You can use this script, I made it several months ago.
#!/bin/bash
ELEMENTS=/home/osmc/Downloads/*
DOWN_DIR="/home/osmc/Downloads"
DEST_DIR="/media/2TB_EHDD/ToClassify"
DATE="$(date)"
echo "$DATE"
#Test if /media/2TB_EHDD/ToClassify exists
if [ ! -d "$DEST_DIR" ]; then
echo "Destination directory does not exist. Check if external drive "2TB_EHDD" is plugged and running"
echo "Aborting..."
exit 1
fi
#Test if there are sub-dir in Downloads directory
subdircount=`find $DOWN_DIR -maxdepth 1 -type d | wc -l`
#Test if there are files in Downloads directory
if [ ! "$(ls -A $DOWN_DIR)" ]; then
echo "$DOWN_DIR is empty and thus contains no file. Nothing to process...."
echo "Exiting $0"
exit 1
fi
#Loop over files and folders in Downloads directory
shopt -s nullglob
for f in $ELEMENTS
do
#if it's a file
if [ -f "$f" ]; then
EXT="${f##*.}"
filename=$(basename "$f")
#if filename does not end with 'part'
if [ $EXT != "part" ]; then
echo "Processing file '$filename'. Moving "$filename" to $DEST_DIR"
mv -vf "$f" $DEST_DIR
else
echo "$filename download still in progress... Waiting for completion to move file to $MEDIA"
fi
fi
#if it's a directory (works only with a depth of 1)
if [ -d "$f" ]; then
folder=$f
countfilewithpart=0
shopt -s nullglob
for file in "$folder"/*
do
#test if it's a file
if [ -f "$file" ]; then
subext="${file##*.}"
subfilename=`basename "$file"`
if [ $subext == "part" ]; then
echo "$subfilename download still in progress... Waiting for completion..."
countfilewithpart=$((countfilewithpart+1))
fi
fi
done
#There is no file which filename ends with 'part'
if [ $countfilewithpart == 0 ]; then
echo "Processing directory $folder , moving to $DEST_DIR"
mv -vf "$folder" $DEST_DIR
fi
fi
done
exit 0
It assumes you are using transmission, and it appends “.part” at the end of the file it is downloading.
It also moves all the finished downloads to “/media/2TB_EHDD/ToCLassify”.
Let me know if you need any help with it.
And this one simply deletes all the files ending with “.torrent” in ‘/home/osmc/Downloads’:
#!/bin/bash
cd /home/osmc/Downloads
counter=0
shopt -s nullglob
for f in *.torrent
do
rm -rvf "${f}"
counter=$((counter+1))
done
if [ $counter == 0 ]; then
echo "No torrent file to delete"
exit 1
else
exit 0
fi
You just have to use crontab then to schedule the execution of the script.
I just want to delete my .torrent files once torrent file and been completed. Looks like this script will actually move the payload as well.
(i’ve configured Transmission to put in-progress torrent in a directory called incomplete, transmission will move to default directory as per the .json file).
Could i use just the ‘delete torrent when done’ portion?
If you have already configured transmission to auto move the files when the downloads are completed, then you just have to use the second script I posted.
Just change the path of the first command to the path where the ‘.torrent’ files are kept (i.e : cd /path/to/torrents_files).
Save the script in a .sh file (i.e : deleteTorrents.sh).
Don’t forget to make it executable : sudo chmod +x /path/to/deleteTorrents.sh
Then schedule the job with cron :
crontab -e
append this line at the end of the file, the script will run every 10 minutes with no output at all. 0,10 * * * * /path/to/deleteTorrents.sh >> /dev/null 2>&1
if you want some output (to see which files have been deleted) 0,10 * * * * /path/to/deleteTorrents.sh >> /path/to/outputFile
