[TESTING] Linux 4.9 kernel and improved video stack for Vero 4K / 4K +
Played 2 videos and around the 5th try, Vero crashed. Sometimes all it takes is 2 tries.
I will post media info and samples on the next edit of this post
Log https://paste.osmc.tv/puremodipe
Sample of video played on 1st, 2nd ,3rd, 5th try - https://drive.google.com/open?id=1IW-bgBD2HHUNcWarkNVRAzWHBw7yT01s
It has this media info
General
Unique ID                                : 321499009661325754871491137263747672534 (0xF1DE74FCA01F334F8A18D880231F29D6)
Complete name                            : Blue Planet II S01E03-problem-part.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 177 MiB
Duration                                 : 30 s 662 ms
Overall bit rate mode                    : Variable
Overall bit rate                         : 48.5 Mb/s
Movie name                               : Blue Planet II (E03) Coral Reefs
Encoded date                             : UTC 2018-11-19 08:21:40
Writing application                      : mkvmerge v28.2.0 ('The Awakening') 64-bit
Writing library                          : libebml v1.3.6 + libmatroska v1.4.9
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Commercial name                          : HDR10
Format profile                           : Main 10@L5.1@High
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 30 s 572 ms
Bit rate                                 : 46.1 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.232
Stream size                              : 168 MiB (95%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1000 cd/m2
Maximum Frame-Average Light Level        : 120 cd/m2
Audio
Format                                   : DTS XLL
Format/Info                              : Digital Theater Systems
Commercial name                          : DTS-HD Master Audio
Codec ID                                 : A_DTS
Duration                                 : 30 s 571 ms
Bit rate mode                            : Variable
Bit rate                                 : 2 507 kb/s
Channel(s)                               : 6 channels
Channel layout                           : C L R Ls Rs LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossless
Delay relative to video                  : 91 ms
Stream size                              : 9.14 MiB (5%)
Title                                    : DTS-HD MA 5.1
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 11 s 178 ms
Bit rate                                 : 31.0 kb/s
Count of elements                        : 4
Stream size                              : 42.3 KiB (0%)
Title                                    : English (SDH)
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : en:Chapter 5
Sample of the video on the 4th try - https://drive.google.com/open?id=1AiLSN494OWbXDfG5jqe2q17ccYYWMlik
Its media info below:
General
Unique ID                                : 255311548000376838804917385913350722751 (0xC013372DE73D7106E9EB281C9D0794BF)
Complete name                            : Avatar_extract.mkv
Format                                   : Matroska
File size                                : 322 MiB
Duration                                 : 38 s 210 ms
Overall bit rate                         : 70.8 Mb/s
Movie name                               : Avatar extract
Encoded date                             : UTC 2019-08-07 09:58:20
Writing application                      : mkvmerge v35.0.0 ('All The Love In The World') 64-bit
Writing library                          : libebml v1.3.9 + libmatroska v1.5.2
Cover                                    : Yes
Attachments                              : cover / Avatar_0.ttf / Europe_Ext_0.ttf
Video
Format                                   : HEVC
Duration                                 : 38 s 205 ms
Bit rate                                 : 66.9 Mb/s
Color space                              : YUV
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.336
Stream size                              : 305 MiB (94%)
Title                                    : Avatar.2009.Extended.UHD.Re-Grade.4000nit
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : DTS XLL
Codec ID                                 : A_DTS
Duration                                 : 38 s 209 ms
Bit rate                                 : 3 795 kb/s
Bit depth                                : 24 bits
Delay relative to video                  : 1 ms
Stream size                              : 17.3 MiB (5%)
Title                                    : | Original |
Language                                 : English
Default                                  : No
Forced                                   : No
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 34 s 285 ms
Bit rate                                 : 76.8 kb/s
Count of elements                        : 17
Stream size                              : 322 KiB (0%)
Title                                    : SDH
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 34 s 284 ms
Bit rate                                 : 68.7 kb/s
Stream size                              : 287 KiB (0%)
Title                                    : Full
Language                                 : English
Default                                  : No
Forced                                   : No
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Bit rate                                 : 0 b/s
Count of elements                        : 0
Stream size                              : 0.00 Byte (0%)
Title                                    : Na'vi parts only
Language                                 : English
Default                                  : No
Forced                                   : Yes
Menu
00:00:00.000                             : en:The Omaticaya Clan
Sorry. Another observation I had about this build is that sometimes when I reboot (cold), the mounted partitions become unmounted. And when I manually unmount a partition, next reboot would not mount the partition.
