of /debian stretch InRelease
Hit:4 Index of /debian stretch-updates InRelease
Hit:5 Index of /debian stretch Release
Hit:1 Index of /osmc/osmc/apt stretch InRelease
Hit:3 Index of /osmc/osmc/download/dev/gmc-18 gmc-18 InRelease
Hit:7 http://security.debian.org stretch/updates InRelease
Reading package lists⦠Done
root@osmc:/home/osmc/.kodi/temp# sudo apt-get dist-upgrade
ā¦
Successfully upgraded for me, couple of errors, but seems fine after reboot:
indent preformatted text by 4 spaces
root@lagavulin:/home/osmc# apt-get dist-upgrade
Building dependency tree
Reading state information⦠Done
Calculating upgrade⦠Done
mediacenter-skin-osmc vero3-mediacenter-osmc
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 83.3 MB of archives.
After this operation, 24.6 kB of additional disk space will be used.
Get:1 Index of /osmc/osmc/download/dev/gmc-18 gmc-18/main armhf mediacenter-skin-osmc all 17.9.3-21 [11.2 MB]
Get:2 Index of /osmc/osmc/download/dev/gmc-18 gmc-18/main armhf vero3-mediacenter-osmc armhf 17.8-363 [72.2 MB]
Fetched 83.3 MB in 1min 41s (820 kB/s)
(Reading database ⦠22804 files and directories currently installed.)
Preparing to unpack ā¦/mediacenter-skin-osmc_17.9.3-21_all.deb ā¦
Unpacking mediacenter-skin-osmc (17.9.3-21) over (17.9.3-20) ā¦
Preparing to unpack ā¦/vero3-mediacenter-osmc_17.8-363_armhf.deb ā¦
Unpacking vero3-mediacenter-osmc (17.8-363) over (17.8-362) ā¦
Processing triggers for mime-support (3.60) ā¦
Setting up mediacenter-skin-osmc (17.9.3-21) ā¦
Setting up vero3-mediacenter-osmc (17.8-363) ⦠W: Could not open file /var/log/apt/eipp.log.xz - open (12: Cannot allocate memory) W: Could not open file ā/var/log/apt/eipp.log.xzā - EIPP::OrderInstall (12: Cannot allocate memory)
This morning APT picked up the 17.8-363. Installed w/o the errors mentioned in the previous post.
Fixed the rar issue
CEC is flawless on my system. But doing a reboot remotely starts the TV. So note to self donāt reboot hours before going to the lounge!
thanks ActionA, Iām curious about whether there is any specific issue here that will be fixed. Dropping the āwait for a new build or rever to old as beta is expected to be unstableā is not a very constructive comment, especially in a thread where we are also supposed to provide feedback (and willing to test fixes, etc.)ā¦
Your desire to be provided with a āworkaroundā for what is almost certainly a growing pain while code matures is not useful to anyone. You could at least provide logs demonstrating the issue? That would be useful feedback. At this point, you are the only report of such an issue. Until others report the same issue, the problem is more likely to be a problem with your environment, not the code. But without logs, who knows.
Thank you, I uninstalled it, seems it solved the problem. I didnāt install anything extra just an openvpn client, maybe that installed that (even when i removed it it removed that package).
Just in case if somebody will have similar issue, maybe good to know.
Thatās to be expected as the localizes for music and video have changed from v17 to v18. The skinshortcuts script will transfer the old localizes when you upgrade to v18. Restoring those entries or changing the name of your already configured entries will solve this
