[TESTING] Linux 4.9 kernel and improved video stack for Vero 4K / 4K +
This worked great! All resolutions and cec working nicely.
Thank you!
Thanks. I’ll make some changes to ensure this behaves as expected for 3.14 too.
It would be good if others can confirm if this works for them as well.
Just reapplied 4.9 to my kitchen Vero which runs through a Panny soundbar, and as before, there are no x1080 resolutions available, it maxes at 720. The OSMC splash screen is 480p, then the GUI is 720.
Looks like your edid is corrupt also. Can you plug the vero into another monitor, see if you get the correct resolutions for that screen, then plug it back into the monitor it’s currently in.
I plugged my 4.9 Vero into my Marantz AVR and it was able to pick up the x1080 resolutions. However, like my other Vero running the March build (but on 3.14), it immediately had blank screen issues upon start/stop, per the other thread I’ve been updating. 3.14 picks up x1080 just fine with my Panny speaker bar.
On re-connecting my 4.9 Vero to the Panny soundbar it booted to 1080. I then rebooted and 1080 was lost. Not sure if that means anything.
I’m getting a lot of sad faces after watching some videos. It happens randomly when starting a video, 3 or 4 movies will play fine, then when starting the next it crashes. I’ll enable logging and post the log when it happens again.
How is your EDID looking in that moment?
Upload logs to check grab-logs -A
https://paste.osmc.tv/ozowugemuf
Your current EDID shows 1080, can’t you currently not configure GUI to 1080? Or is this from when it was working?
====================== Display Cap =================== g0gjk991
480p60hz
576p50hz
720p50hz
720p60hz
1080p24hz
1080i50hz
1080p50hz*
1080i60hz
1080p60hz
The log was just posted with the max available resolution at 720. Here are the current resolutions available to me via the GUI
also the only refresh rates available for the GUI are 59.94 and 60, it has lost all the other device-supported rates.
That’s really odd with the EDID being correct.
I just went back to the GUI resolutions and 1080 appeared in the list, without any interim action on my part. I selected 1080, the change seemed to stick, I then rebooted and then 1080 was gone again and is not in my list of available resolutions.
Yeah actually looking at the logs again seems to be a timing issue. First not detected and then detected. Maybe @grahamh or @sam_nazarko has a better idea what’s going on.
2020-03-29 11:51:43.214 T:4067323904   ERROR: GetString: error reading /home/osmc/.kodi/userdata/disp_cap
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Current display setting is 0192001080060.00000pstd
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Current output resolution is 0072000480059.94006pstd
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Fallback resolution at 16 + 0 00480060.00000pstd
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Fallback resolution at 16 + 2 00720060.00000pstd
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Fallback resolution at 16 + 8 00768060.00000pstd
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2020-03-29 11:51:43.215 T:4067323904  NOTICE: Found best resolution 0102400768060.00000pstd at 24, setting to RES_DESKTOP at 16
2020-03-29 11:51:43.216 T:4067323904   ERROR: GetString: error reading /home/osmc/.kodi/userdata/disp_cap_3d
2020-03-29 11:51:43.216 T:4067323904 WARNING: Update3dResolutions: No valid 3D resolutions found.
2020-03-29 11:51:43.235 T:4067323904  NOTICE: EGL_VERSION = 1.4 Linux-r7p0-00rel0-db6da91a
2020-03-29 11:51:43.235 T:4067323904  NOTICE: EGL_VENDOR = ARM
2020-03-29 11:51:43.235 T:4067323904  NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context EGL_KHR_partial_update EGL_KHR_create_context_no_error
2020-03-29 11:51:43.235 T:4067323904  NOTICE: EGL_CLIENT_EXTENSIONS = EGL_EXT_client_extensions EGL_EXT_platform_base
2020-03-29 11:51:43.236 T:4067323904  NOTICE: Checking resolution 18
2020-03-29 11:51:43.436 T:4067323904  NOTICE: GL_VENDOR = ARM
2020-03-29 11:51:43.436 T:4067323904  NOTICE: GL_RENDERER = Mali-450 MP
2020-03-29 11:51:43.436 T:4067323904  NOTICE: GL_VERSION = OpenGL ES 2.0
2020-03-29 11:51:43.436 T:4067323904  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2020-03-29 11:51:43.436 T:4067323904  NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer GL_KHR_no_error
2020-03-29 11:51:43.809 T:4067323904 WARNING: CLangInfo: could not find language add-on 'English', loading default..