Not sure if reported, but with UHD Blurays Rips, with m2ts files, for example this one:
Summary
General
Complete name : 00010.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 81.0 GiB
Duration : 2 h 11 min
Overall bit rate : 87.9 Mb/s
Maximum Overall bit rate : 109 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate : 640 kb/s
Maximum bit rate : 7 500 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -1 ms
Stream size : 604 MiB (1%)
Service kind : Complete Main
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate mode : Constant
Bit rate : 640 kb/s
Bit depth : 16 bits
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Bit depth : 16 bits
Audio #4
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Bit depth : 16 bits
Audio #5
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Bit depth : 16 bits
Audio #6
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Bit depth : 16 bits
Audio #7
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Bit depth : 16 bits
Or this one:
General
Complete name : 00058.m2ts
Format : BDAV
File size : 82.1 GiB
Duration : 2 h 23 min
Overall bit rate : 82.0 Mb/s
Maximum Overall bit rate : 128 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1506 cd/m2
Maximum Frame-Average Light Level : 459 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 448 kb/s
Maximum bit rate : 6 144 kb/s
Bit depth : 16 bits
Stream size : 459 MiB (1%)
Number of dynamic objects : 15
Audio #2
Menu ID : 1 (0x1)
Format : DTS XLL
Codec ID : 134
Bit depth : 16 bits
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Delay relative to video : -9 ms
Audio #4
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Audio #5
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Audio #6
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 448 kb/s
Maximum bit rate : 6 792 kb/s
Bit depth : 16 bits
Audio #7
Menu ID : 1 (0x1)
Format : DTS XLL
Codec ID : 134
Bit depth : 16 bits
Audio #8
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Audio #9
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Audio #10
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Audio #11
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Audio #12
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
Audio #13
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 448 kb/s
Bit depth : 16 bits
When I start playing works fine, but if I advance the film with two or three clicks in the remote to the right, appears de “Loading …” message, but never start playing again. Sometimes if I press the pause button and play again works, others I have to forward again one time … Appears that something is a bit broken with this kind of files.
But if I doesn’t press any button plays really fine, with no frame drops or skips.
(mod edit: hid the wall of text below a dropdown)
For those having ssh issues, double check your network settings. The new kernel test update reset my network settings back to dhcp from my static ip. Had to change back to my static ip. Ssh was fine, it was the ip change.
Are you using Kodi paths? If so, try a system mount. This behavior sounds like what happens when it is struggling to keep up with (relatively) high bandwidth files.
I’m added the folders via Kodi browser using nfs protocol. My network is gigabit ethernet, and this doesn’t suceed with mkv files (it run 60Gb mkv files without troubles).
The problem is that when appears the “Loading …” text it doesn’t disappear, I can wait 10 minutes, and it’s hanged there, but if I press pause, or forward a bit, start working fine again.
I understand that. I had the same issue in the stable build that did the same thing. I had plenty of bandwidth for the size of the rip, but it had issues anyway. After adding my source as a system mount and putting in a path sub to point my existing library over to it the files played without issue. This is frequently required for people using a Vero and playing larger files.
So is better mounting the folder in fstab and later add to Kodi, correct ?
If you make a system mount with fstab you can test the function by playing though the file manager in settings. If that gets you to where you want to be you can either completely redo your library from scratch or just add a path substitution which will just redirect Kodi to this new location without changing anything else in Kodi or your existing library.
I find that a change of kernel will change the device’s public key. With ssh from linux, I just get a warning to delete the key from known hosts, then I re-connect and accept the new key for that IP. Somethings similar happens with putty. Windows filesharing doesn’t give you a warning but the trick seems to be to delete the relevant entry in Credentials Manager.
I can’t help with Apple stuff.
Can you send me please the output of following command?
cat /sys/class/amhdmitx/amhdmitx0/disp_cap_3d
Yes the same is happening to me, yesterday though when I enabled logging I wasn’t able to reproduce , but still happening randomly , when stopping movie or show , I get the sad face and vero restarts.
I tried playing from file explorer a nfs mounted via fstab and have the same problem:
  • m2ts UHD files: have the problem I explained.
  • m2ts 1080p files: works fine
  • mkv 65gb files: works fine
Also I don’t know why, but I lost the HDR capability, 4k worked fine but without HDR. A reboot solved it.
SSH through macOS Terminal behaves in a similar manner with public key changes, it caches it in ~/.ssh/known_hosts and will fail to connect before warning of mismatched key.
Remove the offending key or the known_hosts file and off you go.
720p50hz FramePacking TopBottom SidebySide
720p60hz FramePacking TopBottom SidebySide
1080p24hz FramePacking TopBottom SidebySide
1080p25hz TopBottom SidebySide
1080i50hz SidebySide
1080i60hz TopBottom SidebySide
Just one small issue for me so far. After the update I had no sound for H264 files with AC3 encoded audio (MPEG2 files with AC3 audio were fine). I went into the Kodi settings and changed the audio from the default to HDMI only and I got sound on all files. Then I changed it back to the default (HDMI, SPIDF, analog) and it kept working. Overall it does seem snappier, although that could be confirmation bias at work.
The updated GPU driver should provide some performance improvements here.
Ok that was the issue. Strange thing is a new install of Debian Buster (10.2 image from a few months ago) does not have those ciphers enabled.
Anyway it’s fixed and I only access Kodi over the LAN or via a VPN to home so it’s all ok I think.
Yeah it does that in Putty but then you just click update and you’re good to go. I was just that specific iOS App and I fixed it by editing out the cipher settings. Thanks.
Working quite well so far. One thing I noticed, however, is that if a particular film had a different Contrast setting other than the default of 50, it always plays initially with a default Contrast setting of 50. If I make any adjustment to the Contrast it’ll play at the new value. For example, if I have a 4K film that I’ve set with a Contrast of 58, lowering it to 57 makes the picture brighter (because it actually adjusted the Contrast from 50 to 57).
