Sam or anyone help with this? I posted the log and then nothing from anyone. I have a completely broken system
If it does, add echo 8bit > /sys/class/amhdmitx/amhdmitx0/attr to /etc/rc.local, before the line exit 0
Not sure if this did anything?
osmc@osmc:~$ echo 4448bitnow | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
4448bitnow
osmc@osmc:~$
Did I do it right?
No error indicates success
Ok so success but still no video
Let’s test with Kodi default settings. Enter the following commands with an SSH connection.
systemctl stop mediacenter
mv ~/.kodi ~/kodi.bak
systemctl start mediacenter
If needed you can restore:
mv ~/.kodi ~/kodi.bk2
mv ~/kodi.bak ~/.kodi
If your original setup was restored as expected and you want get rid of the unneeded clean install you can delete that with the following command.
rm -r ~/kodi.bk2
Crap…
Still no good.
But turns out the HDMI was playing up as I did a hard boot of the receiver and it seems good.
I feel stupid now lol
Thanks everyone for assisting…
Can you update and try again?
Issue should be solved with:
Please post full logs – I can’t see if you updated
Right, updated the URL above.
I’m seeing something myself:
ii mediacenter-addon-osmc 3.0.719 all OSMC addon for mediacenter
No updates available (including via apt get)
It can take a bit of time for the update to propagate to all of the mirrors. It shouldn’t take long before it reaches you.
I just did the update and can confirm that it does fix the skin switching issue. Not that I change skins often. But when you need to change skins, it’s useful to have it actually work.
I confirm, solved.
I have 2 vero 4k+ and one is working great with the new builds but I’m having a problem with 1. This one i have played with more to try get my cec and resolutions recognized correctly so i have probably messed something up.
I was unable to run myosmc for the past few updates but when i was, when i went to scan for updates i would get an error and it wouldn’t scan. After the last update myosmc starts but i still get the update.
Logs are here
https://paste.osmc.tv/cewapalosa
If it’s too hard or not worth chasing down ill just reinstall.
Try removing the videoimprovement line from sources.list.
Will do as soon as I get home
That sorted it. Thank you
As I said earlier I get a stutter when playing 3D-MVC files. I’ve arranged a log and a mediainfo
Log: https://paste.osmc.tv/ovohiyinic
Media: https://paste.osmc.tv/ogovesuqaz
I hope you can help me!
I’ve just read your initial post. Does it happen with all 3D-MVC files or do you have one which plays fine?
