We’d like to move away from Linux 4.9 to Linux 4.14 in the next OSMC update for Raspberry Pi.
We need to test this kernel to make sure that things work as expected, and those using additional hardware (such as I2S DACs) don’t experience any regressions.
I’d appreciate it if you could test this and provide feedback before we release this as an update to other users. To test this update:
Add the following line: deb http://apt.osmc.tv stretch-devel main
It might be worth noting that if you are using the 8812au driver, it won’t work with connman when upgrading to 4.14. It does work with kernel 4.9.
Here is what connmand says:
connmand[345]: wlan0 runs an unsupported 802.11 driver
Here is the module info that works.
RTL871X: rtl8812au v4.3.20_16317.20160108
A workaround could be to kill connman and go to something like wicd, but if there is an easy fix that would be awesome. If not, at least it should be noted that this 802.11 driver will break and presumably others might as well, before pushing the kernel to stable.
Everything turned painfully slow after 4.14.x kernel update from 4.9.x. Sometimes I cannot even ssh and rbp1 looks frozen. Sometimes I manage to make a complete boot up, but everything is so slow that it turns unusable. No evident log errors, just slowliness and sometimes strong freezing.
Any hints to rollback to 4.9.x kernel to check if the new kernel is the culprit or just a bad
install?
UPDATE: I managed the rollback to the previous kernel with:
sudo dpkg-reconfigure rbp1-image-4.9.29-17-osmc
and everything returned to normal, so I guess that rbp1 not loving this 4.14.15-4
I test with ALLO DIGIONE on PI3 and it’s OK. It now works. I only added the following 2 lines in config.txt:
dtoverlay = allo-digione
dtparam = audio = off
Confirmed - I also have troubles with 8812au driver under 4.14: the interface shows up as available, but scanning is not possible. No problem at all with kernel 4.9.
For kernel 4.14 we have version 4.2 from 2013 and somehow for kernel 4.9 we have version 4.3. Doing some looking to find out where that might have happened and where the source is pulled from.
filename: /lib/modules/4.14.15-5-osmc/kernel/drivers/net/wireless/8812au.ko
version: v4.2.2_7502.20130517
author: Realtek Semiconductor Corp.
description: Realtek Wireless Lan Driver
license: GPL
srcversion: 660219EB7C7F3C4915178EF
