18.8 is the latest stable version.
I’d suggest posting some logs if you still have issues so we can check the system is up to date.
I am on the latest Buster on my Vero 4k+. I went ahead and upgraded to the 4.9 testing kernel and no longer have 4k@60hz as an option. Video playback seems stuttery and laggy at 4k@30hz (now the highest framerate option).
You are going to have to provide logs.
I was abe to downgrade via terminal to 18.8.0-3 but mvc showing 2d here is the log https://paste.osmc.tv/wetunodesu
You downgraded to a version which does not support 3D MVC (the standard Buster version).
Try:
sudo apt-get install vero3-mediacenter-osmc=18.8.0-4
I tried that but now having just a blank screen. It was working a week ago before upgrading.
We need to see logs on that version where you experience a problem
https://paste.osmc.tv/icilesigid
Thank you!
Sorry about that. Here they are:
Also I pressed Yes on the question to update my OSMC and now I’m in a reboot loop with a sad face. Will look in to this tomorrow.
I hope the will be some kind of easy fix and that I don’t have to reinstall everything just because if this.
/Söder
Did you update your repos to the Buster version? See the first post on this thread. It should solve your problem.
Well your TV doesn’t report any 4k 60HZ modes. If you had those before maybe it is a AVR in between giving issues?
720p60hz 1080p24hz 1080p30hz 1080i60hz 1080p60hz 2160p30hz* 2160p24hz 2160p30hz* smpte24hz smpte30hz
Also recommend people with 4K TV’s set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
The settings we recommend are as follows…
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty) *
Some televisions may also need, or benefit from, the following being set…
System>Display>Force 4:2:2 colour subsampling> (enable)
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K. *Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
Thanks. Yes, I updated from the update menu in OSMC.
Now I added that 49 line, and doing an update from terminal. I hope this will fix it.
EDIT: No more sad face and boot loops. Great. Thanks.
/Söder
I’m shure i received an update from 17.10., and 3D MVC works still fine. But i can’t found anything in the changelog?
That would be the release of Debian Buster which is covered on our blog
Ah, OK, means 3D is now in the main stage because it works for me? Do we now have to alter the /etc/apt/sources.list back again?
No – you still need to stay on the 4.9 repository for functioning 3D.
I see the problem. We’ll get it fixed. Meanwhile, a workaround is to make a file disp_cap with the following contents:
720p60hz
1080p24hz
1080p30hz
1080i60hz
1080p60hz
2160p24hz
2160p30hz*
2160p60hz
smpte24hz
smpte30hz
smpte60hz
and put it in /home/osmc/.kodi/userdata/ ie go nano /home/osmc/.kodi/userdata/disp_cap and paste the text above in.
Re-boot.
For the record, what’s the make and model of your TV? Sharp LC58Q73?
And forcing 4:2:2 may be a bad idea for 4k60Hz. Can you let me know if it works with that setting and the disp_cap file in place?
My Vero 4K+ Wont connect to my wireless 5Ghz after testing the Linux 4.9 kernel and improved video stack is applied in sources.list.
Debug logs is here.
Edit: I started the Vero up with the 5Ghz, and switched to 2.4Ghz to upload logs, so both scenarios is in the log.
I made a fresh install, and updated the Vero to the latest October update, just to be sure that nothing has gone wrong in the update, and no problem, can connect to my 5Ghz Wifi, but as soon as i applied 4.9 kernel and improved video stack, i cannot connect.
That’s not completely true, it seems that i can connect, but it gives me an obscure IP
I normaly use DHCP, as i have set it to fixed IP in my Router, but for some reason, it changes to manual, and nothing happens when i click on “Configure Network using DHCP” and it does not help to put the correct IP etc. in manually either.
But as soon as i connect to 2.4Ghz, no problem.
Let me know if you need more info.
Thank you.
Looks like a weak signal. How many white dots did you get with 3.14?
