Hi folks,
in case of the github issue about broken composite output:
opened 12:27AM - 23 Dec 22 UTC
closed 12:35AM - 23 Dec 22 UTC
As many have stated here:
https://discourse.osmc.tv/t/rpi3a-new-install-boots-t… o-sad-face/92278
and Here:
https://discourse.osmc.tv/t/composite-video-broken-after-update-on-rpi-3b/93275
and here:
https://discourse.osmc.tv/t/trying-to-boot-pi-4-via-composite-stuck-on-splash/91311
here:
https://discourse.osmc.tv/t/black-screen-on-composite-output-after-update/92358
here:
https://discourse.osmc.tv/t/rpi2-composite-failure/90011/15
also here:
https://discourse.osmc.tv/t/black-after-splash-composite-video-9-kv-9pt50-tv/90309/4
AND EVEN HERE:
https://github.com/osmc/osmc/issues/687
THE FREKIN COMPOSITE OUTPUT DOES NOT WORK AND HASNT SINCE 2020!!
No excuses for every single mention of this issue (INCLUDING MINE I KNOW IT) GETTING COMPLETELY IGNORED
From the devs every time this comes up anywhere.
Please for the love of god can you if not fix, then just frekin do, something on your keyboard and TYPE A RESPONSE!
Why is this not been fixed, can it be fixed, and is there anything you could (IF ITS NOT TO GOD DAM TROUBLE TO ASK) recommend We can do to that could help get this working again?
This is a bug,
And no I'm not going to,be number 83 out of the 100 posts on the osmc forums to,get ignored in this subject
Wichnis another reason why I am posting this here.
You all probably know,this,
But for,those who don't,
When not,using the HDMI on the raspberry pi as the video output, you have the option to use analog composite video,output after change to the config,txt.
After a 2020 update that doesn't f***ING work with the rapsberry pi 4,
This feature has been broken resulting in it displaying the splash screen... Then nothing but a Black screen.
You can here kodi working when using the remote, so its working with sound but that's it!!
So,
Are we going to,get a response here?
Or,is this just going to be yet another god dam pissing in the wind being completely ignored by the devs!
80% granite this will be Yet again another person brining this up just to,get a hand in my face!
Anything?
I did the devel upgrade. after reboot the USB Ports stopped working.
Downgrade to bootloader did not solve the problem.
Tested on Raspberry 3B and 3B+
Do you have the same problem?
I asked @popcornmix about this.
He suggests you try Raspberry Pi OS and see if you experience a problem there. The latest version is also using the 5.15 kernel.
Have tested Raspberry Pi OS 32 and 64bit. The problem does not exist.
So i did a further test with osmc image → problem is back, exist already.
tested a usual usb keyboard, same problem.
Stay tuned - someone on our team was able to reproduce the issue.
I will investigate further
I updated my OSMC on RPI3 last night after being prompted and now USB is not working at all.
Am I having the same issue discussed here?
Is there a way to perform a rollback of the update?
It sounds like you had the staging repository activated. You can install an older kernel and may want to avoid that repository as it’s for testing purposes only.
I think I’ve found the issue on RBP 2/3/3+ and it should now be fixed in staging and you should be able to update using the same instructions.
However, I couldn’t reproduce this problem on Pi 4 and the needed changes are already default on Pi 4.
Please try updating again and let me know how it goes
Many thanks
You are right, I had the dev repo active. I think it was from back when widevine needed a newer distro than the main branch had. Not sure though…
Thanks anyways for the hint.
