If you post debug enabled logs and mediainfo of the video we would at least have a chance to check the bug.
Also first step with such issues would be to play it locally to exclude the network as a source of problem.
I updated again to the latest version and its now fixed. Thanks Chillbo.
Thanks for the feedback! For reference, it should be this issue that’s the root cause: Include rebuild not triggered after template changes · Issue #33 · mikesilvo164/script.skinshortcuts · GitHub
Hopefully, that will be fixed eventually. I’ve circumvented the issue for the time being, but it’s not the way it’s supposed to be.
Concerning the mediainfo it does it for all videos, all formats (h264, AC3, dts, x265, aac, etc etc.) I really tried several dozens of formats and it’s always the same.
Concerning the log How i can i upload it ?
I updated to latest version as well and no longer an issue.
Then before uploading logs try to play the files locally to exclude the network as an issue.
reproduce the issue
upload the log set (all configs and logs!) either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
Thx for confirming!
A footnote to my painful experience with version 19, noted here at length. My problem was caused by a failing hdmi device so apologies to all. Working well on new display now thanks.
Budgie
Glad to hear this.
For some of my videos, the audio skips, and eventually just quits. Sometimes the video and audio are out-of-sync (as well as with the sub-titles). I have not (yet) found any common factor among the videos that are doing this. Again, this is only for certain videoes specified.
I uploaded logs to https://paste.osmc.tv/fekabiyine
I should note that when I first tried to upload logs, I got a response back with “https://paste.osmc.tv/\<html>”. After that I tried updating osmc. I think only the osmc skin updated. But, afterwards, the above url was returned.
I will try several videos again that I know have this problem, and upload those logs as well.
This is after I got all of my network problems resolved and optimized everything that seemed to need it. Performance problems disappeared after that. I can play full 4K UHD videos with no problems. But do note that i can’t do this using the internal builtin wifi; I have an access point that I plug into the vero lan port, This gives me more than enough bandwidth needed.
Fortunately, this seems to fails for a few videos,. Hopefully the other videos in collection will still play well.
- I moved your post hear as you are on the Testing Builds.
- We recommend to change the GUI to 1080p not running it in 4k
- For a video that you can reproduce the issue provide mediainfo via http://videosam.pl and provide filename so people can find it in the logs.
Dang! forgot that I was still using test builds. sorry.
OK.
mediainfo:
https://paste.osmc.tv/xeyacaxeli
In the logs I only used one movie (“Macbeth”) and only ran it once, then stopped it.
Hope this helps,
ken
There is no information about any Macbeth movie being played in that log. Actually there is no trace of any try to play something.
Having problems uploading logs. Via osmc log uploader, I get “http://paste.osmc.tv<html>
Trying to upload file to “http://videosam.pl” I keep getting a login prompt. Trying paste text, but it is big text file.
have uploaded kodi.log to: https://drive.google.com/file/d/15xsQmvudyC5dMo6RbpJedhNySNbSnwre/view?usp=sharing
this is a tar.gz archive.
let me know if you get this.
Having serious internet problems today…
Do not enable any component specific logging, ONLY enable debug logging. Reboot twice before demonstrating issue and obtaining logs.
Yes it can be opened, but as it is 33M it already show that there is a problem.
What I see is many of this entries, lets see what the expers say:
2021-06-08 05:42:51.984 T:2767 DEBUG <general>: CAMLCodec::GetPicture: index: 114, pts: 4.560, dur:40.000ms
2021-06-08 05:42:51.984 T:2767 DEBUG <general>: CVideoPlayerVideo::OutputPicture - ttd:1053ms pts:4.560 Clock:3.507 Level:0 elapsed:0.004ms
2021-06-08 05:42:51.985 T:2701 DEBUG <general>: CAMLCodec::PollFrame elapsed:2.075ms
2021-06-08 05:42:51.985 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:25 dl:8988 fs:7807 front:164
2021-06-08 05:42:51.987 T:2701 DEBUG <general>: PrepareNextRender: frameOnScreen: 3509933.044000 renderPts: 4676599.715753 nextFramePts: 4560000.000000 -> diff: 116599.715753 render: 1 forceNext: 0
