Overview
The next version of Kodi v18 (codename Leia) was released in January. Since then, we’ve been working on bringing this up for OSMC. There have been a number of technical challenges, but we now should have a release that is of the standard you would expect from us.
It would be good if users could test this before we release this as a stable update, currently tentatively scheduled for Easter Sunday, 2019-04-21T19:00:00Z.
Supported platforms
This release supports:
- Vero 2 (late 2015)
- Vero 4K (early 2017)
- Vero 4K + (late 2018)
- Raspberry Pi 0/1
- Raspberry Pi 2/3
Support for Vero 1 has now been discontinued, as the platform has reached end of life status. We will continue to keep older images on the website available for download.
How to update
Updating from a nightly build
If you are currently running a test build of Kodi, please ensure that you have not moved updated beyond the gmc-18 repository. We anticipate Team Kodi to branch Kodi v18 soon and proceed with v19. If you have moved to the gmc-19 repository then you will not receive an update by following the instructions below.
Updating from a stable version of OSMC
If you’re running a stable version of OSMC, then you should be able to update from a compatible platform without issue. Please make sure that you system is up to date first by going to My OSMC → Updates and initiating an update check; installing any outstanding updates.
Updating via the command line
To install the update:
- Login via the command line
- Edit the file
/etc/apt/sources.list - Add the following line:
Go to My OSMC → Updates again, and initiate an update check. Install the updates when prompted.
Tracking releases
There are outstanding issues, so we plan to push some further test builds over the coming days. You may wish to keep the modification to /etc/apt/sources.list, but we would recommend keeping this active until the final release is made available. When we do this, we’ll make a clear announcement on the forums and blog.
Known issues
Currently, we are aware of the following issues:
- Suspend mode is not working as expected on Vero 4K / 4K +
- Hotplugging does not work as expected on Vero 4K / 4K +. This means that turing on Vero before you turn on your display may result in a locked resolution until you reboot the device.
- The system information page needs a cosmetic fix to display versioning
I’ll update this section as more issues are discovered.
Frequently asked questions
Q: I’ve installed the update and now I only have a black screen or a sad face loop, how do I fix this?
A: It’s possible that your Kodi userdata is causing an issue with the new version. The first recommendation would be to move it away and allow Kodi to generate a new userdata directory. This can be done by executing the following commands after accessing the command line:
mv ~/.kodi ~/.kodi-backup
Before attempting this, you may wish to try a more conservative approach, and delete ‘Addons.db’ only, as reports from users suggest that add-on migration is the problem
Q: I only see a black screen / hang on migrating add-ons, what should I do?
A: If you encounter this problem and a consider amount of time (more than half an hour) has passed, you should log in to the system and execute the above instructions from the previous question.
Q: I am using a shared library? Has the database version changed?
A: Yes. You should check that your other Kodi clients are compatible with Kodi Leia before upgrading.
Q: Are add-ons supported by Kodi Krypton supported in Kodi Leia?
A: Most add-ons that worked in Kodi 17 (Krypton) should work without issue with the new version of Kodi.
Q: I can’t find my add-ons anymore
A: To ensure compatibility where possible, Kodi disables any non-official add-ons by default when a new major version is released. You should be able to enable them manually under Settings. Note that this does not necessarily mean they be compatible with the new version of Kodi.
Q: Will my current skin work with Kodi Leia?
A: The new version of Kodi has reworked the skinning system extensively, and as such, only a handful of skins are currently ready for Kodi Leia. You should check with the developer of the skin to see if there is a Leia compatible version available
Q: My add-ons are not working, what can I do?
A: You should notify the developer of this add-on and ask them if there is a version compatible with the new version of Kodi. Unfortunately OSMC cannot do anything about this.
Q: How can I downgrade?
A: Unfortunately, downgrading is not trivial. However we will maintain Krypton images on our website for some time. If you discover a bug or issue, we are more interested in fixing it, as there will be users in a similar position, rather than having users downgrade.
Q: I don’t see all of my skin’s menus. What can I do to resolve this?
A: Please wait a few moments for the skin menus to be rebuilt. This may take a while to update if you have a number of add-ons on your system. If the issue persists, you should check that your skin is indeed compatible.
Q: CEC has stopped working, what can I do?
A: Power off your TV and device at the mains for 60 seconds, including your AV receiver if you have one. This usually resolves CEC issues.
Q: Why does the version show as Kodi Leia 18.2?
A: We have backported some official fixes for Kodi Leia since we anticipate it to be released shortly. To avoid confusion, we have retained the version bump. We will continue to update Kodi and deliver any fixes or improvements in future updates.
Q: My question is not answered and I am experiencing an issue, what can I do?
A: Please start a new forum post, with detailed information so that we can assist you with your problem.
Changelog
20/04/2019: added back HDMI hotplug detection for Vero 4K / 4K +; added support for game add-ons; fixed System Info screen; depend on libwidevine dependencies automatically.
15/04/2019: initial release
Let me know how you get on
