I tried using the iiYama as second display. My system recognised it but I got into difficulties with switching between with mouse cursor. Running su - before using get-edid also wouldn’t accept my root login; strange. Running get-edid didn’t like running as user.
Will do as you suggest but will have to return to this later as I have to go out now.
Many thanks.
The EDID is already in your logs. From that I see your display doesn’t support any ‘video’ (CTA) modes but those two modes must be being injected by the system. Our logs don’t report VESA modes atm.
What you can try is apply surgery to ~/.kodi/userdata/guisettings.xml. Stop Kodi with sudo systemctl stop mediacenter
Find a line in guisettings with videoscreen.screenmode and change it to
Hi Graham,
No joy sadly. Now I have lost my route to host!
My upgrade which was very messy together with subsequent edits may not have helped.
I think I would like to do try a new installation but using the Kodi 19 testing version. The only route I know is to burn an SD card. Can I do that with a complete Kodi 19 or do I burn from the normal published 2020.11-1 installation file and update?
I am back with initial installation from 2020.11-1 and have the dispaly now working again. The resolution from my settings is what I had set it using TV at 1920x1080p but I am not sure I believe it as it is outwith the capability of the iiYama display.
Before I do anything more what should I save before upgrading to Kodi 19?
Where do I find disp_cap?
Well I assume it will have worked from cli in the meantime. But I also wonder did you manually check for updates via “Scan for updates now” in MyOSMC before?
Anybody else have issues with profiles? I started with a clean install (moved .kodi to the side). I’ve created a 2nd profile (Test) but when I try to load it nothing happens (Kodi ‘freezes’).
2021-06-01 11:10:00.442 T:2763 INFO <general>: Python interpreter interrupted by user
2021-06-01 11:10:00.779 T:2766 INFO <general>: Skipped 1 duplicate messages..
2021-06-01 11:10:00.779 T:2766 INFO <general>: CPythonInvoker(7, /home/osmc/.kodi/addons/script.trakt/default.py): script successfully run
2021-06-01 11:10:01.028 T:3852 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-06-01 11:10:01.061 T:2766 INFO <general>: Python interpreter interrupted by user
2021-06-01 11:10:01.064 T:2767 INFO <general>: CPythonInvoker(8, /home/osmc/.kodi/addons/service.iptv.manager/service.py): script successfully run
2021-06-01 11:10:01.240 T:2767 INFO <general>: Python interpreter interrupted by user
2021-06-01 11:10:01.243 T:2768 INFO <general>: CPythonInvoker(9, /usr/share/kodi/addons/service.osmc.settings/resources/lib/service.py): script successfully run
2021-06-01 11:10:01.243 T:2768 INFO <general>: CPythonInvoker(9, /usr/share/kodi/addons/service.osmc.settings/resources/lib/service.py): waiting on thread 3558854864
2021-06-01 11:10:06.253 T:2711 ERROR <general>: CPythonInvoker(9, /usr/share/kodi/addons/service.osmc.settings/resources/lib/service.py): script didn't stop in 5 seconds - let's kill it
Only way to load it seems to be to enable the profile selection screen on startup and select the Test profile but switching between profiles fails.
I think I’m losing the plot. What I understand is with Kodi 18.9 and kernel 3.14 you get a picture on the iiYama with the GUI at 1920x1080x60Hz - even though the monitor is not supposed to support that.
On Kodi 19.1 and kernel 4.9 you can’t even set the GUI to 1920x1080.
The solution should be to make a file called disp_cap containing these lines
I am now getting a rap on my knuckles for posting all these in a row so will have to wait for a reply.
All my efforts to upgrade have failed and I am getting the security errors I posted yesterday when I ran dist-upgrade from cli. I did check my system time and it all seems to be in sync. Here is the log after more attempts from cli. I had better stop now and wait for dust to settle.
Since I was not able to post and having waited a while I tried the update from screen and this time the update ran and did change my system. The same error as last time occurred however as I now have no screen at all and the display has gone to sleep. I can however still run from cli so here is the log after the update.
Hi graham,
sorry this message had been saved somewhere and popped up after you replied.
Will do as you suggest and try the disp_cap file but it is odd that display had been working with higher resolution.
I shall have to leave this now but will return at weekend.
Your help is much appreciated and please forgive the string of logs. Will not do that again.
