[TESTING] Linux 4.9 kernel and improved video stack for Vero 4K / 4K +
Playing Alita in HDR10+ and did a chapter skip. Crashed (sad face) and went back to home screen at 1080p with HDR10+. Very dark screen. Log here https://paste.osmc.tv/jibegaraze
Here is the media info
General
Unique ID                                : 216091936482807218948372970633221711978 (0xA291CB09FF226C8DD69880E36265286A)
Complete name                            : Alita.Battle.Angel.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 53.3 GiB
Duration                                 : 2 h 1 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 62.6 Mb/s
Movie name                               : Alita.Battle.Angel.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
Encoded date                             : UTC 2019-07-15 01:13:04
Writing application                      : mkvmerge v34.0.0 ('Sight and Seen') 64-bit
Writing library                          : libebml v1.3.7 + libmatroska v1.5.0
Cover                                    : Yes
Attachments                              : small_cover_land.jpg / cover.jpg / cover_land.jpg / small_cover.jpg
Video #1
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 41.4 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.208
Stream size                              : 35.2 GiB (66%)
Title                                    : Alita.Battle.Angel.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 233 cd/m2
Maximum Frame-Average Light Level        : 63 cd/m2
Video #2
Format                                   : HEVC
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 2 133 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Color space                              : YUV
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.043
Stream size                              : 1.82 GiB (3%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #1
Format                                   : MLP FBA 16-ch
Format/Info                              : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Codec ID                                 : A_TRUEHD
Bit rate mode                            : Variable
Bit rate                                 : 5 013 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Compression mode                         : Lossless
Stream size                              : 4.30 GiB (8%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Number of dynamic objects                : 13
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Audio #2
Format                                   : DTS XLL
Format/Info                              : Digital Theater Systems
Commercial name                          : DTS-HD Master Audio
Codec ID                                 : A_DTS
Bit rate                                 : 4 104 kb/s
Channel layout                           : C L R LFE Lb Rb Lss Rss
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 24 bits
Stream size                              : 3.50 GiB (7%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #3
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 640 kb/s
Channel(s)                               : 6 channels
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 558 MiB (1%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : No
Forced                                   : No
Audio #4
Format                                   : DTS XLL
Codec ID                                 : A_DTS
Bit rate                                 : 2 058 kb/s
Channel(s)                               : 2 channels
Bit depth                                : 24 bits
Stream size                              : 1.75 GiB (3%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #5
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Stream size                              : 391 MiB (1%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #6
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Audio #7
Format                                   : DTS
Codec ID                                 : A_DTS
Bit rate                                 : 768 kb/s
Channel layout                           : C L R Ls Rs LFE
Bit depth                                : 24 bits
Stream size                              : 670 MiB (1%)
Language                                 : French
Default                                  : No
Forced                                   : No
Audio #8
Format                                   : DTS
Codec ID                                 : A_DTS
Bit rate                                 : 768 kb/s
Bit depth                                : 24 bits
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Audio #9
Format                                   : DTS
Codec ID                                 : A_DTS
Bit rate                                 : 768 kb/s
Bit depth                                : 24 bits
Language                                 : German
Default                                  : No
Forced                                   : No
Audio #10
Format                                   : DTS
Codec ID                                 : A_DTS
Bit rate                                 : 768 kb/s
Bit depth                                : 24 bits
Language                                 : Italian
Default                                  : No
Forced                                   : No
Audio #11
Format                                   : DTS
Codec ID                                 : A_DTS
Bit rate                                 : 768 kb/s
Bit depth                                : 24 bits
Language                                 : Russian
Default                                  : No
Forced                                   : No
Audio #12
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Language                                 : Czech
Default                                  : No
Forced                                   : No
Audio #13
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Language                                 : Hindi
Default                                  : No
Forced                                   : No
Audio #14
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Language                                 : Hungarian
Default                                  : No
Forced                                   : No
Audio #15
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Language                                 : Polish
Default                                  : No
Forced                                   : No
Audio #16
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Language                                 : Thai
Default                                  : No
Forced                                   : No
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 1 h 55 min
Bit rate                                 : 41 b/s
Count of elements                        : 1347
Stream size                              : 34.8 KiB (0%)
Title                                    : English-SRT
Language                                 : English
Default                                  : Yes
Forced                                   : No
No problem here. Tried several chapter skip forward and backwards.
