I have been using OSMC & i am facing issue. My media library seems to be updating very slowly & I am not sure if it is a settings issue or something with the network. Also i have tried restarting the system and checking the network connection but no luck so far. Has anyone else experienced this slow updating problem? Any tips or settings I should check to speed things up??
reproduce the issue
