please any change that you could give me a hand again if you have time with the nfs, thanks
With NFS, a fstab mount would look like this:
192.168.1.100:/Movies /mnt/Movies nfs x-systemd.automount,noauto,rw 0 0
To verify whatâs exported on the NFS server:
showmount -e 192.168.1.100
thanks
Export list for 192.168.1.100:
/mnt/user/downloads *
/mnt/user/TVShows *
/mnt/user/TV *
/mnt/user/Photo *
/mnt/user/Music *
/mnt/user/Movies *
/mnt/user/HT Demo *
/mnt/user/Concerts *
/mnt/user/Backup *
/mnt/user/App Portable *
/mnt/user/APK *
/mnt/user/4K *
/mnt/user/3DMKV *
/mnt/disks/WDBackup *
/mnt/disks/WDSab *
then when i try to mount it i get this
sudo mount /mnt/Movies
mount.nfs: access denied by server while mounting 192.168.1.100:/Movies
is that a problem on my unraid service?
You probably need to use /user/Movies then:
192.168.1.100:/user/Movies /mnt/Movies nfs x-systemd.automount,noauto,rw 0 0
But, some NAS do odd things, so if that doesnât work, try:
192.168.1.100:/mnt/user/Movies /mnt/Movies nfs x-systemd.automount,noauto,rw 0 0
Of course, check the configuration on your NAS to be sure of the permissions allowed.
yeah the permission on my server are public and i can access from my devices browsing NFS
i got no errors on this one
but when i type
sudo mount /mnt/Movies nothing come out i dont see my files
i also try
sudo mount /mnt/user/Movies
mount: canât find /mnt/user/Movies in /etc/fstab
You did remove the SMB mount, right?
Some NAS report the exports oddly. My WD MyCloud is one:
brian@gelth ~ $ showmount -a davros
All mount points on davros:
192.168.1.124:/mnt/HD/HD_a2/Tardis
But to mount:
davros:/nfs/Tardis /media/Tardis nfs rw,user,noauto,noatime,x-systemd.automount 0 0
So you may need to look at the NAS configuration to make sure of how itâs exported.
yeah i remove my movies smb
will this help, this is from my server
See exports(5) for a description.
This file contains a list of all directories exported to other computers.
It is used by rpc.nfsd and rpc.mountd.
â/mnt/disks/WDSabâ -async,no_subtree_check,fsid=200 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/disks/WDBackupâ -async,no_subtree_check,fsid=201 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/3DMKVâ -async,no_subtree_check,fsid=109 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/4Kâ -async,no_subtree_check,fsid=114 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/APKâ -async,no_subtree_check,fsid=117 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/App Portableâ -async,no_subtree_check,fsid=116 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/Backupâ -async,no_subtree_check,fsid=104 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/Concertsâ -async,no_subtree_check,fsid=105 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/HT Demoâ -async,no_subtree_check,fsid=106 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/Moviesâ -async,no_subtree_check,fsid=101 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/Musicâ -async,no_subtree_check,fsid=103 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/Photoâ -async,no_subtree_check,fsid=110 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/TVâ -async,no_subtree_check,fsid=102 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/TVShowsâ -async,no_subtree_check,fsid=107 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
â/mnt/user/downloadsâ -async,no_subtree_check,fsid=113 *(sec=sys,rw,insecure,anongid=100,anonuid=99,all_squash)
root@Server:~#
From that it looks like /mnt/user/Movies is the correct mount. Did you try rebooting?
yeah i did gone reboot again
From command line, you still see nothing if you:
$ ls -l /mnt/Movies
got it , ls -l /mnt/Movies shows my movies, does it mean that is working right?
Yep, you should be good to go. And you can now switch your other mounts to NFS.
And the good think about using fstab is that if you had already scraped your media, to Kodi itâs all still in the same place. /mnt/Movies is the same if itâs SMB or NFS mounted.
great nice and thanks again for all you help, i learn a lot from you today
one more question, just for curiosity can this be down from server side so like that my shield tv can benefice from this
thanks again
forgot to ask, now wiht nfs fstab i use the same on kodi /mnt/Movies or is diferent
I donât know anything about Shield TV. Sorry. But if itâs linux based then what youâve learned here may help
No problem, glad I was able to help. Iâd like to know if it helps with the problems you had playing 4K content.
I think might be a misunderstanding @mata7 was using kodi based nfs mounts.
So he has to either use path substitution or better rescrape with the new source
yes i did reset kodi and going start fresh rescrape, so i will need to use /mnt/user/Movies when adding the shares to kodi right?
actually i only have stutter problem with one movie and i delete it at ready but will let you know if i have any more problem with 4K
Yes, you will find it via âroot filesystemâ in Kodi when adding sources
thank you, wow got all my shared setup and ready , really excited
i ben getting this failed to mount error, but the files play fine, i look at the logs and i see this
Jun 14 16:30:24 CubaMC systemd[1]: Failed to mount /mnt/TV.
Jun 14 16:30:24 CubaMC systemd[1]: mnt-TV.mount: Unit entered failed state.
Jun 14 16:30:24 CubaMC systemd[1]: mnt-Movies.automount: Got automount request for /mnt/Movies, triggered by 767 (JobWorker)
Jun 14 16:30:24 CubaMC systemd[1]: Mounting /mnt/MoviesâŚ
Jun 14 16:30:24 CubaMC systemd[1]: mnt-Movies.mount: Mount process exited, code=exited status=32
Jun 14 16:30:24 CubaMC systemd[1]: Failed to mount /mnt/Movies.
Jun 14 16:30:24 CubaMC systemd[1]: mnt-Movies.mount: Unit entered failed state.
Jun 14 16:30:24 CubaMC systemd[1]: mnt-TVShows.automount: Got automount request for /mnt/TVShows, triggered by 767 (JobWorker)
Jun 14 16:30:24 CubaMC systemd[1]: Mounting /mnt/TVShowsâŚ
Jun 14 16:30:24 CubaMC systemd[1]: mnt-TVShows.mount: Mount process exited, code=exited status=32
Jun 14 16:30:24 CubaMC systemd[1]: Failed to mount /mnt/TVShows.
Jun 14 16:30:24 CubaMC systemd[1]: mnt-TVShows.mount: Unit entered failed state.
Jun 14 16:30:24 CubaMC systemd[1]: mnt-Concerts.automount: Got automount request for /mnt/Concerts, triggered by 767 (JobWorker)
Jun 14 16:30:24 CubaMC systemd[1]: Mounting /mnt/ConcertsâŚ
Jun 14 16:30:24 CubaMC systemd[1]: mnt-Concerts.mount: Mount process exited, code=exited status=32
Jun 14 16:30:24 CubaMC systemd[1]: Failed to mount /mnt/Concerts.
Jun 14 16:30:24 CubaMC systemd[1]: mnt-Concerts.mount: Unit entered failed state.
Show us your current fstab file.