My file has 36 chapters
Sam, were the 3D bug fixes rolled in with this build?
Updated to buster now via post 1…
I now have no video at all when I play anything. Only have audio.
Updated the vero to buster and the videoimprovement build smoothly.
On one of tvs I’m having the same issues I was having when this thread first started. I.e cec not working most of the time and limited resolution chices. Usually only 1280x720 and maybe a 480p resolution. I was having his a bit on the last build also but was waiting for the buster upgrade to see if it improved. It hasnt
logs here https://paste.osmc.tv/aduxinuxab
Thank you
Provide logs grab-logs -A
Direct connection Vero to TV, no devices (AVR or HDMI switch) in between? Did you tried other cables?
Because the EDID recieved doesn’t look good
====================== Display Cap =================== g0gjk991
480p60hz*
720p60hz
---------------------- Display Cap END --------------- g0gjk991
====================== Display Mode =================== Q72ho215
VIC:4
---------------------- Display Mode END --------------- Q72ho215
====================== EDID =================== wE0go885
Rx Manufacturer Name:
Rx Product Code: 0000
Rx Serial Number: 00000000
Rx Product Name:
Manufacture Week: 0
Manufacture Year: 1990
Physical size(cm): 0 x 0
EDID Version: 0.0
EDID block number: 0x0
blk0 chksum: 0x00
Source Physical Address[a.b.c.d]: 0.0.0.0
YCC support 0x00, VIC (native 3):
ColorDeepSupport 0x00 10/12/16/Y444 0/0/0/0
3 4 16
Audio {format, channel, freq, cce}
{1, 1, 0x07, 0x01}
Speaker Allocation: 0x00
Vendor: 0x000c03 (HDMI device)
MaxTMDSClock1 75 MHz
vLatency:  Invalid/Unknown
aLatency:  Invalid/Unknown
i_vLatency:  Invalid/Unknown
i_aLatency:  Invalid/Unknown
SCDC: 0
RR_Cap: 0
LTE_340M_Scramble: 0
checkvalue: 0x00000000
---------------------- EDID END --------------- wE0go885
Direct connection and tried 2 cables. I believe it looked like this the first time I had the problem. Turned out to be a race condition in the vero if I understood correctly
4.9 Buster running fine here except I have the same blank screen issues I reported recently with the production version of OSMC via the Marantz NR1711, particularly bad with 1080/50 content. But nice to see HDR10+ being reported by my new OLED TV on a couple of my 4K mkv’s, so that side of things seems to be working ok. I have two Vero’s available for use with this AVR, so will keep one on the old kernel if that helps with testing.
Can you point us to where this was discussed before?
What happens if you unplug the HDMI and plug it in again? (that shouldn’t cause any races)
Looks like the blank EDID issue again.
[    2.735840] hdmitx: edid: raw data are all zeroes
It exhausts all 10 tries, which is interesting.
Yes – there were some improvements.
Yes unplugging the cable fixed it. After reboots it seems to be a bit of a lottery if it works.
Around march 30 in this thread was the discussion
Thanks again
Can you quickly check if a cold boot always fails or always succeeds?
@DBMandrake could reliably reproduce this on one of his displays. I made some changes around then and he reported it as fixed. Maybe his monitor is less problematic than yours.
Looks like it is time to revisit the issue
Sam or @tanio99, is there a list of those?
Thanks for everything, I have upgraded from stable 2020-06 following the instructions, everything is working well, there are no crashes like there used to be with previous 4.9 test updates. I have no 3D or HDR TV to check for other improvements. I really love your software support and commitment, will always recommend Vero to others
Yeah @sam_nazarko cold boot and back to limited resolutions and no cec.
Not really.
MakeMKV issues were fixed although this would only affect a few rips within a certain timeframe.
A few other things, but there were too many changes for us to track them reliably.
Thanks for your kind words. Glad things are working well for you.
Any problems, give us a shout.
