[TESTING] Linux 4.9 kernel and improved video stack for Vero 4K / 4K +
I’ve just started properly testing the 4.9 USB image and have hit a green screen.
For me this was in a HDR HEVC rip of Aquaman which I never had problems with on 3.14 kernel. The green screen occurred as I was skipping though the file.
Here is the mediainfo: https://paste.osmc.tv/apefutujar
After hitting the green screen I found that every video I attempted to play thereafter would not play and instead showed a green screen until I rebooted
After a reboot I was able to easily reproduce…I play Aquaman again and hit a remote button which I have mapped to the action: Seek(250) a few times in succession and bam…green screen.
Here are some logs for the second green screen incident following the reboot:
https://paste.osmc.tv/gomamejudi
Very easy to reproduce so happy to provide more logs etc if required.
Sounds a lot like: [TESTING] Linux 4.9 kernel and improved video stack for Vero 4K / 4K + - #1365 by sam_nazarko
which has been solved
I can’t, sorry, next time.
It was fixed by reboot or me exiting to console to clear the arp cache and back from there to the gui a few times. I will when it happens again.
I reread, you mean a debug log when it works? I can do that when I get back home.
Right, yes. I assume the info in the Kodi log will be the same compared to the failed one. I’m interested in the differences in the kernel log.
Any chance of updated USB/SD images?
I’ll do some new images soon. For now, I’d like to make a few more changes.
I am very happy with this test version. Have been using it for some time now and don’t have any major issues. Great 3D performance also. Yesterday I have watched Avatar in 3D and this release still has some glitches, but this is a known issue and I can live with it this way. I think it is almost ready for release to stable? :slight_smile:
Remind me - did unplugging and re-plugging the hdmi cable give you a proper picture?
I did, while the vero was unplugged. It required me to add the source in the tv again but was still showing low res and no cec. When i did the same before the updated version it went hd and cec for a while but a day or so later it was back to low res etc. I always leave the vero on and just put the tv to sleep
I have found a further issue. When playing TS recordings from tvheadend, or even just playing the raw TS file directly I find that the screen flashes black for a couple of seconds a time during playback. It seems to always be at the same points in the file.
If I boot back to the 3.14 kernel then the same file plays flawlessly.
Here is a debug log:
https://paste.osmc.tv/huranokuxe
And here is mediainfo for a 100 second sample file:
https://paste.osmc.tv/amiqoyohum
I’m happy to upload the 100 second sample which demonstrates the problem if that would help.
Has bluez been changed? As of today, I can no longer pair my FireTV remote.
[bluetooth]# pair 1C:12:B0:A8:50:C2
Attempting to pair with 1C:12:B0:A8:50:C2
Failed to pair: org.bluez.Error.ConnectionAttemptFailed
No Bluetooth changes.
Should I break this out into support then?
More info:
[bluetooth]# info 1C:12:B0:A8:50:C2
Device 1C:12:B0:A8:50:C2
Alias: AR
Appearance: 0x0180
Paired: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
Modalias: usb:v0171p0413d0000
[bluetooth]# connect 1C:12:B0:A8:50:C2
Attempting to connect to 1C:12:B0:A8:50:C2
[CHG] Device 1C:12:B0:A8:50:C2 Connected: yes
Failed to connect: org.bluez.Error.Failed
[CHG] Device 1C:12:B0:A8:50:C2 Connected: no
Hi! Bad news: the recent updates do not seem to have fixed this,
Good news: debug logs and playing 2 videos (green display instead) here: https://paste.osmc.tv/gomesaqiho
After reboot, playing the same two videos normally, debug logs here: https://paste.osmc.tv/aboleliwon
We’re almost there :smiley: … unfortunately, you forgot to
I’ve now uploaded the sample file which reproduces this to dropbox here:
Cheers.
I can’t reproduce that.
Likewise. Skimmed logs quickly. @jahutchi did you try playing testfile.ts from local storage (eMMC)?
Sorry that cat :scream_cat: thing was not obvious to me, you know all the cat videos on the Internet :sweat_smile:
Will try to search for the exact cat command when it happens next time.
Does this mean the above two logs are not useful?