2020-03-29 11:51:44.136 T:4067323904  NOTICE: WaitForNet: Waiting for a network interface to come up (Timeout: 1 s)
2020-03-29 11:51:44.136 T:4067323904  NOTICE: WaitForNet: A network interface is up after waiting 0 ms
2020-03-29 11:51:44.138 T:3947561696  NOTICE: Running database version Addons27
2020-03-29 11:51:44.143 T:3947561696  NOTICE: Running database version ViewModes6
2020-03-29 11:51:44.145 T:3947561696  NOTICE: Running database version Textures13
2020-03-29 11:51:44.153 T:3947561696  NOTICE: MYSQL: Connected to version 10.3.21-MariaDB
2020-03-29 11:51:44.163 T:3947561696  NOTICE: Running database version MyMusic72
2020-03-29 11:51:44.174 T:3947561696  NOTICE: Running database version MyVideos116
2020-03-29 11:51:44.176 T:3947561696  NOTICE: Running database version TV32
2020-03-29 11:51:44.179 T:3947561696  NOTICE: Running database version Epg12
2020-03-29 11:51:44.179 T:4067323904  NOTICE: start dvd mediatype detection
2020-03-29 11:51:44.242 T:4067323904  NOTICE:   load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.27)
2020-03-29 11:51:44.883 T:4067323904 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2020-03-29 11:51:44.991 T:4067323904  NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2020-03-29 11:51:45.010 T:4067323904  NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2020-03-29 11:51:45.020 T:4067323904  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2020-03-29 11:51:45.022 T:4067323904  NOTICE: Loaded playercorefactory configuration
2020-03-29 11:51:45.022 T:4067323904  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2020-03-29 11:51:45.023 T:4067323904  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2020-03-29 11:51:45.031 T:4067323904  NOTICE: initialize done
2020-03-29 11:51:45.032 T:4067323904  NOTICE: Running the application...
2020-03-29 11:51:45.042 T:4067323904  NOTICE: starting zeroconf publishing
2020-03-29 11:51:45.044 T:4067323904  NOTICE: CWebServer[80]: Started
2020-03-29 11:51:45.047 T:3813630688  NOTICE: ES: Starting UDP Event server on port 9777
2020-03-29 11:51:45.048 T:3813630688  NOTICE: UDP: Listening on port 9777 (ipv6 : true)
2020-03-29 11:51:45.341 T:3880772320  NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
2020-03-29 11:51:45.388 T:3889165024  NOTICE: Register - new hid device registered on usb->/sys/devices/platform/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2: OSMC RF Remote (2017:1688)
2020-03-29 11:51:48.865 T:3947561696  NOTICE: PVR Manager: Starting
2020-03-29 11:51:48.921 T:3615384288  NOTICE: PVR Manager: Started
2020-03-29 11:51:49.923 T:3909890784  NOTICE: EPG thread started
2020-03-29 11:52:09.997 T:4067323904   ERROR: GetString: error reading /home/osmc/.kodi/userdata/disp_cap
2020-03-29 11:52:09.998 T:4067323904  NOTICE: Current display setting is 0128000720060.00000pstd
2020-03-29 11:52:09.998 T:4067323904  NOTICE: Current output resolution is 0128000720060.00000pstd
2020-03-29 11:52:09.998 T:4067323904  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2020-03-29 11:52:09.998 T:4067323904  NOTICE: Fallback resolution at 16 + 0 00480060.00000pstd
2020-03-29 11:52:09.998 T:4067323904  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2020-03-29 11:52:09.998 T:4067323904  NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2020-03-29 11:52:09.998 T:4067323904  NOTICE: Fallback resolution at 16 + 2 00576050.00000pstd
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Fallback resolution at 16 + 3 00720050.00000pstd
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Current resolution setting found at 16 + 4
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 50.000000 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 60.000000 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 59.940060 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2020-03-29 11:52:09.999 T:4067323904  NOTICE: Found best resolution 0128000720060.00000pstd at 20, setting to RES_DESKTOP at 16
2020-03-29 11:52:09.999 T:4067323904   ERROR: GetString: error reading /home/osmc/.kodi/userdata/disp_cap_3d
2020-03-29 11:52:10.000 T:4067323904 WARNING: Update3dResolutions: No valid 3D resolutions found.
2020-03-29 11:52:10.186 T:4067323904  NOTICE: Updated resolutions and set desktop
2020-03-29 11:53:24.212 T:4067323904  NOTICE: NFS is idle. Closing the remaining connections.
I found out that one of the Kodi samples is skipping like crazy, hope you can find out the issue, it ran fine with 3.x kernel.
If you need any logs from my side, give a shout.
The helicopter demo has never run fine IIRC.
Indeed. Although the one I have is mkv.
Weird it ran fine here, just ran it a few weeks ago.
I have Atmos now in my new home with 4 ceiling speakers.
Thanks for the link. This looks like the m2ts problem which is being actively worked on.
