within the last update there was the remark that the preparations for Debian 9 started after it is now officially released. Are there any details that can be shared with the community? It would be interesting to see the timeline when OSMC will switch to Debian 9.
Now the weather doesn’t really invite to spend time outside I would like to play a bit more with hyperion.ng. Problem is I upgraded my “RPI-build-box” to Debian Stretch so I can no longer use the hyperion-packages I build there on the Vero due to changed dependencies. I could downgrade it back to Jessie but since Stretch is “around the corner” for the Vero I don’t really want to.
I would like to upgrade manually to Stretch. Can the Raspbian upgrade procedure be used on the Vero? Is just replacing jessie with stretch in sources.list sufficient? Will this keep my box compatible with future update/upgrades of the Vero? i.e. is the future upgrade of the Vero basicly with I will do manually?
Seen as I need to upgrade to Stretch on the Vero because of changed dependencies/version (e.g. Python 3.4 -> 3.5) I guess it’s best to wait until the Stretch repository has been built.