2021-06-08 05:42:51.989 T:2701 DEBUG <general>: CAMLCodec::ReleaseFrame idx:114, drop:0
2021-06-08 05:42:51.991 T:2701 DEBUG <general>: CAMLCodec::PollFrame elapsed:2.079ms
2021-06-08 05:42:51.992 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:25 dl:8988 fs:7807 front:164
2021-06-08 05:42:51.996 T:2777 DEBUG <general>: connect replacing configured host 192.168.1.103 with resolved host 192.168.1.103
2021-06-08 05:42:51.997 T:2701 DEBUG <general>: CAMLCodec::PollFrame elapsed:2.076ms
2021-06-08 05:42:51.998 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:25 dl:8988 fs:7807 front:164
2021-06-08 05:42:52.003 T:2701 DEBUG <general>: CAMLCodec::PollFrame elapsed:2.077ms
2021-06-08 05:42:52.006 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:25 dl:7708 fs:7807 front:164
2021-06-08 05:42:52.006 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:24 dl:7708 fs:7643 front:120
2021-06-08 05:42:52.009 T:2701 DEBUG <general>: CAMLCodec::PollFrame elapsed:2.080ms
2021-06-08 05:42:52.011 T:2767 DEBUG <general>: CVideoPlayerVideo::CalcDropRequirement - hurry: 0
2021-06-08 05:42:52.012 T:2767 DEBUG <general>: CAMLCodec::AddData: dl:7817 sum:8008 sz:365 dts_in:5.840 pts_in:6.040 ptsOut:4.560 ttd:1026ms overflow:0
2021-06-08 05:42:52.012 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:25 dl:7817 fs:8008 front:120
2021-06-08 05:42:52.012 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:24 dl:7817 fs:7888 front:107
2021-06-08 05:42:52.012 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:23 dl:7817 fs:7781 front:1760
2021-06-08 05:42:52.015 T:2701 DEBUG <general>: CAMLCodec::PollFrame elapsed:2.073ms
2021-06-08 05:42:52.017 T:2767 DEBUG <general>: CVideoPlayerVideo::CalcDropRequirement - hurry: 0
2021-06-08 05:42:52.018 T:2767 DEBUG <general>: CAMLCodec::AddData: dl:7911 sum:7875 sz:94 dts_in:5.880 pts_in:5.960 ptsOut:4.560 ttd:1019ms overflow:0
2021-06-08 05:42:52.018 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:24 dl:7911 fs:7875 front:1760
2021-06-08 05:42:52.018 T:2767 DEBUG <general>: CAMLCodec::DequeueBuffer: pts:4.600 idx:115
2021-06-08 05:42:52.018 T:2767 DEBUG <general>: CAMLCodec::GetPicture: index: 115, pts: 4.600, dur:40.000ms
2021-06-08 05:42:52.018 T:2767 DEBUG <general>: CVideoPlayerVideo::OutputPicture - ttd:1058ms pts:4.600 Clock:3.541 Level:0 elapsed:0.005ms
2021-06-08 05:42:52.020 T:2767 DEBUG <general>: CAMLCodec::GetTimeSize: len:24 dl:7911 fs:7875 front:1760
2021-06-08 05:42:52.020 T:2701 DEBUG <general>: CAMLCodec::PollFrame elapsed:2.089ms
2021-06-08 05:42:52.023 T:2701 DEBUG <general>: PrepareNextRender: frameOnScreen: 3545180.877000 renderPts: 4711847.548753 nextFramePts: 4600000.000000 -> diff: 111847.548753 render: 1 forceNext: 0
2021-06-08 05:42:52.024 T:2701 DEBUG <general>: CAMLCodec::ReleaseFrame idx:115, drop:0
2021-06-08 05:42:52.025 T:2767 DEBUG <general>: CVideoPlayerVideo::CalcDropRequirement - hurry: 0
Finally got logs to upload via osmc: http://paste.osmc.tv/jenicihhoge
this has full component logging. The movie, again, is “Macbeth”. I started where it was last stopped. And the audio is very much out of sync.
I have copied the mediainfo to another video “Gangs of London” to `https://drive.google.com/file/d/1Wm0t3dxVliKYE_qcXq0HHo-9lH_AFMln/view?usp=sharing
(sorry about names.) I don’t have kodi logs for this, but I do know that it too has audio sync problems.
Sorry for all of the inconvenience, thanks for the help.
ken
I have a problem, that my Vero doesnt remember when i am switching from an 1080p Display to an 4k Display… Is it somehow possible to fix the EDID in the vero 4k?
Dispite i have an 4k, or 720p display pluged in… i want that the vero always thinking that the display is cabable of everthing…
4k @ 24hz/30hz/50hz/60hz
1080p @ 24/30/50/60hz…
1080p 3D @ 24 hz etc…
And also on the audio side… with Dolby TrueHD, DTS Master HD, etc…
Maybe you have an tip for me? Thanks! I really enjoy the the device and the software
I have to ask - why would you want that? If you change display, Vero should check all the resolutions available automatically. Isn’t that happening? Also is this something you’ve found to be different on these Kodi v19 builds than on 18.9? If not, we’ll move this to a new thread.
Because I have an AVR with Projektor (4k) and TV (FullHD) connected… i use it only with the projector… but sometimes it detects the TV and so Full HD is only avaibalbe… so I want to persist the EDID Data… is that somehow possible? Thanks!
