Transmission don't works
I install Transmission on my Raspberry Pi 2 (OSMC) but when I launch Transmission I have an error message “could not connect to transmission open settings dialog”.
is that there is a solution or it takes an update ?
Thx
If you install the add-on, it’s just a viewer.
If you try from the OSMC appstore: [TESTING] Transmission app
