I spoke too soon - the 3d has been hurt badly by the update today. Yesterday I watched the meg in 3d and it was perfect. I just did the update and now it has flashing screen with pixelations. i checked a few other movies (avatar 3d and avengers 3d) and it has the same issue. while i didn’t watch avatar 3d or avengers 3d recently, the meg 3d was perfect yesterday (with the previous update) and it now unwatchable (after today’s update).
the hobbit 3d issue as shown in my post earlier and with the logs is unfortunately still there.
All white listed resolutions were removed. I had to manually add them.
After rebooting the first three times, the refresh rate defaulted to the first one on my list (1080p @ 23.98) and not what I manually set it at (1080p @ 60.00). This now seems to have resolved itself.
The contrast bug is still present.
Lip sync issue is now difficult to determine for some reason.
Fixed:
Menu text, clearlogo, icons now rendered cleanly like in kernel 3.14.
to add to my previous post, i just went back to the previous version (april 16 - 4.9.113-16) and the avengers 3d and avatar 3d do play fine with that version.
That’s weird, the movie doesn’t have the stereoscopic flag set, so the 3d MVC detection fails. But the file has also the MVC tag in its name, so it should be detected as MVC as fallback. But it isn’t. I assume (because there’s also the ‘3D’ in its name) that this “3D” overrides the “MVC” and then Kodi defaults to left_right. I’ll try to reproduce it here. Stay tuned …
I have also the pixalation in some 3D movies - and - a lot of x64 content, mostly with lower resolution will play only without hardware acceleration. On 1080p, some will play some not.
Just as an update: I know what’s causing the recent playback issues.
A simple (temporary) fix could be to revert a couple of things, but this won’t be solution we want going forward. If we can’t make enough progress in the next few days, then we’ll push this as a stop-gap to keep testers happy during this lockdown.
I would like to stress clearly though that this is still a testing build and is expected to be somewhat rough around the edges.
